NEO Coolcam NAS-SC01Z Z-wave Wall Light Switch 2CH Gang
Fri Sep 08, 2017 2:49 pm
CliveS offline
My next Neo device has arrived, the 2 ch wall switch, not ideal really for the UK as it needs both live and neutral which most of the UK does not have in the wall but as I have plasterboard walls internally and in a bungalow dropping a neutral down to the switch or replace the cable with 4 core is relatively easy.
To include it I setup for a new z-wave device and clicked the add to network button, plugged in the switch and Indigo just found it without any button being pressed, hit the sync button and it just synced with no errors, all these Neo devices just include and sync first time, the are well built and cheap but definitely not nasty
It almost works but will require a definition file eventually, details already sent to Matt/Jay.
You can turn on and off both switches from Indigo but when you press switch 1 it does not update Indigo but switch 2 does update Indigo's on/off, strange that as I would have expected it to be the other way round but not a deal breaker as raw data will come to the rescue again.
CliveS
CliveS
Sat Sep 09, 2017 2:24 pm
Re: NEO Coolcam NAS-SC01Z Z-wave Wall Light Switch 2CH Gang
Can you copy/paste the sync results and also turn on Indigo's Z-Wave debug logging checkbox via the Interfaces->Z-Wave->Configure menu item, then manually press both switches for me?
Sun Sep 10, 2017 6:44 am
CliveS offline
10 Sep 2017, 13:11:07
Z-Wave Syncing - started for "124 - Relay Switch 1"
Z-Wave Syncing - retrieved module neighbors list: 8, 37, 38, 72, 123
Z-Wave Syncing - assigning return route to "124 - Relay Switch 1"
Z-Wave Syncing - retrieved manufacture and model names: Neo - 0258, Relay Power Switch - 0003108B
Z-Wave Syncing - retrieved protocol version 4.33, app version 2.60
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Relay Switch : Relay Power Switch (04 : 10 : 01, base 25)
Z-Wave Syncing - retrieved command classes: 20v1 60v4 25v1 86v1 27v1 8Ev1 70v1 72v1 73v1 59v1 5Av1 5Ev1 85v1
Z-Wave Syncing - retrieved capabilities: routing, beaming
Z-Wave Syncing - retrieved multi-endpoint types: 1:(10 : 01), 2:(10 : 01)
Z-Wave Syncing - retrieved multi-endpoint classes: 1:[5E 86 8E 25], 2:[5E 86 8E 25]
Z-Wave Syncing - complete
Z-Wave sent "124 - Relay Switch 1" status request
Z-Wave sent "124 - Relay Switch 2" status request
Z-Wave Debug . . requestVarSensorStatus: node 122, endpoint None, type 3, raw value 0A11...
Z-Wave Debug . . requestVarSensorStatus: 4560 lux (float: 4560.000000)
Z-Wave Debug . . requestVarSensorStatus: ignored (no device found for dispatch)
Z-Wave Debug RCVD multiEndPointPacket: 01 0D 00 04 00 7C 07 60 0D 01 00 25 03 FF 38
Z-Wave Debug . . multiEndPointPacket: node 124, endPoint 1
Z-Wave Debug RCVD requestRelayStatus: 01 09 00 04 00 7C 03 25 03 FF FF
Z-Wave Debug . . requestRelayStatus: node 124, endpoint 1, value 255
Z-Wave received "124 - Relay Switch 2" status update is on
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 04 0E 32 02 21 34 00 00 05 1A 00 00 00 00 00 00 DF
Z-Wave Debug . . requestMeterLevel: node 004, endpoint None, meterType 01, raw value 3400...
Z-Wave Debug . . requestMeterLevel: 130.6 W (float: 130.600000)
Z-Wave Debug received "Garage Freezer Power Socket" power load to 130.6 W
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 0F 00 04 00 7A 09 71 05 00 00 00 FF 07 08 00 03
Z-Wave Debug . . requestAlarmSensorStatus: node 122, endpoint None, cmdClass 71, type 0, value 0, classSubKey 710000
Z-Wave Debug . . requestAlarmSensorStatus: typeExt 7, valueExt 8, classSubKeyExt 7100000708
Z-Wave Debug RCVD requestBinarySensorStatus: 01 0A 00 04 00 7A 04 30 03 FF 0C 4F
Z-Wave Debug . . requestBinarySensorStatus: node 122, endpoint None, type 12, value 255
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 49 06 31 05 03 0A 00 6D E8
Z-Wave Debug . . requestVarSensorStatus: node 073, endpoint None, type 3, raw value 0A00...
Z-Wave Debug . . requestVarSensorStatus: 109 lux (float: 109.000000)
Z-Wave Debug received "Kitchen Fibaro 1 - Luminance" sensor update to 109 lux
Z-Wave Debug RCVD multiEndPointPacket: 01 0D 00 04 00 7C 07 60 0D 01 00 25 03 00 C7
Z-Wave Debug RCVD requestRelayStatus: 01 09 00 04 00 7C 03 25 03 00 FF
Z-Wave Debug . . requestRelayStatus: node 124, endpoint 1, value 0
Z-Wave received "124 - Relay Switch 2" status update is off
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 49 06 31 05 03 0A 00 6B EE
Z-Wave Debug . . requestVarSensorStatus: 107 lux (float: 107.000000)
Z-Wave Debug received "Kitchen Fibaro 1 - Luminance" sensor update to 107 lux
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 7A 06 31 05 03 0A 11 04 A3
Z-Wave Debug . . requestVarSensorStatus: 4356 lux (float: 4356.000000)
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 04 0E 32 02 21 34 00 00 05 1B 00 00 00 00 00 00 DE
Z-Wave Debug . . requestMeterLevel: 130.7 W (float: 130.700000)
Z-Wave Debug received "Garage Freezer Power Socket" power load to 130.7 W
Z-Wave Debug RCVD nonceFetch: node 072
Z-Wave Debug SENT nonceReport: 01 11 00 13 48 0A 98 80 A9 27 13 D6 FA 18 8D 8C 25 5C 76
Z-Wave Debug RCVD encryptedPacket: 00 31 05 03 0A 00 68 (decrypted)
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 48 06 31 05 03 0A 00 68 FF
Z-Wave Debug . . requestVarSensorStatus: node 072, endpoint None, type 3, raw value 0A00...
