NEO Coolcam NAS-WR01ZE Z-wave EU Smart Power Plug Socket
Sat Sep 09, 2017 5:39 am
CliveS online
UpDate 8 Nov 2017 - As of Indigo v7.1.1 the Neo Power Plug is supported and working without the errors reported below
Yet another Neo product, with EU/UK adapters both ends it sticks out of the wall socket quite a bit but eventually I will buy a EU inline plug and socket, they also do a USA version (just not a UK one!!)
Installed into Indigo first time again, no problems and it can be controlled by Indigo and reports On/Off from the switch on the unit as well.
The only annoying thing is when it is turned on or off it reports a random energy total of about 240 kWh before resetting
9 Sep 2017, 12:25:52
Z-Wave received "123 - Relay Power Switch" status update is off
Z-Wave Watcher Debug Raw command received (Node 123): 01 09 00 04 00 7B 03 25 03 00 AC
Z-Wave received "123 - Relay Power Switch" status update is on
Z-Wave Watcher Debug Raw command received (Node 123): 01 09 00 04 00 7B 03 25 03 FF 53
Z-Wave received "123 - Relay Power Switch" energy total to 0.00 kWh
Z-Wave Watcher Debug Raw command received (Node 123): 01 14 00 04 00 7B 0E 32 02 21 44 00 00 00 00 01 16 00 00 00 00 D8
Z-Wave Watcher Debug Raw command received (Node 123): 01 14 00 04 00 7B 0E 32 02 21 54 00 00 00 00 01 16 00 00 00 00 C8
Z-Wave received "123 - Relay Power Switch" energy total to 241.51 kWh
Z-Wave Watcher Debug Raw command received (Node 123): 01 10 00 04 00 7B 0A 32 02 A1 42 5E 57 01 16 5E 02 0B
Z-Wave Watcher Debug Raw command received (Node 123): 01 10 00 04 00 7B 0A 32 02 A1 4A 00 00 01 16 00 00 56
Z-Wave Watcher Debug Raw command sent (Node 123): 01 0A 00 13 7B 03 32 01 00 25 25 AD (True)
Z-Wave Watcher Debug Raw command sent (Node 123): 01 0A 00 13 7B 03 32 01 10 25 26 BE (True)
Z-Wave Watcher Debug Raw command received (Node 123): 01 14 00 04 00 7B 0E 32 02 21 44 00 00 00 00 00 1B 00 00 00 00 D4
Z-Wave Watcher Debug Raw command received (Node 123): 01 14 00 04 00 7B 0E 32 02 21 54 00 00 00 00 00 1B 00 00 00 00 C4
Z-Wave received "123 - Relay Power Switch" energy total to 240.39 kWh
Z-Wave Watcher Debug Raw command received (Node 123): 01 10 00 04 00 7B 0A 32 02 A1 42 5D E7 00 1B 5E 57 E1
Z-Wave Watcher Debug Raw command received (Node 123): 01 10 00 04 00 7B 0A 32 02 A1 4A 00 00 00 1B 00 00 5A
Z-Wave Watcher Debug Raw command sent (Node 123): 01 0A 00 13 7B 03 32 01 00 25 27 AF (True)
Z-Wave Watcher Debug Raw command sent (Node 123): 01 0A 00 13 7B 03 32 01 10 25 28 B0 (True)
Sync details
9 Sep 2017, 12:33:23
Z-Wave Syncing - started for "Neo NAS-WR01ZE EU Smart Power Plug"
Z-Wave Syncing - retrieved module neighbors list: - none -
Z-Wave Syncing - assigning return route to "123 - Neo NAS-WR01ZE EU Smart Power Plug"
Z-Wave Watcher Debug Raw command sent (Node 123): 01 06 00 60 7B 24 32 F4 (True)
Z-Wave Watcher Debug Raw command sent (Node 123): 01 09 00 13 7B 02 72 04 25 33 FC (True)
Z-Wave Syncing - retrieved manufacture and model names: Neo - 0258, Relay Power Switch - 00031087
Z-Wave Watcher Debug Raw command received (Node 123): 01 0E 00 04 00 7B 08 72 05 02 58 00 03 10 87 3F
Z-Wave Watcher Debug Raw command sent (Node 123): 01 09 00 13 7B 02 86 11 25 34 1A (True)
