For reference the buttons are numbered as follows:
- O
- You will probably want to use Gateway Mode as this will let you pass all button presses to Indigo to be used to control scenes
- Next, you need to include the remote on your controller
- Put Indigo into Inclusion mode
Push buttons 2 & 3 for 1 second: The LED will glow pink - Within 10 seconds, press button 2: the LED will blink
- Your remote should now be included. Next, you need to synch it
- Press buttons 1 & 2 for 2 seconds, then release them and press button three
- Click the Synch button in Indigo
- You should be done. Try pressing buttons on the remote and look for messages in the Indigo Events log.
I am not 100% sure about creating scenes. I just created triggers to watch for the button presses and assigned appropriate actions. YOUR MILEAGE MAY VARY!
EDIT: BTW, I should note this device replaced a Popp/Düwi 05443 and there is no comparison between the two. The nodon is far superior in every respect. One small problem though, every time I see the word nodon, I get an urge for Japanese noodles.