Z-Wave Debug . . requestVarSensorStatus: 104 lux (float: 104.000000)
Z-Wave Debug received "Living Room Aeon 4 - Luminance" sensor update to 104 lux
Z-Wave Debug SENT nonceReport: 01 11 00 13 48 0A 98 80 A9 27 13 D6 FA 18 8D 8C 25 5D 77
Z-Wave Debug RCVD encryptedPacket: 00 31 05 01 22 00 B9 (decrypted)
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 48 06 31 05 01 22 00 B9 FF
Z-Wave Debug . . requestVarSensorStatus: node 072, endpoint None, type 1, raw value 2200...
Z-Wave Debug . . requestVarSensorStatus: 18.5 °C (float: 18.500000)
Z-Wave Debug received "Living Room Aeon 4 - Temperature" sensor update to 18.5 °C
Z-Wave Debug SENT nonceReport: 01 11 00 13 48 0A 98 80 A9 27 13 D6 FA 18 8D 8C 25 5E 74
Z-Wave Debug RCVD encryptedPacket: 00 31 05 05 01 38 00 (decrypted)
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 48 06 31 05 05 01 38 00 FF
Z-Wave Debug . . requestVarSensorStatus: node 072, endpoint None, type 5, raw value 0138...
Z-Wave Debug . . requestVarSensorStatus: 56% (float: 56.000000)
Z-Wave Debug received "Living Room Aeon 4 - Humidity" sensor update to 56%
Z-Wave Debug RCVD multiEndPointPacket: 01 0D 00 04 00 7C 07 60 0D 02 00 25 03 FF 3B
Z-Wave Debug . . multiEndPointPacket: node 124, endPoint 2
Z-Wave Debug . . requestRelayStatus: node 124, endpoint 2, value 255
Z-Wave Debug RCVD multiEndPointPacket: 01 0D 00 04 00 7C 07 60 0D 02 00 25 03 00 C4
Z-Wave Debug . . requestRelayStatus: node 124, endpoint 2, value 0
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 49 06 31 05 03 0A 00 6F EA
Z-Wave Debug . . requestVarSensorStatus: 111 lux (float: 111.000000)
Z-Wave Debug received "Kitchen Fibaro 1 - Luminance" sensor update to 111 lux
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 10 00 04 00 7A 0A 71 05 00 00 00 FF 07 00 01 08 1E
Z-Wave Debug . . requestAlarmSensorStatus: typeExt 7, valueExt 0, classSubKeyExt 7100000700
Z-Wave Debug RCVD requestBinarySensorStatus: 01 0A 00 04 00 7A 04 30 03 00 0C B0
Z-Wave Debug . . requestBinarySensorStatus: node 122, endpoint None, type 12, value 0
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 49 06 31 05 03 0A 00 66 E3
Z-Wave Debug . . requestVarSensorStatus: 102 lux (float: 102.000000)
Z-Wave Debug received "Kitchen Fibaro 1 - Luminance" sensor update to 102 lux
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 7A 06 31 05 03 0A 10 15 B3
Z-Wave Debug . . requestVarSensorStatus: node 122, endpoint None, type 3, raw value 0A10...
Z-Wave Debug . . requestVarSensorStatus: 4117 lux (float: 4117.000000)
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 04 0E 32 02 21 34 00 00 05 0C 00 00 00 00 00 00 C9
Z-Wave Debug . . requestMeterLevel: 129.2 W (float: 129.200000)
Z-Wave Debug received "Garage Freezer Power Socket" power load to 129.2 W
More info at
https://www.google.com/url?q=https%3A%2F%2Fgithub.com%2FOpenZWave%2Fopen-zwave%2Ffiles%2F980008%2FNeo.CoolCam.Z-wave.switch.manual_Optimize.pdf&sa=D&sntz=1&usg=AFQjCNGtzbgdUButJf5zfm4duosL_yPvoA
CliveS
CliveS
Sun Sep 10, 2017 11:53 am
Thanks, we'll add it to our list to get supported.
Thu Nov 09, 2017 7:31 pm
Indigo 7.1.1 is now available for download and includes support for the Neo CoolCam Double Relay Switch (NAS-SC01Z).
Thu Dec 28, 2017 1:41 pm
Colly offline
@CliveS - have you had any issues with your switches yet? On 2 occasions the switch totally lost connection to Indigo and reverted to original settings. The last time I had to re-add it as a new device - just curious if you've had anything similar happen? I will contact the manufacturer now seeing as it's happened a 2nd time.
Thu Dec 28, 2017 2:25 pm
CliveS offline
I must admit I have not used it for several weeks, it was last used to turn a light on in the "server room" (read large wardrobe with sliding doors!) and I needed the light elsewhere so it has been unplugged since then. It never lost track in the time it was working (about 8 weeks) but it did not pass the other half's acceptance test. :)
Not had a problem with any of the Neo kit but Fibaro switches are causing me grief with the lost connection and re-include.
CliveS
Thu Dec 28, 2017 3:01 pm
Colly offline
I'm happy with the other Neo kit too. I'll see what response I get from the manufacturer.
Users browsing this forum: No registered users and 42 guests
