Temperature from Fibaro Door / Window ZW+ sensor FGK-10x
Fri Jul 14, 2017 2:03 pm
jasonstn_21 offline
I am using the latest version of Indigo 7.0.3
I have a Fibaro FGK-101 (as per the box) Door Window Sensor with a DS18B20 temperature probe attached (wiring confirmed correct).
I have added the device to my Z-Stick and then Sync'd it in Indigo. It gets added as a FGK-10X device. I can see the open and close status. I have removed it, readded it, resync'd numerous times
But, I can't see the temperature!!
At some level it must be working because I occasionally see this in the log:
Jul 14, 2017, 11:28:22 AM
   Z-Wave Debug                    RCVD requestVarSensorStatus: 01 0C 00 04 00 03 06 31 05 01 42 08 F5 78
   Z-Wave Debug                    . .  requestVarSensorStatus: node 003, endpoint None, type 1, raw value 4208...
   Z-Wave Debug                    . .  requestVarSensorStatus: 22.93 °C (float: 22.930000)
   Z-Wave Debug                    . .  requestVarSensorStatus: ignored (no device found for dispatch)
Below are some details from the log. Thanks for your help!
Device details:
ul 14, 2017, 1:01:07 PM
   Z-Wave Debug                    intiatingSyncUI (timeout in 1500 seconds)
   Z-Wave Debug                    terminatingSyncUI
   Z-Wave                          Indigo Device "x - Pool Temp" Z-Wave Properties:
Indigo Z-Wave Version: 2.0.68
Node ID: 3
Model: Door/Window Sensor (FGK10x)
Model ID: 07012001
Manufacturer: Fibaro System
Manufacturer ID: 010F
Protocol Version: 4.05
Application Version: 3.02
Model Definition Version: 5
Library Type: 3
Class Name: Notification Sensor
Class Hierarchy: 04 : 07 : 01
Command Class Base: 00
Command Versions: 20v1 80v1 22v1 84v2 85v1 86v1 71v1 70v1 2Bv1 8Ev1 30v1 31v5 72v1 73v1 56v1 98v1 59v1 5Av1 9Cv1 7Av1 5Ev1
Features: routing, battery, beaming, security, waking
Neighbors: - none -
Associations: 1:[1] 2:[1] 3:[1] 4:[] 5:[]
Config Values: 1:0 2:0 3:6 12:0
The Initial Sync:
Jul 14, 2017, 11:23:02 AM
   Z-Wave Debug                    SENT enterInclusionMode: 01 04 00 4A C1 70
   Z-Wave Debug                    RCVD enterInclusionMode: 06 (ACK)
   Z-Wave                          started controller inclusion mode
   Z-Wave Debug                    RCVD inclusionMode ready: 01 07 00 4A 02 01 00 00 B1
   Z-Wave Debug                    RCVD inclusionMode node found: 01 07 00 4A 02 02 00 00 B2
   Z-Wave Debug                    RCVD inclusionMode adding slave node: 01 1F 00 4A 02 03 03 18 04 07 01 5E 85 59 22 20 80 70 56 5A 7A 72 8E 71 73 98 2B 9C 30 31 86 84 66
   Z-Wave Debug                    RCVD inclusionMode node respondCmds: 5E 85 59 22 20 80 70 56 5A 7A 72 8E 71 73 98 2B 9C 30 31 86 84
   Z-Wave Debug                    RCVD inclusionMode node added: 01 07 00 4A 02 05 03 00 B6
   Z-Wave Debug                    SENT exitInclusionMode: 01 04 00 4A 05 B4
   Z-Wave Debug                    RCVD exitInclusionMode: 06 (ACK)
   Z-Wave Debug                    RCVD inclusionMode finished: 01 07 00 4A 02 06 03 00 B5
   Z-Wave Debug                    SENT getNodeProtocolInfo: 01 04 00 41 03 B9
   Z-Wave Debug                    RCVD getNodeProtocolInfo: 01 09 01 41 53 9C 01 04 07 01 7A
   Z-Wave Debug                    . .  getNodeProtocolInfo:       node 003, class name: Notification Sensor
   Z-Wave Debug                    . .  getNodeProtocolInfo:            class hierarchy: Routing Slave : Notification Sensor : Notification Sensor (04 : 07 : 01)
   Z-Wave Debug                    . .  getNodeProtocolInfo:         base class command: 00
   Z-Wave Debug                    . .  getNodeProtocolInfo:   supported class commands: 20 80 22 84 85 86 71 70 2B 8E 30 31 72 73 56 98 59 5A 9C 7A 5E
   Z-Wave Debug                    . .  getNodeProtocolInfo:     encrypt class commands:
   Z-Wave Debug                    . .  getNodeProtocolInfo:                   features: routing, battery, beaming, security, waking
   Z-Wave                          controller included module: 003 - Notification Sensor
   Z-Wave                          stopped controller inclusion mode
   Z-Wave                          Syncing - started for "003 - Notification Sensor"
   Z-Wave Debug                    SENT getNodeNeighbors: 01 06 00 80 03 01 01 7A
   Z-Wave Debug                    RCVD getNodeNeighbors: 01 20 01 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5E
   Z-Wave Debug                    . .  getNodeNeighbors: nodeId 003, neighbors: - none -
   Z-Wave                          Syncing - retrieved module neighbors list: - none -
   Z-Wave                          Syncing - assigning return route to "003 - Notification Sensor"
   Z-Wave Debug                    SENT assignReturnRoute: 01 05 00 46 03 01 BE
   Z-Wave Debug                    RCVD assignReturnRoute: 01 04 01 46 01 BD
   Z-Wave Debug                    RCVD assignReturnRoute: 01 05 00 46 01 00 BD
   Z-Wave Debug                    . .  assignReturnRoute: node 003, success 1
   Z-Wave Debug                    SENT requestNodeInfo: 01 06 00 60 03 24 AA 14
   Z-Wave Debug                    RCVD nodeInfoFrame: 01 1E 00 49 84 03 18 04 07 01 5E 85 59 22 20 80 70 56 5A 7A 72 8E 71 73 98 2B 9C 30 31 86 84 E1
   Z-Wave Debug                    . .  nodeInfoFrame: node 003, combined class list: 80v1 84v1 85v1 86v1 8Ev1 56v1 98v1 59v1 5Av1 9Cv1 5Ev1 20v1 70v1 22v1 71v1 2Bv1 30v1 31v1 72v1 73v1 7Av1
   Z-Wave Debug                    SENT requestManufactureInfo: 01 09 00 13 03 02 72 04 25 AB 1C
   Z-Wave Debug                    RCVD requestManufactureInfo: 01 0E 00 04 00 03 08 72 05 01 0F 07 01 20 01 A0
   Z-Wave Debug                    . .  requestManufactureInfo: node 003, manufacturerId 010F, productId 07012001
   Z-Wave Debug                    . .  requestManufactureInfo: Fibaro System, Door/Window Sensor (FGK10x)
