- Posted on
Mon Jul 24, 2017 3:50 pm
Different Computers
offline
Indigo reads it successfully as a motion sensor, and allows configurable reset times.
Jul 24, 2017, 5:47:41 PM
Z-Wave Indigo Device "Front Door Motion" Z-Wave Properties:
Indigo Z-Wave Version: 2.0.68
Node ID: 36
Model: Zooz Multi Sensor (ZSE40)
Model ID: 20212101
Manufacturer: Vision / Yale
Manufacturer ID: 0109
Protocol Version: 4.05
Application Version: 5.01
Model Definition Version: 1
Library Type: 3
Class Name: Notification Sensor
Class Hierarchy: 04 : 07 : 01
Command Class Base: 00
Command Versions: 20v1 80v1 84v2 85v1 86v1 71v1 70v1 31v7 72v1 73v1 59v1 5Av1 7Av1 5Ev1
Features: routing, battery, beaming, waking
Neighbors: 2, 3, 4, 14, 15, 22
Associations: 1:[1]
Config Values: 1:1 2:10 3:10 4:10 5:3 6:4 7:1
It also sees Humidity, Temp, Luminance and Tamper, but Indigo does NOT offer these as appearing in the device list, like it did with the Aeon unit I had. Unless I'm forgetting something. In other words, in the Device window, I get Motion/Temp/Tamper/Humidity/Luminance, but only one device shows in the device list.
- Screen Shot 2017-07-24 at 5.51.16 PM.png (72.63 KiB) Viewed 3907 times
- Screen Shot 2017-07-24 at 5.51.39 PM.png (70.45 KiB) Viewed 3907 times
