- Posted on
Sat Oct 07, 2017 5:52 am
CliveS
offline
Well I went mad and spent all of £5.99 on this and as I also bought a Heiman Door/Window sensor
http://forums.indigodomo.com/viewtopic.php?f=58&t=19166&p=146300&hilit=heiman#p146300/ at the same time and at present on eBay there is a buy 1 get 1 at 50% off on both items so it was only £2.99.
- Everspring SA413 USB.jpg (14.82 KiB) Viewed 1502 times
This is the log file of the stick and also adding an Aeon Labs Multi Sensor 6 (ZW100).
Hopefully it means that I can use it in place of theAeon Gen5 Stick?
7 Oct 2017, 11:40:29
Starting Indigo Server version 7.0.4 (Mac OS X 10.12.6)
Loading attachments
Loading database "/Library/Application Support/Perceptive Automation/Indigo 7/Databases/Sample House 1.indiDb"
Loading plugin "Action Collection 2.0.4"
Starting plugin "Action Collection 2.0.4" (pid 8155)
Loading interface "Z-Wave 2.0.68"
Starting interface "Z-Wave 2.0.68" (pid 8156)
Loading plugin "Hue Lights 1.3.17"
Starting plugin "Hue Lights 1.3.17" (pid 8157)
Found disabled interface "INSTEON Commands 2.0.10"
Found disabled plugin "Airfoil Pro 1.0.7"
Found disabled plugin "Airfoil 1.1.11"
Found disabled plugin "Dimmer Extender 1.1.1"
Found disabled plugin "DIRECTV DVR Control 1.1.0"
Found disabled plugin "EasyDAQ Relay Card 2.0.3"
Found disabled plugin "Evohome 1.0.7"
Found disabled plugin "Global Property Manager 2.0"
Found disabled plugin "Growl 2.0.2"
Found disabled plugin "iCal Alarm Processor 2.0.1"
Found disabled plugin "iTunes 2.0.4"
Found disabled plugin "NOAA Weather 2.0.1"
Found disabled plugin "SQL Logger 2.0.5"
Found disabled plugin "Timers and Pesters 2.0.2"
Found disabled plugin "Vera Bridge 1.0.8"
Found disabled interface "Virtual Devices 2.0.4"
Found disabled plugin "WeatherSnoop 2.1.2"
Bonjour registered "Indigo - Sample House 1"
Error failed to create reflector connection: reflector not active
Started plugin "Action Collection 2.0.4"
Started plugin "Hue Lights 1.3.17"
Started interface "Z-Wave 2.0.68"
Z-Wave Debug starting serial connection loop
Z-Wave Debug starting zwave packet parser thread
Z-Wave Debug SENT getVersion: 01 03 00 15 E9
Z-Wave Debug RCVD getVersion: 01 10 01 15 5A 2D 57 61 76 65 20 34 2E 32 34 00 01 94
Z-Wave Debug . . getVersion: Z-Wave 4.24 static controller
Z-Wave Debug SENT getHomeID: 01 03 00 20 DC
Z-Wave Debug RCVD getHomeID: 01 08 01 20 E4 D9 59 A4 01 17
Z-Wave Debug . . getHomeID: E4D959A4, nodeID: 001
Z-Wave Debug SENT getInterfaceFeatures: 01 03 00 05 F9
Z-Wave Debug RCVD getInterfaceFeatures: 01 04 01 05 20 DF
Z-Wave Debug . . getInterfaceFeatures: 20
Z-Wave Debug SENT getInterfaceApiCapabilities: 01 03 00 07 FB
Z-Wave Debug RCVD getInterfaceApiCapabilities: 01 2B 01 07 04 24 00 00 00 01 00 01 FE 81 FF 88 CF 1F 00 00 FB 9F 7D A0 67 00 80 80 00 80 86 00 00 00 E8 73 00 00 0E 00 00 60 00 00 07
Z-Wave Debug . . getInterfaceApiCapabilities: supportedFuncIDs: 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18 1C 20 21 22 23 24 27 28 29 2A 2B 2C 2D 41 42 44 45 46 47 48 49 4A 4B 4C 4D 50 51 53 54 55 56 57 5E 60 61 62 63 66 67 78 80 90 92 93 98 B4 B6 B7 B8 B9 BA BD BE BF D2 D3 D4 EE EF
Z-Wave Debug . . getInterfaceApiCapabilities: serialApi 4.36, manufactureId 0000, productType 0001, productId 0001
Z-Wave connected to Generic Controller interface on /dev/cu.usbmodem1411 (firmware 4.36)
Z-Wave Debug SENT forceSUC: 01 05 00 54 01 01 AE
Z-Wave Debug RCVD forceSUC: 01 04 01 54 01 AF
Z-Wave Debug SENT getInitialNodeData: 01 03 00 02 FE
Z-Wave Debug RCVD getInitialNodeData: 01 25 01 02 05 08 1D 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 CD
Z-Wave Debug . . getInitialNodeData: is static update controller
Z-Wave Debug . . getInitialNodeData: [1]
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 01 BB
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 16 01 02 02 01 73
