MIMO2 Sensor issue
Mon Aug 14, 2017 3:08 pm
vjf offline
MIMO2 Sensor issue
Having a heck of a time with this one. MIMO2 with four endpoints (two sensor inputs/ two relay outputs). I'd like to use both sensors for low and high water level float switches. I cannot get both sensor inputs to recognize an on/off condition. I've updated the Z-WAVE parameters for this device to immediately trigger instead of waiting for the polling interval. I've also included / excluded and re-sync'd the MIMO2 many times, as well as factory defaulted it and reset the Z-WAVE controller. Sometimes endpoints 1 and 2 get switched around, but I can still only ever get one of the two sensor endpoints to behave correctly.
This is what happens when I close endpoint 1 ( I get 3106, which is basically the upper 8 bits of a 12 bit variable representing the on voltage). This is a good trigger.
Z-Wave Debug RCVD multiEndPointPacket: 01 10 00 04 00 02 0A 60 0D 01 00 31 05 02 0A 0C 22 9D
Z-Wave Debug . . multiEndPointPacket: node 002, endPoint 1
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 02 06 31 05 02 0A 0C 22 FF
Z-Wave Debug . . requestVarSensorStatus: node 002, endpoint 1, type 2, raw value 0A0C...
Z-Wave Debug . . requestVarSensorStatus: 3106 (float: 3106.000000)
Z-Wave received "Lo level sensor" sensor update to 3106
This is what I get with endpoint 2 triggered. MIMO2 seems to send a 3113 status, but it then gets ignored:
Z-Wave Debug RCVD multiEndPointPacket: 01 10 00 04 00 02 0A 60 0D 02 00 31 05 02 0A 0C 29 95
Z-Wave Debug . . multiEndPointPacket: node 002, endPoint 2
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 02 06 31 05 02 0A 0C 29 FF
Z-Wave Debug . . requestVarSensorStatus: node 002, endpoint 2, type 2, raw value 0A0C...
Z-Wave Debug . . requestVarSensorStatus: 3113 (float: 3113.000000)
Z-Wave Debug . . requestVarSensorStatus: ignored (no device found for dispatch)
Any ideas?
Fri Aug 18, 2017 9:07 pm
Re: MIMO2 Sensor issue
Sorry for the slow reply on this one, but I'm looking into it now. I'll post an update in the next day or so.
Can you copy/paste the Event Log results from resynching it? And what version of Indigo are you running?
Sat Aug 19, 2017 10:27 am
vjf offline
Here's the sync debug. I'm running Indigo version 7.0.4.
Thanks Matt.
Z-Wave Debug intiatingSyncUI (timeout in 1500 seconds)
Z-Wave Syncing - started for "Hi level sensor"
Z-Wave Debug SENT getNodeNeighbors: 01 06 00 80 04 01 01 7D
Z-Wave Debug RCVD getNodeNeighbors: 01 20 01 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5E
Z-Wave Debug . . getNodeNeighbors: nodeId 004, neighbors: - none -
Z-Wave Syncing - assigning return route to "004 - Hi level sensor"
Z-Wave Debug SENT assignReturnRoute: 01 05 00 46 04 01 B9
Z-Wave Debug RCVD assignReturnRoute: 01 04 01 46 01 BD
Z-Wave Debug RCVD assignReturnRoute: 01 05 00 46 01 00 BD
Z-Wave Debug . . assignReturnRoute: node 004, success 1
Z-Wave Debug SENT requestNodeInfo: 01 06 00 60 04 24 17 AE
Z-Wave Debug RCVD nodeInfoFrame: 01 17 00 49 84 04 11 04 21 00 5E 86 72 5A 59 71 85 8E 73 25 31 70 60 7A CB
Z-Wave Debug . . nodeInfoFrame: node 004, combined class list: 20v1 60v1 85v1 86v1 71v1 8Ev1 70v1 31v1 72v1 73v1 59v1 5Av1 7Av1 5Ev1 25v1
Z-Wave Debug SENT requestManufactureInfo: 01 09 00 13 04 02 72 04 25 18 A8
Z-Wave Debug RCVD requestManufactureInfo: 01 0E 00 04 00 04 08 72 05 00 84 04 63 02 08 67
Z-Wave Debug . . requestManufactureInfo: node 004, manufacturerId 0084, productId 04630208
Z-Wave Debug . . requestManufactureInfo: FortrezZ, Multilevel Sensor
Z-Wave Syncing - retrieved manufacture and model names: FortrezZ - 0084, Multilevel Sensor - 04630208
Z-Wave Debug SENT requestVersInfoGen: 01 09 00 13 04 02 86 11 25 19 48