   Z-Wave                          Syncing - retrieved manufacture and model names: Fibaro System - 010F, Door/Window Sensor (FGK10x) - 07012001
   Z-Wave Debug                    SENT requestVersInfoGen: 01 09 00 13 03 02 86 11 25 AC FA
   Z-Wave Debug                    RCVD requestVersInfoGen: 01 0F 00 04 00 03 09 86 12 03 04 05 03 02 01 00 68
   Z-Wave Debug                    . .  requestVersInfoGen: node 003, protoVers 4.05, appVers 3.02
   Z-Wave                          Syncing - retrieved protocol version 4.05, app version 3.02
   Z-Wave Debug                    SENT requestVersInfoCmdClass: 01 0A 00 13 03 03 86 13 84 25 AD 7F
   Z-Wave Debug                    RCVD requestVersInfoCmdClass: 01 0A 00 04 00 03 04 86 14 84 02 E2
   Z-Wave Debug                    . .  requestVersInfoCmdClass: node 003, class command 84 using version 2
   Z-Wave Debug                    . .  requestVersInfoCmdClass: node 003, combined class list: 80v1 84v2 85v1 86v1 8Ev1 56v1 98v1 59v1 5Av1 9Cv1 5Ev1 20v1 70v1 22v1 71v1 2Bv1 30v1 31v1 72v1 73v1 7Av1
   Z-Wave Debug                    SENT requestVersInfoCmdClass: 01 0A 00 13 03 03 86 13 31 25 AE C9
   Z-Wave Debug                    RCVD requestVersInfoCmdClass: 01 0A 00 04 00 03 04 86 14 31 05 50
   Z-Wave Debug                    . .  requestVersInfoCmdClass: node 003, class command 31 using version 5
   Z-Wave Debug                    . .  requestVersInfoCmdClass: node 003, combined class list: 80v1 84v2 85v1 86v1 8Ev1 56v1 98v1 59v1 5Av1 9Cv1 5Ev1 20v1 70v1 22v1 71v1 2Bv1 30v1 31v5 72v1 73v1 7Av1
   Z-Wave                          Syncing - retrieved class hierarchy: Routing Slave : Notification Sensor : Notification Sensor (04 : 07 : 01, base 00)
   Z-Wave                          Syncing - retrieved command classes: 80v1 84v2 85v1 86v1 8Ev1 56v1 98v1 59v1 5Av1 9Cv1 5Ev1 20v1 70v1 22v1 71v1 2Bv1 30v1 31v5 72v1 73v1 7Av1
   Z-Wave                          Syncing - retrieved encrypt commands: - none -
   Z-Wave                          Syncing - retrieved capabilities: routing, battery, beaming, security, waking
   Z-Wave Debug                    SENT requestWakeInterval: 01 09 00 13 03 02 84 05 25 AF EF
   Z-Wave Debug                    RCVD requestWakeInterval: 01 0C 00 04 00 03 06 84 06 00 54 60 FF BB
   Z-Wave Debug                    . .  requestWakeInterval: node 003, interval 360 minutes, wakeTarget 255
   Z-Wave                          Syncing - retrieved wake interval of 360 minutes
   Z-Wave Debug                    SENT setWakeInterval: 01 0D 00 13 03 06 84 04 00 0E 10 01 25 B0 EE
   Z-Wave                          Syncing - device "003 - Notification Sensor" wake interval changed to 60 minutes
   Z-Wave Debug                    SENT requestAssociationGroupCount: 01 09 00 13 03 02 85 05 25 B1 F0
   Z-Wave Debug                    RCVD requestAssociationGroupCount: 01 09 00 04 00 03 03 85 06 05 74
   Z-Wave Debug                    . .  requestAssociationGroupCount: node 003, group count: 5
   Z-Wave Debug                    SENT requestAssociations: 01 0A 00 13 03 03 85 02 01 25 B2 F7
   Z-Wave Debug                    RCVD requestAssociations: 01 0B 00 04 00 03 05 85 03 01 01 00 70
   Z-Wave Debug                    . .  requestAssociations: node 003, group: 1, num associations: 0, max associations: 1, replies left: 0
   Z-Wave Debug                    . .  requestAssociations: node 003, group: 1, associations: []
   Z-Wave                          Syncing - retrieved group 1 associations: []
   Z-Wave Debug                    SENT requestAssociations: 01 0A 00 13 03 03 85 02 02 25 B3 F5
   Z-Wave Debug                    RCVD requestAssociations: 01 0B 00 04 00 03 05 85 03 02 05 00 77
   Z-Wave Debug                    . .  requestAssociations: node 003, group: 2, num associations: 0, max associations: 5, replies left: 0
   Z-Wave Debug                    . .  requestAssociations: node 003, group: 2, associations: []
   Z-Wave                          Syncing - retrieved group 2 associations: []
   Z-Wave Debug                    SENT requestAssociations: 01 0A 00 13 03 03 85 02 03 25 B4 F3
   Z-Wave Debug                    RCVD requestAssociations: 01 0B 00 04 00 03 05 85 03 03 05 00 76
   Z-Wave Debug                    . .  requestAssociations: node 003, group: 3, num associations: 0, max associations: 5, replies left: 0
   Z-Wave Debug                    . .  requestAssociations: node 003, group: 3, associations: []
   Z-Wave                          Syncing - retrieved group 3 associations: []
   Z-Wave Debug                    SENT requestAssociations: 01 0A 00 13 03 03 85 02 04 25 B5 F5
   Z-Wave Debug                    RCVD requestAssociations: 01 0B 00 04 00 03 05 85 03 04 05 00 71
   Z-Wave Debug                    . .  requestAssociations: node 003, group: 4, num associations: 0, max associations: 5, replies left: 0
   Z-Wave Debug                    . .  requestAssociations: node 003, group: 4, associations: []
   Z-Wave                          Syncing - retrieved group 4 associations: []
   Z-Wave Debug                    SENT requestAssociations: 01 0A 00 13 03 03 85 02 05 25 B6 F7
   Z-Wave Debug                    RCVD requestAssociations: 01 0B 00 04 00 03 05 85 03 05 05 00 70
   Z-Wave Debug                    . .  requestAssociations: node 003, group: 5, num associations: 0, max associations: 5, replies left: 0
   Z-Wave Debug                    . .  requestAssociations: node 003, group: 5, associations: []
   Z-Wave                          Syncing - retrieved group 5 associations: []
   Z-Wave Debug                    SENT addInterfaceAssociation: 01 0B 00 13 03 04 85 01 01 01 25 B7 F6