Z-Wave Debug . . getNodeProtocolInfo: node 001, class name: Static Computer Controller
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Static Controller : Static Controller : Static Computer Controller (02 : 02 : 01)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 00
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20
Z-Wave Debug . . getNodeProtocolInfo: encrypt class commands:
Z-Wave Debug . . getNodeProtocolInfo: features: beaming
Z-Wave Debug starting node healing thread
Z-Wave Debug starting node status polling thread
WebServer client connected
WebServer started on port 8176 -- digest authentication enabled
Indigo Cocoa client connected
7 Oct 2017, 11:41:19
Z-Wave Debug stopping node healing thread
Z-Wave Debug stopping node status polling thread
Z-Wave Debug stopped zwave packet parser thread
Z-Wave connection reset requested
Z-Wave Debug RCVD getInterfaceFeatures: 01 04 01 05 30 CF
Z-Wave Debug . . getInterfaceFeatures: 30
7 Oct 2017, 11:42:18
Reloading interface "Z-Wave 2.0.68"
Stopping interface "Z-Wave 2.0.68" (pid 8156)
Z-Wave closed connection to Generic Controller
Stopped interface "Z-Wave 2.0.68"
Starting interface "Z-Wave 2.0.68" (pid 8238)
7 Oct 2017, 11:43:15
Z-Wave Debug intiatingSyncUI (timeout in 1500 seconds)
Error email scan authentication failed
7 Oct 2017, 11:44:10
Z-Wave Debug SENT enterInclusionMode: 01 04 00 4A C1 70
Z-Wave Debug RCVD enterInclusionMode: 06 (ACK)
Z-Wave started controller inclusion mode with encryption
Z-Wave Debug RCVD inclusionMode ready: 01 07 00 4A 01 01 00 00 B2
7 Oct 2017, 11:49:19
Z-Wave Debug RCVD inclusionMode node found: 01 07 00 4A 01 02 00 00 B1
Z-Wave Debug RCVD inclusionMode adding slave node: 01 19 00 4A 01 03 03 12 04 21 01 5E 86 72 59 85 73 71 84 80 30 31 70 7A 5A EF 55
Z-Wave Debug RCVD inclusionMode node respondCmds: 5E 86 72 59 85 73 71 84 80 30 31 70 7A 5A
Z-Wave Debug RCVD inclusionMode node added: 01 07 00 4A 01 05 03 00 B5
Z-Wave Debug SENT exitInclusionMode: 01 04 00 4A 05 B4
Z-Wave Debug RCVD exitInclusionMode: 06 (ACK)
Z-Wave Debug RCVD inclusionMode finished: 01 07 00 4A 01 06 03 00 B6
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 03 B9
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 01 04 21 01 DC
Z-Wave Debug . . getNodeProtocolInfo: node 003, class name: Multilevel Sensor (routing)
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Multilevel Sensor : Multilevel Sensor (routing) (04 : 21 : 01)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 31
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 80 84 85 86 30 70 31 72 73 71 59 7A 5A 5E
Z-Wave Debug . . getNodeProtocolInfo: features: routing, battery, beaming, waking
Z-Wave controller included module: 003 - Multilevel Sensor (routing)
Z-Wave querying module for encryption support
Z-Wave Debug SENT requestSecuritySchemes: 01 0A 00 13 03 03 98 04 00 25 F1 AE
Z-Wave Debug RCVD requestSecuritySchemes: 01 09 00 04 00 03 03 98 05 00 6F
Z-Wave Debug . . requestSecuritySchemes: node 003, schemeIndex 0
Z-Wave starting encryption key exchange with module
Z-Wave Debug SENT nonceRequest: 01 09 00 13 03 02 98 40 25 F2 EB
Z-Wave Debug RCVD nonceReport: node 003, nonce A8 CE 8C 15 67 E8 8B A8
Z-Wave Debug SENT setNetworkSecurityKey: ** ** ** ** (encrypted)
Z-Wave Debug RCVD sensorSetLevel: 01 09 00 04 00 03 03 20 01 FF 2C
Z-Wave Debug . . sensorSetLevel: node 003, endpoint None, cmdClass 20, value 255
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 10 00 04 00 03 0A 71 05 00 00 00 FF 07 08 00 00 66
Z-Wave Debug . . requestAlarmSensorStatus: node 003, endpoint None, cmdClass 71, type 0, value 0, classSubKey 710000
Z-Wave Debug . . requestAlarmSensorStatus: typeExt 7, valueExt 8, classSubKeyExt 7100000708
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 03 06 31 05 01 22 00 CF 2A
Z-Wave Debug . . requestVarSensorStatus: node 003, endpoint None, type 1, raw value 2200...