Z-Wave Syncing - retrieved protocol version 4.05, app version 3.93
Z-Wave Watcher Debug Raw command received (Node 123): 01 0F 00 04 00 7B 09 86 12 03 04 05 03 5D 41 00 0F
Z-Wave Watcher Debug Raw command sent (Node 123): 01 0A 00 13 7B 03 86 13 32 25 35 29 (True)
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Relay Switch : Relay Power Switch (04 : 10 : 01, base 25)
Z-Wave Syncing - retrieved command classes: 20v1 85v1 86v1 27v1 72v1 70v1 71v1 32v4 73v1 59v1 5Av1 5Ev1 25v1
Z-Wave Syncing - retrieved encrypt commands: - none -
Z-Wave Syncing - retrieved capabilities: routing, beaming
Z-Wave Watcher Debug Raw command received (Node 123): 01 0A 00 04 00 7B 04 86 14 32 04 2A
Z-Wave Watcher Debug Raw command sent (Node 123): 01 09 00 13 7B 02 85 05 25 36 0F (True)
Z-Wave Watcher Debug Raw command sent (Node 123): 01 0A 00 13 7B 03 85 02 01 25 37 0A (True)
Z-Wave Syncing - retrieved group 1 associations: [1]
Z-Wave Watcher Debug Raw command received (Node 123): 01 09 00 04 00 7B 03 85 06 03 0A
Z-Wave Watcher Debug Raw command sent (Node 123): 01 0A 00 13 7B 03 85 02 02 25 38 06 (True)
Z-Wave Syncing - retrieved group 2 associations: []
Z-Wave Watcher Debug Raw command received (Node 123): 01 0C 00 04 00 7B 06 85 03 01 05 00 01 09
Z-Wave Watcher Debug Raw command sent (Node 123): 01 0A 00 13 7B 03 85 02 03 25 39 06 (True)
Z-Wave Syncing - retrieved group 3 associations: []
Z-Wave Syncing - group 1 association to interface already exists (skipping)
Z-Wave Watcher Debug Raw command received (Node 123): 01 0B 00 04 00 7B 05 85 03 02 05 00 0F
Z-Wave Watcher Debug Raw command received (Node 123): 01 0B 00 04 00 7B 05 85 03 03 05 00 0E
Z-Wave Watcher Debug Raw command sent (Node 123): 01 09 00 13 7B 02 32 03 25 3A B2 (True)
Z-Wave Watcher Debug Raw command received (Node 123): 01 0A 00 04 00 7B 04 32 04 A1 35 2C
Z-Wave Syncing - complete
Z-Wave Watcher Debug Raw command sent (Node 123): 01 09 00 13 7B 02 25 02 25 3B A5 (True)
Z-Wave sent "Neo NAS-WR01ZE EU Smart Power Plug" status request
Z-Wave sent "Neo NAS-WR01ZE EU Smart Power Plug" energy status request
Z-Wave Watcher Debug Raw command sent (Node 123): 01 0A 00 13 7B 03 32 01 00 25 3C B4 (True)
Z-Wave received "Neo NAS-WR01ZE EU Smart Power Plug" energy total to 0.00 kWh
Z-Wave Watcher Debug Raw command received (Node 123): 01 14 00 04 00 7B 0E 32 02 21 44 00 00 00 00 01 2D 00 00 00 00 E3
Z-Wave Watcher Debug Raw command sent (Node 123): 01 0A 00 13 7B 03 32 01 10 25 3D A5 (True)
Z-Wave Watcher Debug Raw command received (Node 123): 01 14 00 04 00 7B 0E 32 02 21 54 00 00 00 00 01 2D 00 00 00 00 F3
Hopefully enough details for Matt/Jay to add to Indigo
CliveS
CliveS
Sat Sep 09, 2017 2:22 pm
Re: NEO Coolcam NAS-WR01ZE Z-wave EU Smart Power Plug Socket
I'm not sure why it appears the module is sending out the bogus/duplicate kWh message. Adding a device definition to Indigo won't prevent that.
Turn on Indigo's Z-Wave debug logging checkbox via the Interfaces->Z-Wave->Configure menu item, then record the messages again. It will provide more information about how Indigo is decoding the messages for me.
Sat Sep 09, 2017 3:06 pm
CliveS online
The plug has nothing plugged in to it.