Z-Wave Debug RCVD requestVersInfoGen: 01 0F 00 04 00 04 09 86 12 03 04 22 02 08 05 00 47
Z-Wave Debug . . requestVersInfoGen: node 004, protoVers 4.34, appVers 2.08
Z-Wave Syncing - retrieved protocol version 4.34, app version 2.08
Z-Wave Debug SENT requestVersInfoCmdClass: 01 0A 00 13 04 03 86 13 60 25 1A 2B
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 0A 00 04 00 04 04 86 14 60 04 07
Z-Wave Debug . . requestVersInfoCmdClass: node 004, class command 60 using version 4
Z-Wave Debug . . requestVersInfoCmdClass: node 004, combined class list: 20v1 60v4 85v1 86v1 71v1 8Ev1 70v1 31v1 72v1 73v1 59v1 5Av1 7Av1 5Ev1 25v1
Z-Wave Debug SENT requestVersInfoCmdClass: 01 0A 00 13 04 03 86 13 31 25 1B 7B
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 0A 00 04 00 04 04 86 14 31 09 5B
Z-Wave Debug . . requestVersInfoCmdClass: node 004, class command 31 using version 9
Z-Wave Debug . . requestVersInfoCmdClass: node 004, combined class list: 20v1 60v4 85v1 86v1 71v1 8Ev1 70v1 31v9 72v1 73v1 59v1 5Av1 7Av1 5Ev1 25v1
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Multilevel Sensor : -- (04 : 21 : 00, base 31)
Z-Wave Syncing - retrieved command classes: 20v1 60v4 85v1 86v1 71v1 8Ev1 70v1 31v9 72v1 73v1 59v1 5Av1 7Av1 5Ev1 25v1
Z-Wave Syncing - retrieved capabilities: routing, beaming
Z-Wave Debug SENT requestMultiEndPointInfo: 01 09 00 13 04 02 60 07 25 1C BD
Z-Wave Debug RCVD requestMultiEndPointInfo: 01 0B 00 04 00 04 05 60 08 00 04 00 9D
Z-Wave Debug . . requestMultiEndPointInfo: node 004, numEndPoints 4, sameClass False, notStatic False
Z-Wave Debug SENT requestMultiEndPointDetails: 01 0A 00 13 04 03 60 09 01 25 1D B1
Z-Wave Debug RCVD requestMultiEndPointDetails: 01 0F 00 04 00 04 09 60 0A 01 21 00 31 59 85 8E D0
Z-Wave Debug . . requestMultiEndPointDetails: node 004, endPoint 1, notStatic False, class hierarchy 21 : 00
Z-Wave Debug . . requestMultiEndPointDetails: node 004, combined multi-endpoint types: 1:(21 : 00)
Z-Wave Debug . . requestMultiEndPointDetails: node 004, combined multi-endpoint classes: 1:[31 59 85 8E]
Z-Wave Debug SENT requestMultiEndPointDetails: 01 0A 00 13 04 03 60 09 02 25 1E B1
Z-Wave Debug RCVD requestMultiEndPointDetails: 01 0F 00 04 00 04 09 60 0A 02 21 00 31 59 85 8E D3
Z-Wave Debug . . requestMultiEndPointDetails: node 004, endPoint 2, notStatic False, class hierarchy 21 : 00
Z-Wave Debug . . requestMultiEndPointDetails: node 004, combined multi-endpoint types: 1:(21 : 00), 2:(21 : 00)
Z-Wave Debug . . requestMultiEndPointDetails: node 004, combined multi-endpoint classes: 1:[31 59 85 8E], 2:[31 59 85 8E]
Z-Wave Debug SENT requestMultiEndPointDetails: 01 0A 00 13 04 03 60 09 03 25 1F B1
Z-Wave Debug RCVD requestMultiEndPointDetails: 01 0E 00 04 00 04 08 60 0A 03 10 01 25 20 59 DD
Z-Wave Debug . . requestMultiEndPointDetails: node 004, endPoint 3, notStatic False, class hierarchy 10 : 01
Z-Wave Debug . . requestMultiEndPointDetails: node 004, combined multi-endpoint types: 1:(21 : 00), 2:(21 : 00), 3:(10 : 01)
Z-Wave Debug . . requestMultiEndPointDetails: node 004, combined multi-endpoint classes: 1:[31 59 85 8E], 2:[31 59 85 8E], 3:[25 20 59]
Z-Wave Debug SENT requestMultiEndPointDetails: 01 0A 00 13 04 03 60 09 04 25 20 89
Z-Wave Debug RCVD requestMultiEndPointDetails: 01 0E 00 04 00 04 08 60 0A 04 10 01 25 20 59 DA
Z-Wave Debug . . requestMultiEndPointDetails: node 004, endPoint 4, notStatic False, class hierarchy 10 : 01
Z-Wave Debug . . requestMultiEndPointDetails: node 004, combined multi-endpoint types: 1:(21 : 00), 2:(21 : 00), 3:(10 : 01), 4:(10 : 01)
Z-Wave Debug . . requestMultiEndPointDetails: node 004, combined multi-endpoint classes: 1:[31 59 85 8E], 2:[31 59 85 8E], 3:[25 20 59], 4:[25 20 59]
