Monoprice Z-Wave Plus PIR Multi Sensor
Mon Jul 31, 2017 4:22 pm
Re: Monoprice Z-Wave Plus PIR Multi Sensor
did you see where I mention that you have to hit the program switch 4-6 times, not the lower number in the paper instructions?
Also the program switch is not illustrated in the instructions, It is NOT the tamper switch on the main board. It's accessed with a bent paper clip through the tiny hole on the exterior.
Mon Jul 31, 2017 4:31 pm
Shavano offline
Yes. I think I tried that already. But, I'll try hitting the Program switch (with a trusty paperclip) several more times and see if it works.
Mon Jul 31, 2017 4:54 pm
I was literally holding the Z-stick and the sensor in the same hand and poking the switch randomly until I saw the stick react.
Mon Jul 31, 2017 11:01 pm
Shavano offline
Here is the Indigo log from my last attempt:
Jul 31, 2017, 23:57:41
Z-Wave Syncing - started for "003 - Notification Sensor"
Z-Wave Error Syncing - failed
Z-Wave Error Timeout waiting for "003 - Notification Sensor". Module might be asleep, or is unreachable.
Z-Wave Error no ack/nak/busy reply (003) for requestBatteryLevel (re-sending)
Z-Wave retrieved module neighbors list: - none -
Z-Wave Error rcvd unexpected bytes (sent ACK): 16 00 49 84 03 10 04 07 01 5E 86 72 5A 85 59 73 80 71 31 70 84 7A 24
Z-Wave Syncing - retrieved module neighbors list: - none -
Z-Wave Syncing - assigning return route to "003 - Notification Sensor"
Z-Wave Syncing - retrieved manufacture and model names: Vision / Yale - 0109, Zooz Multi Sensor (ZSE40) - 20212101
Z-Wave Syncing - retrieved protocol version 4.05, app version 5.01
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Notification Sensor : Notification Sensor (04 : 07 : 01, base 00)
Z-Wave Syncing - retrieved command classes: 20v1 80v1 84v2 85v1 86v1 71v1 70v1 31v7 72v1 73v1 59v1 5Av1 7Av1 5Ev1
Z-Wave Syncing - retrieved encrypt commands: - none -
Z-Wave Syncing - retrieved capabilities: routing, battery, beaming, waking
Z-Wave Syncing - retrieved wake interval of 60 minutes
Z-Wave Syncing - device "003 - Notification Sensor" wake interval changed to 60 minutes
Z-Wave Error rcvd unexpected bytes (sent ACK): 07 00 13 2B 00 00 02 C2
Z-Wave Error rcvd unexpected bytes (sent ACK): 09 00 04 00 03 03 85 06 01 70
Thu Aug 03, 2017 4:58 pm
I'm not sure what is going wrong, but I suspect the module is going to sleep despite your efforts during the sync process. To get more details you can turn on the Z-Wave debug logging via the Interfaces->Z-Wave->Configure... menu item (checkbox in that dialog). Copy/paste the results that you get from a sync with that enabled into a reply for us.
I'd also suggest you try resetting the device by excluding it from the Z-Stick, re-including it, then syncing it again. Perhaps it got into a bad state. From your logs it looks like you have the exact same module (including same firmware version) as forum user Different Computers, so I don't think the problem is because of a different firmware version or model.
Thu Aug 03, 2017 8:11 pm
Shavano offline
I removed the Z-stick from my Mac, manually Excluded and then Included the Multi Sensor several times and finally it was able to Sync. So, my advice is to just keep trying.
Fri Apr 06, 2018 11:35 am
Ericbo offline
I have my first Monoprice Z-Wave Plus PIR Multi Sensor installed with Indigo and happy with it !
I will probably add an other 2 (and for the time being mostly use the temperature for central heating/cooling/fans ...)
Did anybody work on a battery low alarm ?
Thank you !
Tue Jan 22, 2019 1:26 pm
Ericbo offline
Oh actually looking into a low battery alarm, if anybody has a solution, interested!
Tue Jan 22, 2019 6:23 pm
Ericbo offline
Ooopsss ... too easy : trigger / device state changed / sensor movement / battery level / becomes less than ....
Thanks Indigo !!