Z-Wave Debug . . requestVarSensorStatus: 20.7 °C (float: 20.700000)
Z-Wave Debug . . requestVarSensorStatus: ignored (no device found for dispatch)
Z-Wave Debug RCVD requestVarSensorStatus: 01 0B 00 04 00 03 05 31 05 05 01 49 8F
Z-Wave Debug . . requestVarSensorStatus: node 003, endpoint None, type 5, raw value 0149...
Z-Wave Debug . . requestVarSensorStatus: 73% (float: 73.000000)
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 03 06 31 05 03 0A 01 A1 6F
Z-Wave Debug . . requestVarSensorStatus: node 003, endpoint None, type 3, raw value 0A01...
Z-Wave Debug . . requestVarSensorStatus: 417 lux (float: 417.000000)
Z-Wave Debug RCVD requestVarSensorStatus: 01 0B 00 04 00 03 05 31 05 1B 01 00 D8
Z-Wave Debug . . requestVarSensorStatus: node 003, endpoint None, type 27, raw value 0100...
Z-Wave Debug . . requestVarSensorStatus: 0 (float: 0.000000)
7 Oct 2017, 11:50:21
Z-Wave Debug RCVD nodeInfoFrame: 01 18 00 49 84 03 12 04 21 01 5E 86 72 59 85 73 71 84 80 30 31 70 7A 5A EF D1
Z-Wave Debug queueing full request of "003 - Multilevel Sensor (routing)" (activity detected)
Z-Wave Debug ignoring duplicate full request of "003 - Multilevel Sensor (routing)" (activity detected)
Z-Wave stopping controller inclusion mode
Z-Wave Debug RCVD inclusionMode finished: 01 07 00 4A 26 06 03 00 91
Z-Wave stopped controller inclusion mode
Z-Wave Syncing - started for "003 - Multilevel Sensor (routing)"
Z-Wave Debug SENT getNodeNeighbors: 01 06 00 80 03 01 01 7A
Z-Wave Debug RCVD getNodeNeighbors: 01 20 01 80 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5F
Z-Wave Debug . . getNodeNeighbors: nodeId 003, neighbors: 1
Z-Wave Syncing - retrieved module neighbors list: 1
Z-Wave Syncing - assigning return route to "003 - Multilevel Sensor (routing)"
Z-Wave Debug SENT assignReturnRoute: 01 05 00 46 03 01 BE
Z-Wave Debug RCVD assignReturnRoute: 01 04 01 46 01 BD
Z-Wave Debug RCVD assignReturnRoute: 01 05 00 46 01 00 BD
Z-Wave Debug . . assignReturnRoute: node 003, success 1
Z-Wave Debug SENT requestNodeInfo: 01 06 00 60 03 24 F4 4A
Z-Wave Debug . . nodeInfoFrame: node 003, combined class list: 20v1 80v1 84v1 85v1 86v1 30v1 70v1 71v1 72v1 73v1 5Av1 59v1 31v1 7Av1 5Ev1
Z-Wave Debug SENT requestManufactureInfo: 01 09 00 13 03 02 72 04 25 F5 42
Z-Wave Debug RCVD requestManufactureInfo: 01 0E 00 04 00 03 08 72 05 00 86 00 02 00 64 69
Z-Wave Debug . . requestManufactureInfo: node 003, manufacturerId 0086, productId 00020064
Z-Wave Debug overriding node 003 type from zwValueSensorType to zwOnOffSensorType
Z-Wave Debug . . requestManufactureInfo: Aeon Labs, Multi Sensor 6 (ZW100)
Z-Wave Syncing - retrieved manufacture and model names: Aeon Labs - 0086, Multi Sensor 6 (ZW100) - 00020064
Z-Wave Debug SENT requestVersInfoGen: 01 09 00 13 03 02 86 11 25 F6 A0
Z-Wave Debug RCVD requestVersInfoGen: 01 0F 00 04 00 03 09 86 12 03 04 05 01 07 64 00 0A
Z-Wave Debug . . requestVersInfoGen: node 003, protoVers 4.05, appVers 1.07
Z-Wave Syncing - retrieved protocol version 4.05, app version 1.07
Z-Wave Debug SENT requestVersInfoCmdClass: 01 0A 00 13 03 03 86 13 84 25 F7 25
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 0A 00 04 00 03 04 86 14 84 02 E2
Z-Wave Debug . . requestVersInfoCmdClass: node 003, class command 84 using version 2
Z-Wave Debug . . requestVersInfoCmdClass: node 003, combined class list: 20v1 80v1 84v2 85v1 86v1 30v1 70v1 71v1 72v1 73v1 5Av1 59v1 31v1 7Av1 5Ev1