   Z-Wave                          Syncing - added group 1 association to interface
   Z-Wave Debug                    . .  addInterfaceAssociation: node 003, group: 1, associations: [1]
   Z-Wave Debug                    SENT addInterfaceAssociation: 01 0B 00 13 03 04 85 01 02 01 25 B8 FA
   Z-Wave                          Syncing - added group 2 association to interface
   Z-Wave Debug                    . .  addInterfaceAssociation: node 003, group: 2, associations: [1]
   Z-Wave Debug                    SENT addInterfaceAssociation: 01 0B 00 13 03 04 85 01 03 01 25 B9 FA
   Z-Wave                          Syncing - added group 3 association to interface
   Z-Wave Debug                    . .  addInterfaceAssociation: node 003, group: 3, associations: [1]
   Z-Wave Debug                    SENT requestConfigVal: 01 0A 00 13 03 03 70 05 05 25 BA 09
   Z-Wave Debug                    timeout waiting for reply from module (retrying)
   Z-Wave Debug                    SENT requestConfigVal: 01 0A 00 13 03 03 70 05 05 25 BB 08
   Z-Wave Debug                    SENT requestConfigVal: 01 0A 00 13 03 03 70 05 05 25 BC 0F
   Z-Wave Debug                    maximum retry count exceeded waiting reply from module (non-fatal, skipping request)
   Z-Wave                          Syncing - failed to retrieve parameter 5 "Group 1 command type" (skipping)
   Z-Wave Debug                    SENT requestConfigVal: 01 0A 00 13 03 03 70 05 09 25 BD 02
   Z-Wave Debug                    SENT requestConfigVal: 01 0A 00 13 03 03 70 05 09 25 BE 01
   Z-Wave Debug                    SENT requestConfigVal: 01 0A 00 13 03 03 70 05 09 25 BF 00
   Z-Wave                          Syncing - failed to retrieve parameter 9 "Disable off commands" (skipping)
   Z-Wave Debug                    SENT requestConfigVal: 01 0A 00 13 03 03 70 05 03 25 C0 75
   Z-Wave Debug                    RCVD requestConfigVal: 01 0B 00 04 00 03 05 70 06 03 01 06 84
   Z-Wave Debug                    . .  requestConfigVal: node 003, parm index 3, value 6 (size 1)
   Z-Wave                          Syncing - retrieved parameter 3 "Switch type" is 6
   Z-Wave Debug                    . .  requestConfigVal: node 003, combined config vals: 3:6
   Z-Wave Debug                    SENT requestConfigVal: 01 0A 00 13 03 03 70 05 01 25 C1 76
   Z-Wave Debug                    RCVD requestConfigVal: 01 0B 00 04 00 03 05 70 06 01 01 00 80
   Z-Wave Debug                    . .  requestConfigVal: node 003, parm index 1, value 0 (size 1)
   Z-Wave                          Syncing - retrieved parameter 1 "Delayed off" is 0 seconds
   Z-Wave Debug                    . .  requestConfigVal: node 003, combined config vals: 1:0 3:6
   Z-Wave Debug                    SENT requestConfigVal: 01 0A 00 13 03 03 70 05 0C 25 C2 78
   Z-Wave Debug                    RCVD requestConfigVal: 01 0C 00 04 00 03 06 70 06 0C 02 00 FF 75
   Z-Wave Debug                    . .  requestConfigVal: node 003, parm index 12, value 255 (size 2)
   Z-Wave                          Syncing - retrieved parameter 12 "Temperature sensitivity" is 255
   Z-Wave Debug                    . .  requestConfigVal: node 003, combined config vals: 1:0 3:6 12:255
   Z-Wave Debug                    SENT requestConfigVal: 01 0A 00 13 03 03 70 05 02 25 C3 77
   Z-Wave Debug                    RCVD requestConfigVal: 01 0B 00 04 00 03 05 70 06 02 01 00 83
   Z-Wave Debug                    . .  requestConfigVal: node 003, parm index 2, value 0 (size 1)
   Z-Wave                          Syncing - retrieved parameter 2 "Enable LED flash on change" is false
   Z-Wave Debug                    . .  requestConfigVal: node 003, combined config vals: 1:0 2:0 3:6 12:255
   Z-Wave Debug                    SENT requestBatteryLevel: 01 09 00 13 03 02 80 02 25 C4 87
   Z-Wave Debug                    RCVD requestBatteryLevel: 01 09 00 04 00 03 03 80 03 64 15
   Z-Wave Debug                    . .  requestBatteryLevel: node 003, level 100
   Z-Wave                          Syncing - retrieved battery level of 100%
   Z-Wave                          Syncing - created device "003 - Door/Window"
   Z-Wave                          Syncing - created device "003 - Tamper Switch"
Open/Close:
Z-Wave                          received "002 - Door/Window" status update is on
   Z-Wave Debug                    RCVD requestAlarmSensorStatus: 01 0F 00 04 00 03 09 71 05 00 00 00 FF 06 17 00 64
   Z-Wave Debug                    . .  requestAlarmSensorStatus: node 003, endpoint None, cmdClass 71, type 0, value 0, classSubKey 710000
   Z-Wave Debug                    . .  requestAlarmSensorStatus: typeExt 6, valueExt 23, classSubKeyExt 7100000617
   Z-Wave                          received "003 - Tamper Switch" status update is off
   Z-Wave Debug                    RCVD requestSensAlarmSensorStatus: 01 0D 00 04 08 03 07 9C 02 03 00 00 00 00 67
   Z-Wave Debug                    . .  requestSensAlarmSensorStatus: node 003, endpoint None, cmdClass 9C, alarmType 0, value 0, classSubKey 9C0000
   Z-Wave Debug                    filtering duplicate command -- old: 710000, 7100000617, 0, new: 9C0000, 0, 0 (0.0747 secs)
   Z-Wave Debug                    RCVD requestSensAlarmSensorStatus: 01 0D 00 04 00 03 07 9C 02 03 00 00 00 00 6F
   Z-Wave Debug                    filtering duplicate command -- old: 9C0000, 0, 0, new: 9C0000, 0, 0 (0.0099 secs)
   Z-Wave Debug                    RCVD sensorSetLevel: 01 09 00 04 08 03 03 20 01 00 DB
   Z-Wave Debug                    . .  sensorSetLevel: node 003, endpoint None, cmdClass 20, value 0
Fri Jul 14, 2017 2:38 pm
Re: Temperature from Fibaro Door / Window ZW+ sensor FGK-10x
I don't believe the original one supported temp sensors. We'll add it to the list of things to add in a future version.
