Zooz Z-Wave Plus Smart Plug ZEN06 with 2 USB Charging Ports
Tue Oct 10, 2017 9:59 pm
srkinard offline
I bought one of these for the USB ports and the energy monitoring...
It works in Indigo...but it's annoying me...the log fills with every single energy update. I changed the Polling to once every hour, but it still seems to send an update to Indigo any time the power consumption changes...
Here's the device info:
Indigo Z-Wave Version: 2.0.96
Node ID: 77
Model: Relay Power Switch
Model ID: 0101000A
Manufacturer: Zooz
Manufacturer ID: 027A
Protocol Version: 4.34
Application Version: 1.02
Model Definition Version: 0
Library Type: 3
Class Hierarchy: 04 : 10 : 01
Command Class Base: 25
Command Versions: 20v1 25v1 86v1 27v1 2Bv1 2Cv1 32v3 70v1 72v1 73v1 59v1 7Av1 5Av1 5Ev1 85v1
Features: routing, beaming, energyMeter
Neighbors: - none -
Associations: 1:[1]
Config Values: - none -
And here's a sample of the log getting hammered by this device:
   Z-Wave                          received "Front Porch - Sensor - Temperature" sensor update to 66.2 °F
   Z-Wave                          received "Front Porch - Sensor - Humidity" sensor update to 53%
   Z-Wave                          received "Living Room Entertainment Center" power load to 41.912 W
   Z-Wave                          received "Front Porch - Sensor - Luminance" sensor update to 0 lux
   Z-Wave                          received "Front Porch - Sensor - Ultraviolet" sensor update to 0
   Z-Wave                          received "Living Room Entertainment Center" power load to 54.022 W
   Z-Wave                          received "Living Room Entertainment Center" power load to 48.335 W
   Z-Wave                          received "Living Room Entertainment Center" power load to 41.993 W
   Z-Wave                          received "Living Room Entertainment Center" power load to 47.669 W
   Z-Wave                          received "Living Room Entertainment Center" power load to 41.832 W
   Z-Wave                          received "Living Room Entertainment Center" power load to 46.975 W
   Z-Wave                          received "Living Room Entertainment Center" power load to 42.074 W
   Z-Wave                          received "Living Room Entertainment Center" power load to 57.146 W
   Z-Wave                          received "Living Room Entertainment Center" power load to 47.021 W
   Z-Wave                          received "Living Room Entertainment Center" power load to 41.872 W
   Z-Wave                          received "Living Room Entertainment Center" power load to 47.716 W
   Z-Wave                          received "Living Room Entertainment Center" power load to 41.792 W
   Z-Wave                          received "Living Room Entertainment Center" power load to 47.067 W
   Z-Wave                          received "Living Room Entertainment Center" power load to 40.639 W
   Z-Wave                          received "Front Porch - Sensor - Temperature" sensor update to 66.3 °F
   Z-Wave                          received "Living Room Entertainment Center" power load to 47.204 W
   Z-Wave                          received "Living Room Entertainment Center" energy total to 0.126 kWh
   Z-Wave                          received "Living Room Entertainment Center" power load to 48.383 W
   Z-Wave                          received "Living Room Entertainment Center" power load to 42.443 W
   Z-Wave                          received "Living Room Entertainment Center" power load to 54.820 W
   Z-Wave                          received "Living Room Entertainment Center" power load to 47.952 W
   Z-Wave                          received "Living Room Entertainment Center" power load to 41.952 W
   Z-Wave                          received "Living Room Entertainment Center" power load to 48.047 W
   Z-Wave                          received "Living Room Entertainment Center" power load to 57.887 W
   Z-Wave                          received "Living Room Entertainment Center" power load to 44.326 W
Any way to cut down on the messages or anything? Matt? Jay?
Ross
Tue Oct 10, 2017 11:54 pm
Re: Zooz Z-Wave Plus Smart Plug ZEN06 with 2 USB Charging Po
Ross, there’s various parameters that control the frequency of reports in the manual.
I’d expect them to be exposed in the Edit Device dialog assuming Indigo has recognised the device - are they not there?
If not, go Interfaces > Zwave > Set parameters manually (or something about parameters)
151, 152, 171, 172, 173 and 174 are the parameters - read the manual for them.
Thu Oct 12, 2017 4:41 pm
srkinard offline
Yeah...had to change Parameters 151 and 152 to 0 to make it stop
I've never changed a parameter on a device like this so I learned something new....thanks!
Ross
Fri Nov 17, 2017 7:49 pm
toille27 offline
I tried this and it didn't work. For me, the key is to change parameter 171 (power reporting frequency) to "0" and it finally shut the energy reporting down.
Manual here http://www.getzooz.com/downloads/Zooz-Z-Wave-Smart-Plug-ZEN06-Manual.pdf
Wed Nov 22, 2017 1:55 am
It depends on your preference.
171 will stop the “send Power every hour” report.
151 will stop the “send Power whenever it changes by ...” report, which is what I believe was filling Ross’s log when I replied last month.