Z-Wave Debug SENT requestVersInfoCmdClass: 01 0A 00 13 03 03 86 13 31 25 F8 9F
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 0A 00 04 00 03 04 86 14 31 05 50
Z-Wave Debug . . requestVersInfoCmdClass: node 003, class command 31 using version 5
Z-Wave Debug . . requestVersInfoCmdClass: node 003, combined class list: 20v1 80v1 84v2 85v1 86v1 30v1 70v1 71v1 72v1 73v1 5Av1 59v1 31v5 7Av1 5Ev1
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Multilevel Sensor : Multilevel Sensor (routing) (04 : 21 : 01, base 31)
Z-Wave Syncing - retrieved command classes: 20v1 80v1 84v2 85v1 86v1 30v1 70v1 71v1 72v1 73v1 5Av1 59v1 31v5 7Av1 5Ev1
Z-Wave Syncing - retrieved capabilities: routing, battery, beaming, waking
Z-Wave Debug SENT requestWakeInterval: 01 09 00 13 03 02 84 05 25 F9 B9
Z-Wave Debug RCVD requestWakeInterval: 01 0C 00 04 00 03 06 84 06 00 0E 10 01 6F
Z-Wave Debug . . requestWakeInterval: node 003, interval 60 minutes, wakeTarget 001
Z-Wave Syncing - retrieved wake interval of 60 minutes
Z-Wave Debug SENT setWakeInterval: 01 0D 00 13 03 06 84 04 00 0E 10 01 25 FA A4
Z-Wave Syncing - device "003 - Multilevel Sensor (routing)" wake interval changed to 60 minutes
Z-Wave Debug SENT requestAssociationGroupCount: 01 09 00 13 03 02 85 05 25 FB BA
Z-Wave Debug RCVD requestAssociationGroupCount: 01 09 00 04 00 03 03 85 06 01 70
Z-Wave Debug . . requestAssociationGroupCount: node 003, group count: 1
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 03 03 85 02 01 25 FC B9
Z-Wave Debug RCVD requestAssociations: 01 0C 00 04 00 03 06 85 03 01 05 00 01 71
Z-Wave Debug . . requestAssociations: node 003, group: 1, num associations: 1, max associations: 5, replies left: 0
Z-Wave Debug . . requestAssociations: node 003, group: 1, associations: [1]
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 03 03 70 05 FC 25 FD B7
Z-Wave Debug RCVD requestConfigVal: 01 0B 00 04 00 03 05 70 06 FC 01 00 7D
Z-Wave Debug . . requestConfigVal: node 003, parm index 252, value 0 (size 1)
Z-Wave Syncing - retrieved parameter 252 "Lock configuration" is false
Z-Wave Debug . . requestConfigVal: node 003, combined config vals: 252:0
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 03 03 70 05 02 25 FE 4A
Z-Wave Debug RCVD requestConfigVal: 01 0B 00 04 00 03 05 70 06 02 01 00 83
Z-Wave Debug . . requestConfigVal: node 003, parm index 2, value 0 (size 1)
Z-Wave Syncing - retrieved parameter 2 "Wake for 10 minutes after battery change" is false
Z-Wave Debug . . requestConfigVal: node 003, combined config vals: 2:0 252:0
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 03 03 70 05 04 25 FF 4D
Z-Wave Debug RCVD requestConfigVal: 01 0B 00 04 00 03 05 70 06 04 01 05 80
Z-Wave Debug . . requestConfigVal: node 003, parm index 4, value 5 (size 1)
Z-Wave Syncing - retrieved parameter 4 "Motion sensing" is 5 "Sensitivity 5 - Maximum"
Z-Wave Debug . . requestConfigVal: node 003, combined config vals: 4:5 2:0 252:0
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 03 03 70 05 03 25 01 B4
Z-Wave Debug RCVD requestConfigVal: 01 0C 00 04 00 03 06 70 06 03 02 00 F0 75
Z-Wave Debug . . requestConfigVal: node 003, parm index 3, value 240 (size 2)
Z-Wave Syncing - retrieved parameter 3 "Off delay" is 240 seconds
Z-Wave Debug . . requestConfigVal: node 003, combined config vals: 4:5 2:0 3:240 252:0