Fri Jul 14, 2017 3:18 pm
jasonstn_21 offline
I am not sure what you mean by the "original one"?
The box says FGK-101 but when I pop off the cover of the sensor it says US Ver 3.2 FGK-10X.
I continue to get the following messages in my log:
Jul 14, 2017, 2:15:32 PM
   Z-Wave Debug                    RCVD requestVarSensorStatus: 01 0C 00 04 00 04 06 31 05 01 42 0B 41 C8
   Z-Wave Debug                    . .  requestVarSensorStatus: node 004, endpoint None, type 1, raw value 420B...
   Z-Wave Debug                    . .  requestVarSensorStatus: 28.81 °C (float: 28.810000)
Is there any way I can pull the temperature it is reporting into Indigo?
Fri Jul 14, 2017 3:45 pm
Indigo does (or at least should) support the temperature sensor broadcasts for that module. However, it only works if you have the temp sensor added before you include it with the Z-Stick. So try excluding and re-including the module with the Z-Stick, then re-sync it in Indigo. If that doesn't work then copy/paste the Event Log results of the sync into a reply for me.
If you already had the sensor added before the initial include then we'll need to work with you to debug into it some more.
Fri Jul 14, 2017 8:07 pm
jasonstn_21 offline
Thanks for your help troubleshooting...
I have removed everything from the ZStick and Indigo and started from the beginning.
I added the device to the Stick (with the temp sensors already in place) and then sync'd them with Indigo.
No luck with the temperature other than what has already been reported:
Jul 14, 2017, 7:02:49 PM
   Z-Wave Debug                    RCVD requestVarSensorStatus: 01 0C 00 04 00 06 06 31 05 01 42 0D C5 48
   Z-Wave Debug                    . .  requestVarSensorStatus: node 006, endpoint None, type 1, raw value 420D...
   Z-Wave Debug                    . .  requestVarSensorStatus: 35.25 °C (float: 35.250000)
   Z-Wave Debug                    RCVD requestVarSensorStatus: 01 0C 00 04 00 05 06 31 05 01 42 0E 22 AF
   Z-Wave Debug                    . .  requestVarSensorStatus: node 005, endpoint None, type 1, raw value 420E...
   Z-Wave Debug                    . .  requestVarSensorStatus: 36.18 °C (float: 36.180000)
Here is the sync:
Jul 14, 2017, 6:39:05 PM
   Z-Wave                          Syncing - started for "005 - Notification Sensor"
   Z-Wave Debug                    SENT getNodeNeighbors: 01 06 00 80 05 01 01 7C
   Z-Wave Debug                    . .  getNodeNeighbors: nodeId 005, neighbors: - none -
   Z-Wave                          Syncing - assigning return route to "005 - Notification Sensor"
   Z-Wave Debug                    SENT assignReturnRoute: 01 05 00 46 05 01 B8
   Z-Wave Debug                    RCVD assignReturnRoute: 01 05 00 46 01 01 BC
   Z-Wave Debug                    . .  assignReturnRoute: node 005, success 0
   Z-Wave Error                    Syncing - failed to assign return route
   Z-Wave Debug                    SENT requestNodeInfo: 01 06 00 60 05 24 6F D7
   Z-Wave Debug                    RCVD requestNodeInfo: 01 06 00 49 81 00 00 31
   Z-Wave Debug                    RCVD requestNodeInfo: failed (module asleep or doesn't support command)
   Z-Wave Error                    No response from "005 - Notification Sensor". Module might be asleep, or is unreachable.
   Z-Wave Debug                    RCVD nodeAwake: 01 08 00 04 04 05 02 84 07 73
   Z-Wave Debug                    . .  nodeAwake: node 005 (queued awake processing because sync in progress)
   Z-Wave Debug                    . .  assignReturnRoute: node 005, success 1
   Z-Wave Debug                    SENT requestNodeInfo: 01 06 00 60 05 24 70 C8
   Z-Wave Debug                    RCVD nodeInfoFrame: 01 1E 00 49 84 05 18 04 07 01 5E 85 59 22 20 80 70 56 5A 7A 72 8E 71 73 98 2B 9C 30 31 86 84 E7
   Z-Wave Debug                    . .  nodeInfoFrame: node 005, combined class list: 20v1 80v1 22v1 84v1 85v1 86v1 71v1 70v1 2Bv1 8Ev1 30v1 31v1 72v1 73v1 56v1 98v1 59v1 5Av1 9Cv1 7Av1 5Ev1
   Z-Wave Debug                    SENT requestManufactureInfo: 01 09 00 13 05 02 72 04 25 71 C0
   Z-Wave Debug                    RCVD requestManufactureInfo: 01 0E 00 04 00 05 08 72 05 01 0F 07 01 20 01 A6
   Z-Wave Debug                    . .  requestManufactureInfo: node 005, manufacturerId 010F, productId 07012001
   Z-Wave Debug                    SENT requestVersInfoGen: 01 09 00 13 05 02 86 11 25 72 22
   Z-Wave Debug                    RCVD requestVersInfoGen: 01 0F 00 04 00 05 09 86 12 03 04 05 03 02 01 00 6E
   Z-Wave Debug                    . .  requestVersInfoGen: node 005, protoVers 4.05, appVers 3.02
   Z-Wave Debug                    SENT requestVersInfoCmdClass: 01 0A 00 13 05 03 86 13 84 25 73 A7
   Z-Wave Debug                    RCVD requestVersInfoCmdClass: 01 0A 00 04 00 05 04 86 14 84 02 E4
   Z-Wave Debug                    . .  requestVersInfoCmdClass: node 005, class command 84 using version 2
   Z-Wave Debug                    . .  requestVersInfoCmdClass: node 005, combined class list: 20v1 80v1 22v1 84v2 85v1 86v1 71v1 70v1 2Bv1 8Ev1 30v1 31v1 72v1 73v1 56v1 98v1 59v1 5Av1 9Cv1 7Av1 5Ev1
   Z-Wave Debug                    SENT requestVersInfoCmdClass: 01 0A 00 13 05 03 86 13 31 25 74 15
   Z-Wave Debug                    RCVD requestVersInfoCmdClass: 01 0A 00 04 00 05 04 86 14 31 05 56
   Z-Wave Debug                    . .  requestVersInfoCmdClass: node 005, class command 31 using version 5
