Aeotec Recessed Door Sensor (ZW089)
Sat Jul 15, 2017 9:06 pm
kwijibo007 offline
Hi Guys,
This is the AU/NZ Aeotec Recessed Door Sensor (ZW089). It's missing device definitions. Would you mind adding it to a future Indigo release?
controller included module: 013 - Notification Sensor
   Z-Wave                          stopped controller inclusion mode
   Z-Wave                          Syncing - started for "013 - Notification Sensor"
   Z-Wave                          Syncing - retrieved module neighbors list: 3, 5, 6, 7, 8, 9, 10, 12
   Z-Wave                          Syncing - assigning return route to "013 - Notification Sensor"
   Z-Wave                          Syncing - retrieved manufacture and model names: Aeon Labs - 0086, Notification Sensor - 02020059
   Z-Wave                          Syncing - retrieved protocol version 3.92, app version 1.13
   Z-Wave                          Syncing - retrieved class hierarchy: Routing Slave : Notification Sensor : Notification Sensor (04 : 07 : 01, base 00)
   Z-Wave                          Syncing - retrieved command classes: 20v1 80v1 84v2 85v1 86v1 30v1 70v1 71v1 72v1 73v1 98v1 59v1 7Av1 5Ev1
   Z-Wave                          Syncing - retrieved encrypt commands: - none -
   Z-Wave                          Syncing - retrieved capabilities: routing, battery, beaming, security, waking
   Z-Wave                          Syncing - retrieved wake interval of 0 minutes
   Z-Wave                          Syncing - device "013 - Notification Sensor" wake interval changed to 60 minutes
   Z-Wave                          Syncing - retrieved group 1 associations: [1]
   Z-Wave                          Syncing - retrieved group 2 associations: []
   Z-Wave                          Syncing - group 1 association to interface already exists (skipping)
   Z-Wave                          Syncing - retrieved battery level of 100%
   Z-Wave                          Syncing - created device "013 - Notification Sensor"
   Z-Wave                          sent "013 - Notification Sensor" status request
   Z-Wave                          received "013 - Notification Sensor" status update battery level 100%
I submitted it to the web form too.
Pete
Sat Jul 15, 2017 10:05 pm
Re: Aeotec Recessed Door Sensor (ZW089)
Hi Pete,
Yes, that gives us the info we need. We'll get it added.
Sun Jul 16, 2017 3:32 am
kwijibo007 offline
Cheers, Matt
Thu Nov 09, 2017 11:24 am
Indigo 7.1.1 is now available for download and supports the Aeotec ZW089.
Mon Apr 23, 2018 4:24 am
siclark offline
Has anyone had trouble getting this to work? It's paired and synced after few goes but then does nothing. Doesn't respond to magnet and doesn't get updates when polled hourly.
Tried unpairing and factory resets but no luck.
Mon Apr 23, 2018 4:43 am
Happened to have one in stock :wink:
I have just added it (non-encrypted) and sync'd it OK. :)
The Device details are:
Indigo Device "Door Sensor" Z-Wave Properties:
Indigo Z-Wave Version: 2.0.116
Node ID: 148
Model: Recessed Door Sensor (ZW089)
Model ID: 00020059
Manufacturer: Aeon Labs
Manufacturer ID: 0086
Protocol Version: 3.92
Application Version: 1.13
Model Definition Version: 1
Library Type: 3
Class Name: Notification Sensor
Class Hierarchy: 04 : 07 : 01
Command Class Base: 00
Command Versions: 20v1 80v1 84v2 85v1 86v1 30v1 70v1 71v1 72v1 73v1 98v1 59v1 7Av1 5Ev1
Features: routing, battery, beaming, security, waking
Neighbors: 4, 6, 9, 14, 17, 21, 22, 23, 24, 25, 43, 44, 52, 99, 121, 141, 142, 143, 144, 146, 147
Associations: 1:[1] 2:[]
Config Values: - none -
It is responding to the magnet as I would expect. :)
Mon Apr 23, 2018 6:26 am
Note it won't respond to polling/status requests since it is battery operated and sleeps.
Mon Apr 23, 2018 8:00 am
siclark offline
Thought it would at least wake once an hour to receive updates and send battery status?. It's not doing that and doesn't respond to door magnet either.
Mon Apr 23, 2018 8:01 am
siclark offline
Node ID: 148
Model ID: 00020059
Library Type: 3
Haha. Perfect. How did you add and sync? In one go from indigo? I could never get it to UK include unless I removed the zstick and did it on there.
Mon Apr 23, 2018 8:07 am
I am using a Z-Stick Gen 5 and did it via the Indigo add new device menu and embedded Define & Sync i.e. didn't unplug Z-Stick.
What device details does your device show?
Does the red light flash on the device when you move the magnet?
Mon Apr 23, 2018 10:45 am
siclark offline
Yes the red light flashes and the details show exactly the same as you.
Think I've found one problem though. The Comm Enabled box was unticked. Not sure when that happened so that's probably been causing some issues.
It's just about the only complaint I have with Indigo so can't complain too much.
I've enabled and will so how this works now
Tue Apr 24, 2018 12:45 am
siclark offline
No joy. It's unpaired and won't pair when using indigo new device option, even if sitting next to the Mac.
Will give it another go tonight using the zstick to pair.
Tue Apr 24, 2018 1:27 pm
siclark offline
Ok. Much testing later and I've found there problem. It only communicates if it's within a few cm of the z-stick (1" for those using old money)
When that close it immediately sees the sensor changing state. However if I move it further away, only 10cm then it doesn't communicate. I have zwave watcher on it and nothing happens. Move it closer and it works.
Battery is saying 100% so I'm at a loss to the problem.
Tue Apr 24, 2018 2:00 pm
It might be worth checking the battery with a voltmeter.
Have you include it in encrypted mode, if so might be with trying unencrypted.
Are you using a Gen 5 Z-Stick?
Final suggestion is a factory reset and start from square one. :)
Of course, it could be a dodgy device? :|
Tue Apr 24, 2018 2:44 pm
siclark offline
It's a 3v 800mah battery and does 2.8v when the device is powered so seems ok.
Might try a new battery just to test otherwise back to Aeotec.
