I've tried the "Optimize Z-Wave network" to no avail. Even if I just manually open and close the lock to make it active, those changes are reflected in Indigo, and I start the Optimization right away, but the lock is still "unreachable".
- Code: Select all
Z-Wave Optimizing - starting "005 - Front Door"
Z-Wave Optimizing - ping failed (could be asleep)
Z-Wave Optimizing - skipped "005 - Front Door" (unreachable)
The lock was included using encryption, but this is just a bit frustrating..... can't figure out what might be wrong... Is this just more complicated that I think?
The lock does communicate with indigo perfectly.... just not the other way 'round. I've used the Lock Plugin to add user codes, and that worked fine... but now even that isn't working. The only thing that is different is that I recently changed the batteries... is there something I need to do in that case?
Do I need to create an Action Group that does something first before unlocking? Should I un-include it and try again?