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 03 03 70 05 05 25 02 B1
Z-Wave Debug RCVD requestConfigVal: 01 0B 00 04 00 03 05 70 06 05 01 01 85
Z-Wave Debug . . requestConfigVal: node 003, parm index 5, value 1 (size 1)
Z-Wave Syncing - retrieved parameter 5 "Motion flags" is 1
Z-Wave Debug . . requestConfigVal: node 003, combined config vals: 4:5 2:0 3:240 252:0 5:1
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 03 03 70 05 28 25 03 9D
Z-Wave Debug RCVD requestConfigVal: 01 0B 00 04 00 03 05 70 06 28 01 00 A9
Z-Wave Debug . . requestConfigVal: node 003, parm index 40, value 0 (size 1)
Z-Wave Syncing - retrieved parameter 40 "Enable selective threshold reporting" is false
Z-Wave Debug SENT setConfigVal: 01 0C 00 13 03 05 70 04 28 01 00 25 04 9A
Z-Wave Syncing - device "003 - Multilevel Sensor (routing)" parameter 40 "Enable selective threshold reporting" changed to false
Z-Wave Debug . . pushNewValToNode: node 003, combined config vals: 2:0 3:240 4:5 5:1 40:0 252:0
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 03 03 70 05 6F 25 05 DC
Z-Wave Debug RCVD requestConfigVal: 01 0E 00 04 00 03 08 70 06 6F 04 00 00 0E 10 FD
Z-Wave Debug . . requestConfigVal: node 003, parm index 111, value 3600 (size 4)
Z-Wave Syncing - retrieved parameter 111 "Reporting interval" is 3600 seconds
Z-Wave Debug SENT setConfigVal: 01 0F 00 13 03 08 70 04 6F 04 00 00 07 08 25 06 DB
Z-Wave Syncing - device "003 - Multilevel Sensor (routing)" parameter 111 "Reporting interval" changed to 1800 seconds (was 3600 seconds)
Z-Wave Debug . . pushNewValToNode: node 003, combined config vals: 2:0 3:240 4:5 5:1 40:0 252:0 111:1800
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 03 03 70 05 70 25 07 C1
Z-Wave Debug RCVD requestConfigVal: 01 0E 00 04 00 03 08 70 06 70 04 00 00 0E 10 E2
Z-Wave Debug . . requestConfigVal: node 003, parm index 112, value 3600 (size 4)
Z-Wave Syncing - retrieved parameter 112 "Reporting interval2" is 3600 seconds
Z-Wave Debug SENT setConfigVal: 01 0F 00 13 03 08 70 04 70 04 00 00 07 08 25 08 CA
Z-Wave Syncing - device "003 - Multilevel Sensor (routing)" parameter 112 "Reporting interval2" changed to 1800 seconds (was 3600 seconds)
Z-Wave Debug . . pushNewValToNode: node 003, combined config vals: 112:1800 2:0 3:240 4:5 5:1 40:0 252:0 111:1800
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 03 03 70 05 71 25 09 CE
Z-Wave Debug RCVD requestConfigVal: 01 0E 00 04 00 03 08 70 06 71 04 00 00 0E 10 E3
Z-Wave Debug . . requestConfigVal: node 003, parm index 113, value 3600 (size 4)
Z-Wave Syncing - retrieved parameter 113 "Reporting interval3" is 3600 seconds
Z-Wave Debug SENT setConfigVal: 01 0F 00 13 03 08 70 04 71 04 00 00 07 08 25 0A C9
Z-Wave Syncing - device "003 - Multilevel Sensor (routing)" parameter 113 "Reporting interval3" changed to 1800 seconds (was 3600 seconds)
Z-Wave Debug . . pushNewValToNode: node 003, combined config vals: 112:1800 113:1800 2:0 3:240 4:5 5:1 40:0 252:0 111:1800
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 03 03 70 05 65 25 0B D8
Z-Wave Debug RCVD requestConfigVal: 01 0E 00 04 00 03 08 70 06 65 04 00 00 00 F1 18
Z-Wave Debug . . requestConfigVal: node 003, parm index 101, value 241 (size 4)
Z-Wave Syncing - retrieved parameter 101 "Group 1 flags" is 241
Z-Wave Debug SENT setConfigVal: 01 0F 00 13 03 08 70 04 65 04 00 00 00 F0 25 0C 24