   Z-Wave Debug                    . .  requestVersInfoCmdClass: node 005, combined class list: 20v1 80v1 22v1 84v2 85v1 86v1 71v1 70v1 2Bv1 8Ev1 30v1 31v5 72v1 73v1 56v1 98v1 59v1 5Av1 9Cv1 7Av1 5Ev1
   Z-Wave                          Syncing - retrieved command classes: 20v1 80v1 22v1 84v2 85v1 86v1 71v1 70v1 2Bv1 8Ev1 30v1 31v5 72v1 73v1 56v1 98v1 59v1 5Av1 9Cv1 7Av1 5Ev1
   Z-Wave Debug                    SENT requestWakeInterval: 01 09 00 13 05 02 84 05 25 75 33
   Z-Wave Debug                    RCVD requestWakeInterval: 01 0C 00 04 00 05 06 84 06 00 54 60 FF BD
   Z-Wave Debug                    . .  requestWakeInterval: node 005, interval 360 minutes, wakeTarget 255
   Z-Wave Debug                    SENT setWakeInterval: 01 0D 00 13 05 06 84 04 00 0E 10 01 25 76 2E
   Z-Wave                          Syncing - device "005 - Notification Sensor" wake interval changed to 60 minutes
   Z-Wave Debug                    SENT requestAssociationGroupCount: 01 09 00 13 05 02 85 05 25 77 30
   Z-Wave Debug                    RCVD requestAssociationGroupCount: 01 09 00 04 00 05 03 85 06 05 72
   Z-Wave Debug                    . .  requestAssociationGroupCount: node 005, group count: 5
   Z-Wave Debug                    SENT requestAssociations: 01 0A 00 13 05 03 85 02 01 25 78 3B
   Z-Wave Debug                    RCVD requestAssociations: 01 0C 00 04 00 05 06 85 03 01 01 00 01 73
   Z-Wave Debug                    . .  requestAssociations: node 005, group: 1, num associations: 1, max associations: 1, replies left: 0
   Z-Wave Debug                    . .  requestAssociations: node 005, group: 1, associations: [1]
   Z-Wave                          Syncing - retrieved group 1 associations: [1]
   Z-Wave Debug                    SENT requestAssociations: 01 0A 00 13 05 03 85 02 02 25 79 39
   Z-Wave Debug                    RCVD requestAssociations: 01 0B 00 04 00 05 05 85 03 02 05 00 71
   Z-Wave Debug                    . .  requestAssociations: node 005, group: 2, num associations: 0, max associations: 5, replies left: 0
   Z-Wave Debug                    . .  requestAssociations: node 005, group: 2, associations: []
   Z-Wave Debug                    SENT requestAssociations: 01 0A 00 13 05 03 85 02 03 25 7A 3B
   Z-Wave Debug                    RCVD requestAssociations: 01 0B 00 04 00 05 05 85 03 03 05 00 70
   Z-Wave Debug                    . .  requestAssociations: node 005, group: 3, num associations: 0, max associations: 5, replies left: 0
   Z-Wave Debug                    . .  requestAssociations: node 005, group: 3, associations: []
   Z-Wave Debug                    SENT requestAssociations: 01 0A 00 13 05 03 85 02 04 25 7B 3D
   Z-Wave Debug                    RCVD requestAssociations: 01 0B 00 04 00 05 05 85 03 04 05 00 77
   Z-Wave Debug                    . .  requestAssociations: node 005, group: 4, num associations: 0, max associations: 5, replies left: 0
   Z-Wave Debug                    . .  requestAssociations: node 005, group: 4, associations: []
   Z-Wave Debug                    SENT requestAssociations: 01 0A 00 13 05 03 85 02 05 25 7C 3B
   Z-Wave Debug                    RCVD requestAssociations: 01 0B 00 04 00 05 05 85 03 05 05 00 76
   Z-Wave Debug                    . .  requestAssociations: node 005, group: 5, num associations: 0, max associations: 5, replies left: 0
   Z-Wave Debug                    . .  requestAssociations: node 005, group: 5, associations: []
   Z-Wave                          Syncing - group 1 association to interface already exists (skipping)
   Z-Wave Debug                    SENT addInterfaceAssociation: 01 0B 00 13 05 04 85 01 02 01 25 7D 39
   Z-Wave Debug                    . .  addInterfaceAssociation: node 005, group: 2, associations: [1]
   Z-Wave Debug                    SENT addInterfaceAssociation: 01 0B 00 13 05 04 85 01 03 01 25 7E 3B
   Z-Wave Debug                    . .  addInterfaceAssociation: node 005, group: 3, associations: [1]
   Z-Wave Debug                    SENT requestConfigVal: 01 0A 00 13 05 03 70 05 05 25 7F CA
   Z-Wave Debug                    SENT requestConfigVal: 01 0A 00 13 05 03 70 05 05 25 80 35
   Z-Wave Debug                    SENT requestConfigVal: 01 0A 00 13 05 03 70 05 05 25 81 34
   Z-Wave Debug                    SENT requestConfigVal: 01 0A 00 13 05 03 70 05 09 25 82 3B
   Z-Wave Debug                    SENT requestConfigVal: 01 0A 00 13 05 03 70 05 09 25 83 3A
   Z-Wave Debug                    SENT requestConfigVal: 01 0A 00 13 05 03 70 05 09 25 84 3D
   Z-Wave Debug                    SENT requestConfigVal: 01 0A 00 13 05 03 70 05 03 25 85 36
   Z-Wave Debug                    RCVD requestConfigVal: 01 0B 00 04 00 05 05 70 06 03 01 06 82
   Z-Wave Debug                    . .  requestConfigVal: node 005, parm index 3, value 6 (size 1)
   Z-Wave Debug                    . .  requestConfigVal: node 005, combined config vals: 3:6
   Z-Wave Debug                    SENT requestConfigVal: 01 0A 00 13 05 03 70 05 01 25 86 37
   Z-Wave Debug                    RCVD requestConfigVal: 01 0B 00 04 00 05 05 70 06 01 01 00 86
   Z-Wave Debug                    . .  requestConfigVal: node 005, parm index 1, value 0 (size 1)
   Z-Wave Debug                    . .  requestConfigVal: node 005, combined config vals: 1:0 3:6
   Z-Wave Debug                    SENT requestConfigVal: 01 0A 00 13 05 03 70 05 0C 25 87 3B