Z-Wave sent "Neo NAS-WR01ZE EU Smart Power Plug" on
Z-Wave Debug queueing energy request of "123 - Neo NAS-WR01ZE EU Smart Power Plug" (activity detected)
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 05 0E 32 02 21 34 00 00 12 8C 00 00 00 00 00 00 5F
Z-Wave Debug . . requestMeterLevel: node 005, endpoint None, meterType 01, raw value 3400...
Z-Wave Debug . . requestMeterLevel: 474.8 W (float: 474.800000)
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 7B 0E 32 02 21 44 00 00 00 00 00 12 00 00 00 00 DD
Z-Wave Debug . . requestMeterLevel: node 123, endpoint None, meterType 01, raw value 4400...
Z-Wave Debug . . requestMeterLevel: 0.00 kWh (float: 0.000000)
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 7B 0E 32 02 21 54 00 00 00 00 00 12 00 00 00 00 CD
Z-Wave Debug . . requestMeterLevel: node 123, endpoint None, meterType 01, raw value 5400...
Z-Wave Debug . . requestMeterLevel: 0.00 W (float: 0.000000)
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 7B 0A 32 02 A1 42 5E 6B 00 12 5E 6E 5E
Z-Wave Debug . . requestMeterLevel: node 123, endpoint None, meterType 01, raw value 425E...
Z-Wave Debug . . requestMeterLevel: 241.71 kWh (float: 241.710000)
Z-Wave received "Neo NAS-WR01ZE EU Smart Power Plug" energy total to 241.71 kWh
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 7B 0A 32 02 A1 4A 00 00 00 12 00 00 53
Z-Wave Debug . . requestMeterLevel: node 123, endpoint None, meterType 01, raw value 4A00...
Z-Wave Debug . . requestMeterLevel: 0.00 kVAh (float: 0.000000)
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 05 0E 32 02 21 34 00 00 0D B3 00 00 00 00 00 00 7F
Z-Wave Debug . . requestMeterLevel: 350.7 W (float: 350.700000)
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 49 06 31 05 03 0A 00 00 85
Z-Wave Debug . . requestVarSensorStatus: node 073, endpoint None, type 3, raw value 0A00...
Z-Wave Debug . . requestVarSensorStatus: 0 lux (float: 0.000000)
Z-Wave Debug . . requestVarSensorStatus: ignored (no device found for dispatch)
Z-Wave Debug polling status of node "123 - Neo NAS-WR01ZE EU Smart Power Plug" (post-activity energy request)
Z-Wave Debug SENT requestMeterLevel: 01 0A 00 13 7B 03 32 01 00 25 FF 77
Z-Wave Debug SENT requestMeterLevel: 01 0A 00 13 7B 03 32 01 10 25 01 99
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 05 0E 32 02 21 34 00 00 12 6F 00 00 00 00 00 00 BC
Z-Wave Debug . . requestMeterLevel: 471.9 W (float: 471.900000)
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 04 0E 32 02 21 34 00 00 05 1A 00 00 00 00 00 00 DF
Z-Wave Debug . . requestMeterLevel: node 004, endpoint None, meterType 01, raw value 3400...
Z-Wave Debug . . requestMeterLevel: 130.6 W (float: 130.600000)
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 05 0E 32 02 21 34 00 00 0C 37 00 00 00 00 00 00 FA
Z-Wave Debug . . requestMeterLevel: 312.7 W (float: 312.700000)
Z-Wave Debug RCVD requestMeterLevel: 01 0E 00 04 00 64 08 32 02 21 32 00 A7 00 00 1D
Z-Wave Debug . . requestMeterLevel: node 100, endpoint None, meterType 01, raw value 3200...