Z-Wave Syncing - device "003 - Multilevel Sensor (routing)" parameter 101 "Group 1 flags" changed to 240 (was 241)
Z-Wave Debug . . pushNewValToNode: node 003, combined config vals: 112:1800 113:1800 2:0 3:240 4:5 5:1 40:0 252:0 101:240 111:1800
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 03 03 70 05 66 25 0D DD
Z-Wave Debug RCVD requestConfigVal: 01 05 00 13 0D 01 E5 (node NAK)
Z-Wave Debug . . requestConfigVal: requeuing 6 unsolicited packets
Z-Wave Debug failed to send requestConfigVal -- retrying
Z-Wave Error Syncing - failed
Z-Wave Error Timeout waiting for "003 - Multilevel Sensor (routing)". Module might be asleep, or is unreachable.
Z-Wave Debug RCVD requestConfigVal: 01 0E 00 04 00 03 08 70 06 66 04 00 00 00 00 EA
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 03 06 31 05 01 22 00 D3 36
Z-Wave Debug . . requestVarSensorStatus: 21.1 °C (float: 21.100000)
Z-Wave Debug RCVD requestVarSensorStatus: 01 0B 00 04 00 03 05 31 05 05 01 47 81
Z-Wave Debug . . requestVarSensorStatus: node 003, endpoint None, type 5, raw value 0147...
Z-Wave Debug . . requestVarSensorStatus: 71% (float: 71.000000)
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 03 06 31 05 03 0A 01 B2 7C
Z-Wave Debug . . requestVarSensorStatus: 434 lux (float: 434.000000)
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 03 03 70 05 66 25 0E DE
Z-Wave Debug . . requestConfigVal: node 003, parm index 102, value 0 (size 4)
Z-Wave retrieved parameter 102 "Group 2 flags" is 0
Z-Wave Debug SENT setConfigVal: 01 0F 00 13 03 08 70 04 66 04 00 00 00 00 25 0F D4
Z-Wave device "003 - Multilevel Sensor (routing)" parameter 102 "Group 2 flags" changed to 0
Z-Wave Debug . . pushNewValToNode: node 003, combined config vals: 2:0 3:240 4:5 5:1 102:0 40:0 111:1800 112:1800 113:1800 252:0 101:240
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 03 06 31 05 01 22 00 D4 31
Z-Wave Debug . . requestVarSensorStatus: 21.2 °C (float: 21.200000)
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 03 06 31 05 03 0A 01 B9 77
Z-Wave Debug . . requestVarSensorStatus: 441 lux (float: 441.000000)
Z-Wave Debug polling status of node "003 - Multilevel Sensor (routing)" (post-activity full request)
Z-Wave Debug SENT requestNodeInfo: 01 06 00 60 03 24 10 AE
Z-Wave Debug SENT requestManufactureInfo: 01 09 00 13 03 02 72 04 25 11 A6
Z-Wave Debug SENT requestVersInfoGen: 01 09 00 13 03 02 86 11 25 12 44
Z-Wave Debug SENT requestVersInfoCmdClass: 01 0A 00 13 03 03 86 13 84 25 13 C1
Z-Wave Debug SENT requestVersInfoCmdClass: 01 0A 00 13 03 03 86 13 31 25 14 73
Z-Wave Debug SENT requestWakeInterval: 01 09 00 13 03 02 84 05 25 15 55
Z-Wave Debug SENT setWakeInterval: 01 0D 00 13 03 06 84 04 00 0E 10 01 25 16 48
Z-Wave Debug SENT requestAssociationGroupCount: 01 09 00 13 03 02 85 05 25 17 56
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 03 03 85 02 01 25 18 5D
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 03 03 70 05 FC 25 19 53
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 03 03 70 05 02 25 1A AE
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 03 03 70 05 04 25 1B A9
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 03 03 70 05 03 25 1C A9
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 03 03 70 05 05 25 1D AE
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 03 03 70 05 28 25 1E 80
