NEO Coolcam NAS-WR01ZE Z-wave EU Smart Power Plug Socket
Tue Nov 07, 2017 9:11 pm
Re: NEO Coolcam NAS-WR01ZE Z-wave EU Smart Power Plug Socket
Indigo 7.1.1 is now available for download and should prevent the overwriting of the Watts and kWh states.
Great detective work and packet decoding on this guys!
Wed Nov 08, 2017 4:30 am
CliveS offline
Thanks Matt, I can confirm that it now works fine, no spurious readings, is it possible to add a request to your 'Feature Request List' for Amps and Volts reporting especially in the Device Details in the GUI as well please.
CliveS
Tue Nov 14, 2017 8:46 am
mortenkols offline
Is it possible to hide status updates from the log?Image
Tue Nov 14, 2017 9:20 am
CliveS offline
I set the Configuration Parameters
1=0 (Meter Report Set To Disabled)
2=65535 (Meter Report Interval Set To Max Seconds)
6=100 (Meter Report Level =100% change before reporting)
That should shut it up
Full details can be found at https://docs.domeha.com/#configuration-command-class-parameters50 as Dome and Neo are the same internals.
CliveS
Sat Mar 14, 2020 1:28 pm
McJohn offline
Indigo 7.4.1
Z-Wave Error received “Kitchen-lamp” energy total value out-of-bounds -21474835.02 kWh (ignored)
How can we avoid these error messages?
Indigo Z-Wave Version: 7.4.1
Node ID: 101
Model: Power Plug (NAS-WR01ZE)
Model ID: 02001027
Manufacturer: Neo
Manufacturer ID: 0258
Protocol Version: 6.02
Application Version: 2.32
Model Definition Version: 1
Library Type: 3
Class Hierarchy: 04 : 10 : 01
Command Class Base: 25
Command Versions: 20v1 85v1 86v1 27v1 6Cv1 72v1 8Ev1 70v1 71v1 32v4 73v1 55v1 98v1 59v1 5Av1 9Fv1 5Ev1 25v1
Features: routing, beaming, security, energyMeter
Neighbors: 2, 3, 4, 5, 6, 7, 8, 9, 13, 14, 15, 16, 19, 20, 25, 30, 31, 34, 87, 95
Associations: 1:[1] 2:[]
Config Values: 1:1 2:1 3:1 6:0 7:300
Sat Mar 14, 2020 1:40 pm
You cannot. The module is reporting bad data to Indigo so Indigo logs it as such.
Sat Mar 14, 2020 1:50 pm
McJohn offline
Thanks for the fast reply.
It isn't possible to change the Indigo software that it could avoid bad data?
Sat Mar 14, 2020 2:14 pm
No the bad data is coming from the module. Probably a firmware bug. Indigo is just reporting it, and we will not be changing Indigo to not report it.
Sat Mar 14, 2020 2:16 pm
McJohn offline
OK, thanks for the explanation. Then we have to live with that.
Users browsing this forum: Eagleye and 7 guests