Z-Wave Debug . . requestMeterLevel: 16.7 W (float: 16.700000)
Z-Wave Debug SENT setRelayValue: 01 0A 00 13 7B 03 25 01 00 25 02 9D
Z-Wave sent "Neo NAS-WR01ZE EU Smart Power Plug" off
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 05 0E 32 02 21 34 00 00 12 83 00 00 00 00 00 00 50
Z-Wave Debug . . requestMeterLevel: 473.9 W (float: 473.900000)
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 7B 0E 32 02 21 44 00 00 00 00 00 19 00 00 00 00 D6
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 7B 0E 32 02 21 54 00 00 00 00 00 19 00 00 00 00 C6
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 05 0E 32 02 21 34 00 00 0E 44 00 00 00 00 00 00 8B
Z-Wave Debug . . requestMeterLevel: 365.2 W (float: 365.200000)
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 7B 0A 32 02 A1 42 5E A7 00 19 5E 6B 9C
Z-Wave Debug . . requestMeterLevel: 242.31 kWh (float: 242.310000)
Z-Wave received "Neo NAS-WR01ZE EU Smart Power Plug" energy total to 242.31 kWh
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 7B 0A 32 02 A1 4A 00 00 00 19 00 00 58
Z-Wave Debug SENT requestMeterLevel: 01 0A 00 13 7B 03 32 01 00 25 03 8B
Z-Wave Debug SENT requestMeterLevel: 01 0A 00 13 7B 03 32 01 10 25 04 9C
Z-Wave Debug . . requestMeterLevel: requeuing 1 unsolicited packets
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 05 0E 32 02 21 34 00 00 12 8B 00 00 00 00 00 00 58
Z-Wave Debug . . requestMeterLevel: 474.7 W (float: 474.700000)
Z-Wave Debug RCVD requestBinarySensorStatus: 01 0A 00 04 00 63 04 30 03 FF 0C 56
CliveS
CliveS
Sat Sep 09, 2017 3:14 pm
Sorry, I think you'll have to contact their support to ask them. It is definitely sending non-zero W and kWh values to Indigo. I think it must either have a firmware bug, or the one you have is marginal.
Sun Sep 10, 2017 6:01 am
CliveS online
Thanks Matt, time to get the Chinglish dictionary out I think!
Mind you saying that their user manual is very well written and better than some z-wave instructions I have tried to understand and apart from this 'blip' the Neo range have been so easy to include, work well and are solidly built units.
CliveS
CliveS
Sun Sep 24, 2017 12:40 pm
CliveS online
Well I messaged the AliExpress company I bought it from ( Coolcam Official Store ) and without any problems after explaining the power reporting error they just sent me a message saying a replacement is on its way with a new tracking number for me to follow progress.
I was not asked to send back the old one so I will have an inline on/off switch as I have managed to kill the constant power reporting to the log so am well pleased. Highly recommend them as a company and the Neo products, great value compared to Aeotec and Fibaro especially when they have their frequent sales.
Matt, I have all the Neo range manuals with the config parameters, if that is helpful I can email them if required
CliveS
CliveS
Thu Oct 05, 2017 6:43 am
Lucardos offline
hi CliveS,
ordered the EU-plug and unfortunately i see the same results. on/off works fine but a see a total energy around 240kWh and back to zero.
please keep us informed on the new plug they have sent you. Price for the plug is very nice, but only if also the power consumption works.
Lucardos
Thu Oct 05, 2017 8:32 am
CliveS online
The postman has just arrived with the replacement and it does the same as the original so counting yours that makes 3 out of 3 with this problem. Looking around the web no others are having the reset to zero loop so the Neo's are obviously sending a reset to Indigo that other systems are not acting on.
At least I got mine at 50% off (bought one, got one free!!) and it works fine as an on/off switch.
CliveS
CliveS
Mon Oct 09, 2017 9:00 am
Lucardos offline
was in contact with the Chinees supplier of NEO Coolcam.
They are not aware of any software bugs and the switch should work for the power monitoring.
3 out of 3 not working is not a "marginal". So who is right, INDIGO or NEO?
Tue Oct 17, 2017 2:15 pm
As the author of the ZWave Sensor Logger and Watcher plugins, I've just decoded the raw values to check Matt hasn't gone wrong anywhere :twisted: and I'm seeing the same as Indigo is.
What parameter values are set on the units, particularly for parameters 3 and 4?