Z-Wave Debug . . requestConfigVal: node 003, combined config vals: 2:0 3:240 4:5 5:1 40:0 252:0
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 03 03 70 05 6F 25 1F C6
Z-Wave Debug RCVD requestConfigVal: 01 0E 00 04 00 03 08 70 06 6F 04 00 00 07 08 EC
Z-Wave Debug . . requestConfigVal: node 003, parm index 111, value 1800 (size 4)
Z-Wave Syncing - retrieved parameter 111 "Reporting interval" is 1800 seconds
Z-Wave Debug . . requestConfigVal: node 003, combined config vals: 2:0 3:240 4:5 5:1 40:0 252:0 111:1800
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 03 03 70 05 70 25 20 E6
Z-Wave Debug RCVD requestConfigVal: 01 0E 00 04 00 03 08 70 06 70 04 00 00 07 08 F3
Z-Wave Debug . . requestConfigVal: node 003, parm index 112, value 1800 (size 4)
Z-Wave Syncing - retrieved parameter 112 "Reporting interval2" is 1800 seconds
Z-Wave Debug . . requestConfigVal: node 003, combined config vals: 112:1800 2:0 3:240 4:5 5:1 40:0 252:0 111:1800
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 03 03 70 05 71 25 21 E6
Z-Wave Debug RCVD requestConfigVal: 01 0E 00 04 00 03 08 70 06 71 04 00 00 07 08 F2
Z-Wave Debug . . requestConfigVal: node 003, parm index 113, value 1800 (size 4)
Z-Wave Syncing - retrieved parameter 113 "Reporting interval3" is 1800 seconds
Z-Wave Debug . . requestConfigVal: node 003, combined config vals: 112:1800 113:1800 2:0 3:240 4:5 5:1 40:0 252:0 111:1800
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 03 03 70 05 65 25 22 F1
Z-Wave Debug RCVD requestConfigVal: 01 0E 00 04 00 03 08 70 06 65 04 00 00 00 F0 19
Z-Wave Debug . . requestConfigVal: node 003, parm index 101, value 240 (size 4)
Z-Wave Syncing - retrieved parameter 101 "Group 1 flags" is 240
Z-Wave Debug . . requestConfigVal: node 003, combined config vals: 112:1800 113:1800 2:0 3:240 4:5 5:1 40:0 252:0 101:240 111:1800
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 03 03 70 05 66 25 23 F3
Z-Wave Syncing - retrieved parameter 102 "Group 2 flags" is 0
Z-Wave Debug . . requestConfigVal: node 003, combined config vals: 2:0 3:240 4:5 5:1 102:0 40:0 111:1800 112:1800 113:1800 252:0 101:240
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 03 03 70 05 67 25 24 F5
Z-Wave Debug RCVD requestConfigVal: 01 0E 00 04 00 03 08 70 06 67 04 00 00 00 00 EB
Z-Wave Debug . . requestConfigVal: node 003, parm index 103, value 0 (size 4)
Z-Wave Syncing - retrieved parameter 103 "Group 3 flags" is 0
Z-Wave Debug SENT setConfigVal: 01 0F 00 13 03 08 70 04 67 04 00 00 00 00 25 25 FF
Z-Wave Syncing - device "003 - Multilevel Sensor (routing)" parameter 103 "Group 3 flags" changed to 0
Z-Wave Debug . . pushNewValToNode: node 003, combined config vals: 2:0 3:240 4:5 5:1 102:0 103:0 40:0 111:1800 112:1800 113:1800 252:0 101:240
Z-Wave Debug SENT requestBatteryLevel: 01 09 00 13 03 02 80 02 25 26 65
Z-Wave Debug RCVD requestBatteryLevel: 01 05 00 13 26 01 CE (node NAK)
Z-Wave Debug . . requestBatteryLevel: requeuing 4 unsolicited packets
Z-Wave Debug failed to send requestBatteryLevel -- retrying
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 03 06 31 05 01 22 00 D6 33
Z-Wave Debug . . requestVarSensorStatus: 21.4 °C (float: 21.400000)
Z-Wave Debug RCVD requestVarSensorStatus: 01 0B 00 04 00 03 05 31 05 05 01 46 80
Z-Wave Debug . . requestVarSensorStatus: node 003, endpoint None, type 5, raw value 0146...
