GE Z-Wave+ Wireless Smart Lighting Motion Dimmer 26933?
Mon Nov 13, 2017 10:54 am
It's a combination wall switch and motion sensor. It would be handy for my office. Always good to move to something hard wired.
I don't see it or anything like it listed in the compatible devices list.
Mon Nov 13, 2017 11:11 am
Re: GE Z-Wave+ Wireless Smart Lighting Motion Dimmer 26933?
It doesn't look like anyone has submitted any information on that one yet. If you get one then submit the information and post a follow-up here of the Sync results for us.
Fri Nov 24, 2017 3:12 pm
davidw offline
This seems like it would be pretty handy - motion sensor and light switch that operates locally or remotely, all in one decora-sized package. So far only the switch function works though, even though Indigo detects that it's a multi-sensor device. Output below:
Indigo Z-Wave Version: 2.0.111
Node ID: 27
Model: Dimmable Power Switch
Model ID: 494D3034
Manufacturer: General Electric
Manufacturer ID: 0063
Protocol Version: 4.34
Application Version: 5.27
Model Definition Version: 0
Library Type: 3
Class Name: Dimmable Power Switch
Class Hierarchy: 04 : 11 : 01
Command Class Base: 26
Command Versions: 20v1 85v1 86v1 8Ev1 56v1 59v1 5Av1 5Ev1 60v4 26v2 27v1 2Bv1 2Cv1 70v1 71v1 72v1 73v1 7Av1
Multi-Endpoint Types: 1:(11 : 01), 2:(07 : 01)
Multi-Endpoint Classes: 1:[5E 59 26], 2:[5E 59 71]
Features: routing, beaming
Neighbors:
Associations: 1:[1] 2:[] 3:[]
Config Values: - none -
Sat Nov 25, 2017 3:29 pm
Thanks, we'll add it to the module request list. You might be able to use the Trigger that can catch raw Z-Wave commands to detect the motion command in the mean time.
