- Posted on
Tue Aug 08, 2017 6:50 pm
dejees
offline
When I select write device details to event log here is the output...
Z-Wave Indigo Device "018 - Notification Sensor" Z-Wave Properties:
Indigo Z-Wave Version: 2.0.68
Node ID: 18
Model: Notification Sensor
Model ID: 00040002
Manufacturer: Ecolink
Manufacturer ID: 014A
Protocol Version: 4.05
Application Version: 10.01
Model Definition Version: 0
Library Type: 6
Class Name: Notification Sensor
Class Hierarchy: 04 : 07 : 01
Command Class Base: 00
Command Versions: 20v1 80v1 84v2 85v1 86v1 30v1 70v1 71v1 72v1 73v1 59v1 5Ev1
Features: routing, battery, beaming, waking
Neighbors: 1, 2, 3, 4, 6, 7, 8, 9, 10, 13, 14
Associations: 1:[1] 2:[]
Config Values: - none -
Here is the output when Z-Wave debug is turned on and I trigger the sensor...
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 11 00 04 00 12 0B 71 05 00 00 00 FF 06 17 00 00 00 69
Z-Wave Debug . . requestAlarmSensorStatus: node 018, endpoint None, cmdClass 71, type 0, value 0, classSubKey 710000
Z-Wave Debug . . requestAlarmSensorStatus: typeExt 6, valueExt 23, classSubKeyExt 7100000617
Z-Wave Debug RCVD requestBinarySensorStatus: 01 0A 00 04 00 12 04 30 03 00 FF 2B
Z-Wave Debug . . requestBinarySensorStatus: node 018, endpoint None, type 255, value 0
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 11 00 04 00 12 0B 71 05 00 00 00 FF 06 16 00 00 00 68
Z-Wave Debug . . requestAlarmSensorStatus: typeExt 6, valueExt 22, classSubKeyExt 7100000616
Z-Wave Debug RCVD requestBinarySensorStatus: 01 0A 00 04 00 12 04 30 03 FF FF D4
Z-Wave Debug . . requestBinarySensorStatus: node 018, endpoint None, type 255, value 255
Configure screen image in attachment
- Configure_On_Off_Sensor_Module.png (82.35 KiB) Viewed 1848 times