   Z-Wave Debug                    RCVD requestConfigVal: 01 0C 00 04 00 05 06 70 06 0C 02 00 FF 73
   Z-Wave Debug                    . .  requestConfigVal: node 005, parm index 12, value 255 (size 2)
   Z-Wave Debug                    . .  requestConfigVal: node 005, combined config vals: 1:0 3:6 12:255
   Z-Wave Debug                    SENT requestConfigVal: 01 0A 00 13 05 03 70 05 02 25 88 3A
   Z-Wave Debug                    RCVD requestConfigVal: 01 0B 00 04 00 05 05 70 06 02 01 00 85
   Z-Wave Debug                    . .  requestConfigVal: node 005, parm index 2, value 0 (size 1)
   Z-Wave Debug                    . .  requestConfigVal: node 005, combined config vals: 1:0 2:0 3:6 12:255
   Z-Wave Debug                    SENT requestBatteryLevel: 01 09 00 13 05 02 80 02 25 89 CC
   Z-Wave Debug                    RCVD requestBatteryLevel: 01 09 00 04 00 05 03 80 03 64 13
   Z-Wave Debug                    . .  requestBatteryLevel: node 005, level 100
   Z-Wave                          Syncing - changed device "x - Hottub Temp" address from undefined to 005
   Z-Wave                          Syncing - changed device "004 - Tamper Switch" address from undefined to 005
   Z-Wave Debug                    SENT goToSleep: 01 09 00 13 05 02 84 08 24 8A C0
   Z-Wave Debug                    RCVD packet: 01 07 00 13 8A 00 00 01 60 (hex)
Jul 14, 2017, 6:41:33 PM
   Z-Wave                          Syncing - started for "006 - Notification Sensor"
   Z-Wave Debug                    SENT getNodeNeighbors: 01 06 00 80 06 01 01 7F
   Z-Wave Debug                    . .  getNodeNeighbors: nodeId 006, neighbors: - none -
   Z-Wave                          Syncing - assigning return route to "006 - Notification Sensor"
   Z-Wave Debug                    SENT assignReturnRoute: 01 05 00 46 06 01 BB
   Z-Wave Debug                    . .  assignReturnRoute: node 006, success 0
   Z-Wave Debug                    SENT requestNodeInfo: 01 06 00 60 06 24 8F 34
   Z-Wave Debug                    RCVD nodeAwake: 01 08 00 04 04 06 02 84 07 70
   Z-Wave Debug                    . .  nodeAwake: node 006 (queued awake processing because sync in progress)
   Z-Wave Error                    No response from "006 - Notification Sensor". Module might be asleep, or is unreachable.
   Z-Wave Debug                    RCVD nodeInfoFrame: 01 1E 00 49 84 06 18 04 07 01 5E 85 59 22 20 80 70 56 5A 7A 72 8E 71 73 98 2B 9C 30 31 86 84 E4
   Z-Wave Debug                    . .  assignReturnRoute: node 006, success 1
   Z-Wave Debug                    SENT requestNodeInfo: 01 06 00 60 06 24 90 2B
   Z-Wave Debug                    . .  nodeInfoFrame: node 006, combined class list: 20v1 80v1 22v1 84v1 85v1 86v1 71v1 70v1 2Bv1 8Ev1 30v1 31v1 72v1 73v1 56v1 98v1 59v1 5Av1 9Cv1 7Av1 5Ev1
   Z-Wave Debug                    SENT requestManufactureInfo: 01 09 00 13 06 02 72 04 25 91 23
   Z-Wave Debug                    RCVD requestManufactureInfo: 01 0E 00 04 00 06 08 72 05 01 0F 07 01 20 01 A5
   Z-Wave Debug                    . .  requestManufactureInfo: node 006, manufacturerId 010F, productId 07012001
   Z-Wave Debug                    SENT requestVersInfoGen: 01 09 00 13 06 02 86 11 25 92 C1
   Z-Wave Debug                    RCVD requestVersInfoGen: 01 0F 00 04 00 06 09 86 12 03 04 05 03 02 01 00 6D
   Z-Wave Debug                    . .  requestVersInfoGen: node 006, protoVers 4.05, appVers 3.02
   Z-Wave Debug                    SENT requestVersInfoCmdClass: 01 0A 00 13 06 03 86 13 84 25 93 44
   Z-Wave Debug                    RCVD requestVersInfoCmdClass: 01 0A 00 04 00 06 04 86 14 84 02 E7
   Z-Wave Debug                    . .  requestVersInfoCmdClass: node 006, class command 84 using version 2
   Z-Wave Debug                    . .  requestVersInfoCmdClass: node 006, combined class list: 20v1 80v1 22v1 84v2 85v1 86v1 71v1 70v1 2Bv1 8Ev1 30v1 31v1 72v1 73v1 56v1 98v1 59v1 5Av1 9Cv1 7Av1 5Ev1
   Z-Wave Debug                    SENT requestVersInfoCmdClass: 01 0A 00 13 06 03 86 13 31 25 94 F6
   Z-Wave Debug                    RCVD requestVersInfoCmdClass: 01 0A 00 04 00 06 04 86 14 31 05 55
   Z-Wave Debug                    . .  requestVersInfoCmdClass: node 006, class command 31 using version 5
   Z-Wave Debug                    . .  requestVersInfoCmdClass: node 006, combined class list: 20v1 80v1 22v1 84v2 85v1 86v1 71v1 70v1 2Bv1 8Ev1 30v1 31v5 72v1 73v1 56v1 98v1 59v1 5Av1 9Cv1 7Av1 5Ev1
   Z-Wave Debug                    SENT requestWakeInterval: 01 09 00 13 06 02 84 05 25 95 D0
   Z-Wave Debug                    RCVD requestWakeInterval: 01 0C 00 04 00 06 06 84 06 00 54 60 FF BE
   Z-Wave Debug                    . .  requestWakeInterval: node 006, interval 360 minutes, wakeTarget 255
   Z-Wave Debug                    SENT setWakeInterval: 01 0D 00 13 06 06 84 04 00 0E 10 01 25 96 CD
   Z-Wave                          Syncing - device "006 - Notification Sensor" wake interval changed to 60 minutes
   Z-Wave Debug                    SENT requestAssociationGroupCount: 01 09 00 13 06 02 85 05 25 97 D3
   Z-Wave Debug                    RCVD requestAssociationGroupCount: 01 09 00 04 00 06 03 85 06 05 71
   Z-Wave Debug                    . .  requestAssociationGroupCount: node 006, group count: 5
   Z-Wave Debug                    SENT requestAssociations: 01 0A 00 13 06 03 85 02 01 25 98 D8
   Z-Wave Debug                    RCVD requestAssociations: 01 0C 00 04 00 06 06 85 03 01 01 00 01 70