Z-Wave Syncing - retrieved multi-endpoint types: 1:(21 : 00), 2:(21 : 00), 3:(10 : 01), 4:(10 : 01)
Z-Wave Syncing - retrieved multi-endpoint classes: 1:[31 59 85 8E], 2:[31 59 85 8E], 3:[25 20 59], 4:[25 20 59]
Z-Wave Debug SENT requestAssociationGroupCount: 01 09 00 13 04 02 85 05 25 21 67
Z-Wave Debug RCVD requestAssociationGroupCount: 01 09 00 04 00 04 03 85 06 03 75
Z-Wave Debug . . requestAssociationGroupCount: node 004, group count: 3
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 04 03 85 02 01 25 22 60
Z-Wave Debug RCVD requestAssociations: 01 0C 00 04 00 04 06 85 03 01 02 00 01 71
Z-Wave Debug . . requestAssociations: node 004, group: 1, num associations: 1, max associations: 2, replies left: 0
Z-Wave Debug . . requestAssociations: node 004, group: 1, associations: [1]
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 04 03 85 02 02 25 23 62
Z-Wave Debug RCVD requestAssociations: 01 0B 00 04 00 04 05 85 03 02 02 00 77
Z-Wave Debug . . requestAssociations: node 004, group: 2, num associations: 0, max associations: 2, replies left: 0
Z-Wave Debug . . requestAssociations: node 004, group: 2, associations: []
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 04 03 85 02 03 25 24 64
Z-Wave Debug RCVD requestAssociations: 01 0B 00 04 00 04 05 85 03 03 02 00 76
Z-Wave Debug . . requestAssociations: node 004, group: 3, num associations: 0, max associations: 2, replies left: 0
Z-Wave Debug . . requestAssociations: node 004, group: 3, associations: []
Z-Wave Syncing - retrieved group 3 associations: []
Z-Wave Syncing - complete
Z-Wave Debug SENT requestRelayStatus: 01 0D 00 13 04 06 60 0D 01 03 25 02 25 25 AB
Z-Wave Debug terminatingSyncUI
Z-Wave sent "002 - Relay Switch" status request
Z-Wave Debug RCVD multiEndPointPacket: 01 0D 00 04 00 04 07 60 0D 03 01 25 03 00 BC
Z-Wave Debug . . multiEndPointPacket: node 004, endPoint 3
Z-Wave Debug RCVD requestRelayStatus: 01 09 00 04 00 04 03 25 03 00 FF
Z-Wave Debug . . requestRelayStatus: node 004, endpoint 3, value 0
Z-Wave Debug SENT requestVarSensorStatus: 01 0D 00 13 04 06 60 0D 01 02 31 04 25 26 BB
Z-Wave sent "Lo level sensor" status request
Z-Wave Debug RCVD multiEndPointPacket: 01 10 00 04 00 04 0A 60 0D 02 01 31 05 02 0A 0C 28 93
Z-Wave Debug . . multiEndPointPacket: node 004, endPoint 2
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 04 06 31 05 02 0A 0C 28 FF
Z-Wave Debug . . requestVarSensorStatus: node 004, endpoint 2, type 2, raw value 0A0C...
Z-Wave Debug . . requestVarSensorStatus: 3112 (float: 3112.000000)
Z-Wave received "Lo level sensor" sensor update to 3112
Z-Wave Debug SENT requestRelayStatus: 01 0D 00 13 04 06 60 0D 01 03 25 02 25 27 A9
Z-Wave Debug SENT requestRelayStatus: 01 0D 00 13 04 06 60 0D 01 04 25 02 25 28 A1
Z-Wave sent "002 - Relay Switch 2" status request
Z-Wave Debug RCVD multiEndPointPacket: 01 0D 00 04 00 04 07 60 0D 04 01 25 03 00 BB
Z-Wave Debug . . multiEndPointPacket: node 004, endPoint 4
Z-Wave Debug . . requestRelayStatus: node 004, endpoint 4, value 0
Sat Sep 23, 2017 9:11 pm
I've added beta support for this version of the MIMO2 to this download. Download and double-click it to install it, then re-sync your MIMO2 module. Does it then work correctly?
Tue Nov 07, 2017 1:10 pm
vjf offline
Sorry for the slow response on this. My system is in a remote location, and I had the MIMO2 disconnected. I am happy to report that everything looks to be working as expected. It also looks like version 7.1 has native support for it. I appreciate the support.
Tue Nov 07, 2017 2:07 pm
Great. Thanks for the follow-up post.
Thu Nov 09, 2017 7:19 pm
Indigo 7.1.1 is now available for download and includes support for the MIMO2.
Users browsing this forum: No registered users and 27 guests
