Heiman Z Wave Door/Window Sensor (HS1DS)
Thu Oct 05, 2017 9:57 am
CliveS offline
Just bought 6 x Heiman Z Wave Door/Window Sensor (HS1DS) for £33.66.
(That is for 6 so £5.61 each, 1st class post free - well they are £7.49 each but buy 2 and get the second one at 50% off at present)
http://www.ebay.co.uk/itm/263094691704
Installed into Indigo and got the following
2017-10-04 16:17:28.322 Z-Wave started controller inclusion mode
2017-10-04 16:17:53.836 Z-Wave controller included module: 148 - Notification Sensor
2017-10-04 16:17:53.840 Z-Wave stopped controller inclusion mode
2017-10-04 16:17:58.116 Z-Wave Syncing - started for "148 - Notification Sensor"
2017-10-04 16:17:58.140 Z-Wave Syncing - retrieved module neighbors list: 37, 38, 72
2017-10-04 16:17:58.141 Z-Wave Syncing - assigning return route to "148 - Notification Sensor"
2017-10-04 16:18:00.755 Z-Wave Syncing - assigned return route
2017-10-04 16:18:01.351 Z-Wave Syncing - retrieved manufacture and model names: Unknown - 0260, Notification Sensor - 01680168
2017-10-04 16:18:01.683 Z-Wave Syncing - retrieved protocol version 4.05, app version 1.01
2017-10-04 16:18:02.018 Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Notification Sensor : Notification Sensor (04 : 07 : 01, base 00)
2017-10-04 16:18:02.018 Z-Wave Syncing - retrieved command classes: 20v1 80v1 84v2 85v1 86v1 30v1 71v1 72v1 73v1 59v1 5Av1 5Ev1
2017-10-04 16:18:02.018 Z-Wave Syncing - retrieved encrypt commands: - none -
2017-10-04 16:18:02.018 Z-Wave Syncing - retrieved capabilities: routing, battery, beaming, waking
2017-10-04 16:18:02.401 Z-Wave Syncing - retrieved wake interval of 180 minutes
2017-10-04 16:18:02.484 Z-Wave Syncing - device "148 - Notification Sensor" wake interval changed to 60 minutes
2017-10-04 16:18:03.312 Z-Wave Syncing - retrieved group 1 associations: []
2017-10-04 16:18:03.642 Z-Wave Syncing - retrieved group 2 associations: []
2017-10-04 16:18:03.971 Z-Wave Syncing - retrieved group 3 associations: []
2017-10-04 16:18:04.312 Z-Wave Syncing - retrieved group 4 associations: []
2017-10-04 16:18:04.642 Z-Wave Syncing - retrieved group 5 associations: []
2017-10-04 16:18:05.027 Z-Wave Syncing - added group 1 association to interface
2017-10-04 16:18:05.361 Z-Wave Syncing - retrieved battery level of 95%
2017-10-04 16:18:05.585 Z-Wave Syncing - created device "148 - Notification Sensor"
2017-10-04 16:18:05.603 Z-Wave Syncing - complete
2017-10-04 16:18:06.046 Z-Wave sent "148 - Notification Sensor" status request
2017-10-04 16:18:06.378 Z-Wave received "148 - Notification Sensor" status update battery level 95%
2017-10-04 16:18:26.826 Z-Wave received "148 - Notification Sensor" status update battery level 95%
2017-10-04 16:19:20.230 Z-Wave Indigo Device "Heiman 1 Notification Sensor" Z-Wave Properties:
Indigo Z-Wave Version: 2.0.96
Node ID: 148
Model: Notification Sensor
Model ID: 01680168
Manufacturer: Unknown
Manufacturer ID: 0260
Protocol Version: 4.05
Application Version: 1.01
Model Definition Version: 0
Library Type: 6
Class Name: Notification Sensor
Class Hierarchy: 04 : 07 : 01
Command Class Base: 00
Command Versions: 20v1 80v1 84v2 85v1 86v1 30v1 71v1 72v1 73v1 59v1 5Av1 5Ev1
Features: routing, battery, beaming, waking
Neighbors: 37, 38, 72
Associations: 1:[1] 2:[] 3:[] 4:[] 5:[]
Config Values: - none -
No manual included but not required!
