Associating a dual Qubino switch with a dual Merten pushbutt
Sun Oct 29, 2017 4:19 am
Stoutjesdijk offline
Hi all,
I have an association puzzle, and no matter what I try, I do not get the desired behaviour.
I have one dual switch by Qubino, and one dual pushbutton by Merten. I want to control relay A with the left button on the Merten, and relay B with the right. How do I do this? If I set the Merten as the controlling device, I can set associations between the top/bottom side of both switches (through groups 1/2 and 3/4 respectively), but I can only switch both Qubino relays at the same time!
Hopefully I'm explaining the problem clearly but please let me know if I need to provide more data.
Any help greatly appreciated as I'm pulling my hair out on this one!
Mark
Best regards,
Mark
Trying to tie it all together...
| Indigo | Plex | NAD M33 | Unifi | LG WebOS | Tado | Sonos | SolarEdge | HUE |
Sat Nov 18, 2017 2:27 am
Re: Associating a dual Qubino switch with a dual Merten push
Hi there!
Just wondering, does anyone have am idea how to solve the above problem to associate a dual switch with a dual battery-operated controller?
Best regards,
Mark
Sat Nov 18, 2017 11:21 am
Colly offline
I've had plenty of issues with the Qubino's in the past, one issue was that both outputs would switch on if I2 (I think) was switched. I eventually got it sorted. Does it work properly by switching I1 & I2 from a wall switch and also from Indigo? Maybe you've already proven that and it's more of an association problem.
Sun Nov 19, 2017 7:05 am
Hi Colly,
Yes it is purely an association issue. The switches work fine from Indigo.
Cheers
Mark
Best regards,
Mark
Sun Nov 19, 2017 8:34 am
Colly offline
Hi Mark,
To achieve something similar I create a Trigger to react to a button press. See screenshot of how it is set up - maybe this might work for you?
Screen Shot 2017-11-19 at 14.30.57.png (84.65 KiB) Viewed 1115 times
Sun Nov 26, 2017 10:14 am
I tried, but my Merten pushbutton transmitter does not have any commands in the dropdown button. It's also very, very quiet in the z-wave log...
Best regards,
Mark
Users browsing this forum: No registered users and 18 guests