   Z-Wave Debug                    . .  requestAssociations: node 006, group: 1, num associations: 1, max associations: 1, replies left: 0
   Z-Wave Debug                    . .  requestAssociations: node 006, group: 1, associations: [1]
   Z-Wave Debug                    SENT requestAssociations: 01 0A 00 13 06 03 85 02 02 25 99 DA
   Z-Wave Debug                    RCVD requestAssociations: 01 0B 00 04 00 06 05 85 03 02 05 00 72
   Z-Wave Debug                    . .  requestAssociations: node 006, group: 2, num associations: 0, max associations: 5, replies left: 0
   Z-Wave Debug                    . .  requestAssociations: node 006, group: 2, associations: []
   Z-Wave Debug                    SENT requestAssociations: 01 0A 00 13 06 03 85 02 03 25 9A D8
   Z-Wave Debug                    RCVD requestAssociations: 01 0B 00 04 00 06 05 85 03 03 05 00 73
   Z-Wave Debug                    . .  requestAssociations: node 006, group: 3, num associations: 0, max associations: 5, replies left: 0
   Z-Wave Debug                    . .  requestAssociations: node 006, group: 3, associations: []
   Z-Wave Debug                    SENT requestAssociations: 01 0A 00 13 06 03 85 02 04 25 9B DE
   Z-Wave Debug                    RCVD requestAssociations: 01 0B 00 04 00 06 05 85 03 04 05 00 74
   Z-Wave Debug                    . .  requestAssociations: node 006, group: 4, num associations: 0, max associations: 5, replies left: 0
   Z-Wave Debug                    . .  requestAssociations: node 006, group: 4, associations: []
   Z-Wave Debug                    SENT requestAssociations: 01 0A 00 13 06 03 85 02 05 25 9C D8
   Z-Wave Debug                    RCVD requestAssociations: 01 0B 00 04 00 06 05 85 03 05 05 00 75
   Z-Wave Debug                    . .  requestAssociations: node 006, group: 5, num associations: 0, max associations: 5, replies left: 0
   Z-Wave Debug                    . .  requestAssociations: node 006, group: 5, associations: []
   Z-Wave Debug                    SENT addInterfaceAssociation: 01 0B 00 13 06 04 85 01 02 01 25 9D DA
   Z-Wave Debug                    . .  addInterfaceAssociation: node 006, group: 2, associations: [1]
   Z-Wave Debug                    SENT addInterfaceAssociation: 01 0B 00 13 06 04 85 01 03 01 25 9E D8
   Z-Wave Debug                    . .  addInterfaceAssociation: node 006, group: 3, associations: [1]
   Z-Wave Debug                    SENT requestConfigVal: 01 0A 00 13 06 03 70 05 05 25 9F 29
   Z-Wave Debug                    SENT requestConfigVal: 01 0A 00 13 06 03 70 05 05 25 A0 16
   Z-Wave Debug                    SENT requestConfigVal: 01 0A 00 13 06 03 70 05 05 25 A1 17
   Z-Wave Debug                    SENT requestConfigVal: 01 0A 00 13 06 03 70 05 09 25 A2 18
   Z-Wave Debug                    SENT requestConfigVal: 01 0A 00 13 06 03 70 05 09 25 A3 19
   Z-Wave Debug                    SENT requestConfigVal: 01 0A 00 13 06 03 70 05 09 25 A4 1E
   Z-Wave Debug                    SENT requestConfigVal: 01 0A 00 13 06 03 70 05 03 25 A5 15
   Z-Wave Debug                    RCVD requestConfigVal: 01 0B 00 04 00 06 05 70 06 03 01 06 81
   Z-Wave Debug                    . .  requestConfigVal: node 006, parm index 3, value 6 (size 1)
   Z-Wave Debug                    . .  requestConfigVal: node 006, combined config vals: 3:6
   Z-Wave Debug                    SENT requestConfigVal: 01 0A 00 13 06 03 70 05 01 25 A6 14
   Z-Wave Debug                    RCVD requestConfigVal: 01 0B 00 04 00 06 05 70 06 01 01 00 85
   Z-Wave Debug                    . .  requestConfigVal: node 006, parm index 1, value 0 (size 1)
   Z-Wave Debug                    . .  requestConfigVal: node 006, combined config vals: 1:0 3:6
   Z-Wave Debug                    SENT requestConfigVal: 01 0A 00 13 06 03 70 05 0C 25 A7 18
   Z-Wave Debug                    RCVD requestConfigVal: 01 0C 00 04 00 06 06 70 06 0C 02 00 FF 70
   Z-Wave Debug                    . .  requestConfigVal: node 006, parm index 12, value 255 (size 2)
   Z-Wave Debug                    . .  requestConfigVal: node 006, combined config vals: 1:0 3:6 12:255
   Z-Wave Debug                    SENT requestConfigVal: 01 0A 00 13 06 03 70 05 02 25 A8 19
   Z-Wave Debug                    RCVD requestConfigVal: 01 0B 00 04 00 06 05 70 06 02 01 00 86
   Z-Wave Debug                    . .  requestConfigVal: node 006, parm index 2, value 0 (size 1)
   Z-Wave Debug                    . .  requestConfigVal: node 006, combined config vals: 1:0 2:0 3:6 12:255
   Z-Wave Debug                    SENT requestBatteryLevel: 01 09 00 13 06 02 80 02 25 A9 EF
   Z-Wave Debug                    RCVD requestBatteryLevel: 01 09 00 04 00 06 03 80 03 64 10
   Z-Wave Debug                    . .  requestBatteryLevel: node 006, level 100
   Z-Wave                          Syncing - created device "006 - Door/Window"
   Z-Wave                          Syncing - created device "006 - Tamper Switch"
   Z-Wave Debug                    SENT goToSleep: 01 09 00 13 06 02 84 08 24 AA E3
   Z-Wave Debug                    RCVD packet: 01 07 00 13 AA 00 00 02 43 (hex)
Sat Jul 15, 2017 2:53 pm
Indigo is failing to create a device for the temperature sensor for some reason. Based on the event log details it should be, so I'm not sure what is going wrong. I'm going to email you off the forum to troubleshoot this in more detail.
