Updated to 7.1.1 and noticed a bit afterwards that one light no longer works. Cannot be 100% sure that this is cause and effect rather than just correlation, but am least a bit suspicious. Here is an extract from the log after trying to resync.
- Code: Select all
Z-Wave Error device "Garden lantern" does not support on command
Z-Wave Syncing - started for "Garden lantern"
Z-Wave Syncing - assigning return route to "014 - Garden lantern"
Z-Wave Error Syncing - failed to assign return route
Z-Wave Syncing - retrieved manufacture and model names: Fibaro System - 010F, Dimmer Switch (FGD212) - 01021000
Z-Wave Syncing - retrieved protocol version 4.05, app version 3.03
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Mulitlevel Switch : Dimmable Power Switch (04 : 11 : 01, base 26)
Z-Wave Syncing - retrieved command classes: 20v1 60v4 22v1 26v3 86v1 27v1 7Av1 72v1 8Ev1 70v1 71v1 32v3 73v1 75v1 56v1 98v1 59v1 31v4 5Av1 5Ev1 85v1
Z-Wave Syncing - retrieved capabilities: routing, beaming, security
Z-Wave Syncing - retrieved multi-endpoint types: 1:(11 : 01), 2:(11 : 01)
Z-Wave Syncing - retrieved multi-endpoint classes: 1:[5E 20 86 26 85 59 8E 32 31 71], 2:[5E 20 86 26 85 59 8E]
Z-Wave Syncing - retrieved group 2 associations: [1]
Z-Wave Syncing - retrieved group 3 associations: []
Z-Wave received "Kitchen - Motion Sensor" status update is on
Z-Wave Syncing - retrieved group 4 associations: []
Z-Wave Syncing - retrieved group 5 associations: []
Z-Wave Syncing - group 2 association to interface already exists (skipping)
Z-Wave Syncing - retrieved parameter 20 "Switch type" is 2 "Shutters"
Z-Wave Syncing - retrieved parameter 28 "Enable scene commands" is false
Z-Wave Syncing - retrieved parameter 23 "Enable double-click to full brightness" is true
Z-Wave Syncing - retrieved parameter 9 "Power up to last known state" is true
Z-Wave Syncing - retrieved parameter 26 "Enable 3-way switch mode" is false
Z-Wave Syncing - retrieved parameter 1 "Minimum value" is 9
Z-Wave Syncing - retrieved parameter 2 "Maximum value" is 68
Z-Wave Syncing - retrieved parameter 7 "Local dim delta" is 1
Z-Wave Syncing - retrieved parameter 8 "Local dim timer" is 5 * 10 milliseconds
Z-Wave Syncing - retrieved parameter 5 "On/Off dim delta" is 1
Z-Wave Syncing - retrieved parameter 6 "On/Off dim timer" is 1 * 10 milliseconds
Z-Wave Syncing - retrieved parameter 50 "Immediate power threshold" is 10 %
Z-Wave Syncing - retrieved parameter 52 "Periodic report delay" is 3600 seconds
Z-Wave Syncing - complete
Z-Wave sent "014 - Mulitlevel Switch 2" status request
Z-Wave received "Kitchen - Motion Sensor" status update is off
Z-Wave received "016 - Tamper" status update is off
14 Nov 2017 at 09:38:59
14 Nov 2017 at 09:39:58
Z-Wave sent "Garden lantern" on
Z-Wave received "Garden lantern" status update is off
Schedule Change screensaver picture
Z-Wave Error send "Garden lantern" requestMeterLevel command failed (module might be asleep, or is unreachable)
14 Nov 2017 at 09:40:29
Z-Wave Error No response from "014 - Garden lantern". Module might be asleep, or is unreachable.
Any advice on what to do?
LM