Taking it apart it runs on 2 AAA batteries (supplied) and the PCB is very small and wiring a switch in place of the 2 reed switches (one on each long side) gives options for zwave projects, I also am considering getting some 240v to 3v power supplies to power them in remote areas like the loft and garage for the garage door opener.
Works well with Raw Commands at present until Matt gets time to add a definition
CliveS
CliveS
Thu Oct 05, 2017 10:26 am
Re: Heiman Z Wave Door/Window Sensor (HS1DS)
Hi Clive,
Can you copy/paste some debug log (via checkbox from Interfaces->Z-Wave->Configure...) snippets showing the commands it sends when open/closed?
Thu Oct 05, 2017 11:27 am
CliveS offline
Matt,
As requested
Z-Wave Debug RCVD requestBinarySensorStatus: 01 0A 00 04 00 94 04 30 03 FF 0A A7
Z-Wave Debug . . requestBinarySensorStatus: node 148, endpoint None, type 10, value 255
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 10 00 04 00 94 0A 71 05 00 00 00 FF 06 16 00 00 EE
Z-Wave Debug . . requestAlarmSensorStatus: node 148, endpoint None, cmdClass 71, type 0, value 0, classSubKey 710000
Z-Wave Debug . . requestAlarmSensorStatus: typeExt 6, valueExt 22, classSubKeyExt 7100000616
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 8F 06 31 05 03 0A 00 6E 2D
Z-Wave Debug . . requestVarSensorStatus: node 143, endpoint None, type 3, raw value 0A00...
Z-Wave Debug . . requestVarSensorStatus: 110 lux (float: 110.000000)
Z-Wave Debug . . requestVarSensorStatus: ignored (no device found for dispatch)
Z-Wave Debug RCVD nodeAwake: 01 08 00 04 00 94 02 84 07 E6
Z-Wave Debug . . nodeAwake: node 148
Z-Wave Debug . . . . . . . : skipping battery check (next check in 717 mins)
Z-Wave Debug SENT goToSleep: 01 09 00 13 94 02 84 08 24 DB 00
Z-Wave Debug RCVD packet: 01 07 00 13 DB 00 00 05 35 (hex)
Z-Wave Debug RCVD requestBinarySensorStatus: 01 0A 00 04 00 94 04 30 03 00 0A 58
Z-Wave Debug . . requestBinarySensorStatus: node 148, endpoint None, type 10, value 0
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 10 00 04 00 94 0A 71 05 00 00 00 FF 06 17 00 00 EF
Z-Wave Debug . . requestAlarmSensorStatus: typeExt 6, valueExt 23, classSubKeyExt 7100000617
Z-Wave Debug SENT goToSleep: 01 09 00 13 94 02 84 08 24 DC 07
Z-Wave Debug RCVD packet: 01 07 00 13 DC 00 00 05 32 (hex)
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 04 0E 32 02 21 34 00 00 00 02 00 00 00 00 00 00 C2
Z-Wave Debug . . requestMeterLevel: node 004, endpoint None, meterType 01, raw value 3400...
Z-Wave Debug . . requestMeterLevel: 0.2 W (float: 0.200000)
Z-Wave Debug SENT goToSleep: 01 09 00 13 94 02 84 08 24 DD 06
Z-Wave Debug RCVD packet: 01 07 00 13 DD 00 00 05 33 (hex)
Z-Wave connection reset requested
Z-Wave connected to Z-Wave 3.95 static controller interface on /dev/cu.usbmodemFA131 (firmware 1.00)
CliveS
CliveS
Mon Oct 09, 2017 10:19 am
aderrington offline
Also interested in this being added as I’ve picked up a couple
Thu Nov 09, 2017 7:33 pm
Indigo 7.1.1 is now available for download and includes support for the Heiman Door/Window Sensor (HS1DS).