Thu Nov 09, 2017 5:11 pm
Indigo 7.1.1 is now available for download and supports this version of the Fibaro Door/Window Sensor (FGK10x).
Fri Jan 05, 2018 3:56 pm
scs offline
I was trying to set one of these up with the temp sensor and failing, after running across this thread and upgrading my server to 7.1.1 the temp sensor popped right up after a resync.
Thanks for that. :)
Question though, the sensor output is in degrees C. Is there some command I can send to the device to make it read degrees F?
Indigo 2022.2 w/ Insteon and Z-Wave lights and outlets
Security integration.
Energy monitoring
Fri Jan 05, 2018 6:47 pm
Some modules have configuration parameters to change the units sent to Indigo but I don't think that Fibaro does. Instead you can use the Adapters plugin to create a virtual sensor device that has the translated values.
Sat Jan 06, 2018 10:29 am
scs offline
That worked like a charm. Thanks @Matt.
Energy monitoring
Tue Apr 17, 2018 9:29 pm
webdeck offline
I just tried adding one of these with a temperature probe attached, and it didn't create the temperature device - I'm on 7.1.1. What am I doing wrong?
-Mike
   Z-Wave                          Syncing - started for "018 - Notification Sensor"
   Z-Wave                          Syncing - retrieved module neighbors list: 3, 6, 11, 14
   Z-Wave                          Syncing - assigning return route to "018 - Notification Sensor"
   Z-Wave                          Syncing - device "018 - Notification Sensor" wake interval changed to 5 minutes
   Z-Wave                          Syncing - device "018 - Notification Sensor" parameter 1 "Operation mode" changed to 0 "Door Sensor or External Alarm"
   Z-Wave                          Syncing - device "018 - Notification Sensor" parameter 2 "Reverse ON / OFF commands for magnet switch" changed to false
   Z-Wave                          Syncing - device "018 - Notification Sensor" parameter 3 "LED mode" changed to 7 "Sensor, Wakup, and Tamper"
   Z-Wave                          Syncing - device "018 - Notification Sensor" parameter 14 "Delayed on" changed to 0 seconds
   Z-Wave                          Syncing - device "018 - Notification Sensor" parameter 15 "Delayed off" changed to 0 seconds
   Z-Wave                          Syncing - device "018 - Notification Sensor" parameter 50 "Temperature measuring interval" changed to 300 seconds
   Z-Wave                          Syncing - device "018 - Notification Sensor" parameter 51 "Temperature sensitivity" changed to 1 * 0.1°C
   Z-Wave                          Syncing - device "018 - Notification Sensor" parameter 52 "Temperature reporting interval" changed to 300 seconds
   Z-Wave                          Syncing - device "018 - Notification Sensor" parameter 53 "Temperature offset" changed to 0 * 0.1°C
   Z-Wave                          Syncing - device "018 - Notification Sensor" parameter 30 "Tamper off delay" changed to 5 seconds
   Z-Wave                          Syncing - device "018 - Notification Sensor" parameter 31 "Enable tamper auto off" changed to true
   Z-Wave                          Syncing - retrieved battery level of 98%
   Z-Wave                          Syncing - retrieved command classes: 20v1 80v1 22v1 84v2 85v1 86v1 70v1 2Bv1 8Ev1 30v1 71v1 72v1 73v1 56v1 98v1 59v1 5Av1 9Cv1 7Av1 5Ev1
   Z-Wave                          Syncing - retrieved wake interval of 60 minutes
   Z-Wave                          Syncing - retrieved parameter 20 "Group 1 command type" is 0
   Z-Wave                          Syncing - retrieved parameter 1 "Operation mode" is 0 "Door Sensor or External Alarm"
   Z-Wave                          Syncing - retrieved parameter 3 "LED mode" is 7 "Sensor, Wakup, and Tamper"
   Z-Wave                          Syncing - retrieved parameter 2 "Reverse ON / OFF commands for magnet switch" is false
   Z-Wave                          Syncing - retrieved parameter 14 "Delayed on" is 0 seconds
   Z-Wave                          Syncing - retrieved parameter 15 "Delayed off" is 0 seconds
   Z-Wave                          Syncing - retrieved parameter 31 "Enable tamper auto off" is true
   Z-Wave                          Syncing - retrieved parameter 30 "Tamper off delay" is 5 seconds
   Z-Wave                          Syncing - retrieved parameter 51 "Temperature sensitivity" is 1 * 0.1°C
   Z-Wave                          Syncing - retrieved parameter 50 "Temperature measuring interval" is 300 seconds
   Z-Wave                          Syncing - retrieved parameter 52 "Temperature reporting interval" is 300 seconds
   Z-Wave                          Syncing - retrieved parameter 53 "Temperature offset" is 0 * 0.1°C
   Z-Wave                          Syncing - created device "018 - Door/Window"
   Z-Wave                          Syncing - created device "018 - Tamper Switch"
Tue Apr 17, 2018 9:30 pm
webdeck offline
PS - device properties:
   Z-Wave                          Indigo Device "018 - Door/Window" Z-Wave Properties:
Indigo Z-Wave Version: 2.0.111
Node ID: 18
Model ID: 07012001
Model Definition Version: 8
Library Type: 3
Command Versions: 20v1 80v1 22v1 84v2 85v1 86v1 70v1 2Bv1 8Ev1 30v1 71v1 72v1 73v1 56v1 98v1 59v1 5Av1 9Cv1 7Av1 5Ev1
Neighbors: 3, 6, 11, 14
Associations: 1:[1] 2:[] 3:[] 4:[] 5:[]
Config Values: 1:0 2:0 3:7 14:0 15:0 50:300 51:1 52:300 53:0 20:0 30:5 31:1
Tue Apr 17, 2018 10:22 pm
Did you exclude and re-include it (with the Z-Stick) after the sensor was added?
Tue Apr 17, 2018 10:26 pm
webdeck offline
Yeah, just figured that part out - had to exclude and re-include. It's working now! Thanks!
