- Posted on
Fri Nov 17, 2017 11:21 pm
matt (support)
offline
- Site Admin
I'm not sure if that is possible or not. Try turning on Indigo's Z-Wave debugging checkbox (via the Interfaces->Z-Wave->Configure... menu item), then press/toggle each switch independently 3 or 4 times. Copy/paste the Event Log results into a reply and we'll see if it is sending unique commands or not.
Also try adding an Association Group from the ZW116 back to your Z-Wave Interface (Z-Stick) for Group 2, then repeat pressing each switch 3 or 4 times. Copy those results over as well into a follow-up post.
