I use USBAnywhere devices at work which do the same as VirtualHere.
Probably got 5 or 6 in total though only 2 are currently in use due to change of systems.
berkinet wrote:The RESTful API would work too, but I am not sure if that is supported in the basic license.
jay (support) wrote:In any event, there is only 1 license level as of Indigo 7 (no more Lite) and we only sell Indigo 7 licenses.
berkinet wrote:For anything else you'd seriously need to have your head examined if you even thought of using it.
berkinet wrote:Has anyone tried using the Z-Stick on something like a Pi with software like [url=https://www.virtualhere.com VirtualHere[/url]? That would give the ability to optimize the Z-Stick's location regardless on the Indigo server's location.
jay (support) wrote:The code in the plugin that populates usage data is commented out. I can't remember exactly why, but I believe it's because the library used as the basis for the plugin didn't handle it correctly (but I could be misremembering).
The source is available in case someone wants to try it out - uncomment lines 126-128, 140-142, and 317-320 in the plugin.py file. I think you'd need to recreate any devices to have the changes picked up.
It might work, but it also might not.
berkinet wrote:Well, I guess it could work. I uncommented the lines you noted and do not see the usage data.
berkinet wrote:And a question. When I first looked at my installed plugin I found plugin.so and veralib.si i instead of the expected plugin.py and veralib.py (and *.pyc). After downloading, patching and reinstalling, it looks as expected. Any idea what was going on?
jay (support) wrote:...Did you recreate the device as I mentioned above? I think the only time it sets the appropriate properties is when it creates the device (though, again, I could be wrong -....