Tue Oct 17, 2017 3:08 pm
CliveS online
The manual with all the configuration settings can be found at http://adresat.kiev.ua/sites/default/files/neo_coolcam_z_wave_power_plug_manual_eng.pdf
I did try your plugin and the log gave
    17 Oct 2017, 22:05:09
    Reloading plugin "Z-Wave Sensor Logger 1.0.18"
    Stopping plugin "Z-Wave Sensor Logger 1.0.18" (pid 90548)
    Stopped plugin "Z-Wave Sensor Logger 1.0.18"
    Starting plugin "Z-Wave Sensor Logger 1.0.18" (pid 90833)
    Started plugin "Z-Wave Sensor Logger 1.0.18"
    Z-Wave sent "147 - Relay Power Switch" off
    Z-Wave sent "147 - Relay Power Switch" on
    Z-Wave sent "147 - Relay Power Switch" status request
    Z-Wave sent "147 - Relay Power Switch" energy status request
    Z-Wave received "147 - Relay Power Switch" energy total to 249.63 kWh
    Z-Wave Sensor Logger Error Error in plugin execution ReceivedBroadcast:
    File "plugin.py", line 180, in zwaveCommandReceived
    UnboundLocalError: local variable 'stateid' referenced before assignment
CliveS
Tue Oct 17, 2017 3:20 pm
I've already got the manual - I meant what are your parameter values set at.
I've just uploaded .21 which should fix your error but also might cast light onto things; I suspect your device is reporting kVAh somewhere in that lot.
Peter
Tue Oct 17, 2017 3:45 pm
CliveS online
Updated and now error free
My settings are
1 = 1
2 = 300
3 =. 13
4 =. 12
5 =. 1
6 =. 5
7 =. 1
8 =. 0
9 =. 150
10 =. 1
11 =. 0
12 =. 1
CliveS
Tue Oct 17, 2017 3:52 pm
Can you put Sensor Logger in debug and run Action (Zwave Sensor Logger -> Get All Power)?
Tue Oct 17, 2017 4:13 pm
CliveS online
17 Oct 2017, 23:06:18
Z-Wave received "125 - .Kitchen Window Sensor" status update battery level 100%
Z-Wave received "147 - Relay Power Switch" energy total to 0.00 kWh
Z-Wave Sensor Logger Debug -----
Z-Wave Sensor Logger Debug Raw command: 01 14 00 04 00 93 0E 32 02 21 44 00 00 00 00 00 5C 00 00 00 00 7B
Z-Wave Sensor Logger Debug Bitmask: 44, DP: 2, Scale: 0, ByteLength: 4
Z-Wave Sensor Logger Debug Energy Reported: 0.0 kWh
Z-Wave Sensor Logger Debug Raw command: 01 14 00 04 00 93 0E 32 02 21 54 00 00 00 00 00 5C 00 00 00 00 6B
Z-Wave Sensor Logger Debug Bitmask: 54, DP: 2, Scale: 2, ByteLength: 4
Z-Wave Sensor Logger Debug Power Reported: 0.0 w
Z-Wave Sensor Logger Debug Raw command: 01 14 00 04 00 93 0E 32 02 21 44 00 00 00 00 00 02 00 00 00 00 25
Z-Wave Sensor Logger Debug Raw command: 01 14 00 04 00 93 0E 32 02 21 54 00 00 00 00 00 02 00 00 00 00 35
Z-Wave received "147 - Relay Power Switch" energy total to 247.71 kWh
Z-Wave Sensor Logger Debug Incorrect packet size - ignoring
Z-Wave Sensor Logger Debug Raw command: 01 14 00 04 00 93 0E 32 02 21 44 00 00 00 00 00 06 00 00 00 00 21
Z-Wave Sensor Logger Debug Raw command: 01 14 00 04 00 93 0E 32 02 21 54 00 00 00 00 00 06 00 00 00 00 31
17 Oct 2017, 23:06:50
Action Group Neo All
Z-Wave Sensor Logger Debug Node: 147
Z-Wave Sensor Logger Requesting total power levels for node 147
Z-Wave sent "147 - Relay Power Switch" raw command [32 01 10]
Z-Wave Sensor Logger Requesting power level 1 for node 147
Z-Wave Sensor Logger Requesting power level 2 for node 147
Z-Wave Sensor Logger Requesting power level 3 for node 147
Z-Wave Sensor Logger Requesting power level 4 for node 147
Z-Wave Sensor Logger Requesting power level 5 for node 147
Z-Wave Sensor Logger Requesting power level 6 for node 147
Z-Wave Sensor Logger Requesting power level 7 for node 147
Z-Wave Sensor Logger Requesting power level 8 for node 147
Z-Wave Sensor Logger Debug Raw command: 01 14 00 04 00 93 0E 32 02 21 54 00 00 00 00 00 12 00 00 00 00 25
Hope that helps, been told to 'put that computer down and get to bed' so can't send anymore tonight :(
CliveS