Z-Wave Debug . . requestVarSensorStatus: 70% (float: 70.000000)
Z-Wave Debug RCVD requestBatteryLevel: 01 09 00 04 00 03 03 80 03 64 15
Z-Wave Debug . . requestBatteryLevel: node 003, level 100
Z-Wave Debug SENT requestBatteryLevel: 01 09 00 13 03 02 80 02 25 27 64
Z-Wave Debug terminatingSyncUI
7 Oct 2017, 11:51:33
Z-Wave Debug SENT requestNodeInfo: 01 06 00 60 03 24 28 96
Z-Wave Debug SENT requestManufactureInfo: 01 09 00 13 03 02 72 04 25 29 9E
Z-Wave Debug SENT requestVersInfoGen: 01 09 00 13 03 02 86 11 25 2A 7C
Z-Wave Debug SENT requestVersInfoCmdClass: 01 0A 00 13 03 03 86 13 84 25 2B F9
Z-Wave Debug SENT requestVersInfoCmdClass: 01 0A 00 13 03 03 86 13 31 25 2C 4B
Z-Wave Debug SENT requestWakeInterval: 01 09 00 13 03 02 84 05 25 2D 6D
Z-Wave Debug SENT setWakeInterval: 01 0D 00 13 03 06 84 04 00 0E 10 01 25 2E 70
Z-Wave Debug SENT requestAssociationGroupCount: 01 09 00 13 03 02 85 05 25 2F 6E
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 03 03 85 02 01 25 30 75
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 03 03 70 05 FC 25 31 7B
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 03 03 70 05 02 25 32 86
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 03 03 70 05 04 25 33 81
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 03 03 70 05 03 25 34 81
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 03 03 70 05 05 25 35 86
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 03 03 70 05 28 25 36 A8
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 03 03 70 05 6F 25 37 EE
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 03 03 70 05 70 25 38 FE
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 03 03 70 05 71 25 39 FE
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 03 03 70 05 65 25 3A E9
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 03 03 70 05 66 25 3B EB
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 03 03 70 05 67 25 3C ED
Z-Wave Debug . . requestConfigVal: node 003, combined config vals: 2:0 3:240 4:5 5:1 102:0 103:0 40:0 111:1800 112:1800 113:1800 252:0 101:240
Z-Wave Debug SENT requestBatteryLevel: 01 09 00 13 03 02 80 02 25 3D 7E
Z-Wave Syncing - retrieved battery level of 100%
Z-Wave Syncing - created device "003 - Motion Sensor"
Z-Wave Syncing - created device "003 - Tamper"
Z-Wave Syncing - created device "003 - Temperature"
Z-Wave Syncing - created device "003 - Humidity"
Z-Wave Syncing - created device "003 - Luminance"
Z-Wave Syncing - created device "003 - Ultraviolet"
Z-Wave Syncing - complete
Z-Wave Debug ignoring duplicate full request of "003 - Motion Sensor" (activity detected)
Z-Wave Debug polling status of node "003 - Motion Sensor" (post-activity full request)
7 Oct 2017, 11:55:05
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 10 00 04 00 03 0A 71 05 00 00 00 FF 07 03 00 00 6D
Z-Wave Debug . . requestAlarmSensorStatus: typeExt 7, valueExt 3, classSubKeyExt 7100000703
Z-Wave Debug . . requestAlarmSensorStatus: defnStatusByte 255
Z-Wave received "003 - Tamper" status update is on
CliveS
