Please add support for Fibaro Door & Window Sensor 2 Gen5
Wed Jun 28, 2017 8:25 am
RPRobinson offline
Just got this new version from vesternet see link below
http://www.vesternet.com/z-wave-fibaro- ... sor-2-gen5
SKU: FGDW-002-1
However the only status that is currently obtained through Indigo is 'Battery Status'.
Appreciate if this could be defined and added in future release please.
Indigo Z-Wave Version: 2.0.68
Node ID: 79
Model: Notification Sensor
Model ID: 07021000
Manufacturer: Fibaro System
Manufacturer ID: 010F
Protocol Version: 4.38
Application Version: 3.02
Model Definition Version: 0
Library Type: 3
Class Name: Notification Sensor
Class Hierarchy: 04 : 07 : 01
Command Class Base: 00
Command Versions: 20v1 80v1 22v1 84v2 85v1 86v1 71v1 8Ev1 70v1 31v5 72v1 73v1 56v1 59v1 5Av1 7Av1 5Ev1
Features: routing, battery, beaming, waking
Neighbors: 1, 4, 5, 7, 8, 9, 14, 25, 26, 27, 28, 29, 30, 35, 37, 38, 39, 40, 46, 47, 55, 56, 57, 58, 59
Associations: 1:[1] 2:[] 3:[]
Config Values: - none -
Richard
Wed Jun 28, 2017 9:06 am
Re: Please add support for Fibaro Door & Window Sensor 2 Gen
Please click the Submit Device Information button in the device's config dialog (if it shows up).
[MODERATOR NOTE] moved to Z-Wave forum.
Wed Jul 05, 2017 7:53 pm
We have a beta of Indigo's Z-Wave library that should support this new Fibaro module. You can download it here then double-click to install it (you might need to also double-click to uncompress it). After that, re-sync the device in Indigo and it should update its state correctly based on the sensor's messages and you should see some of the configuration parameters available in Indigo's device settings UI. Let us know if it works for you.
Sun Oct 08, 2017 10:14 am
elov offline
I've tried the new beta, 2.0.96 with the Fibaro door/window sensor 2 and it works.
The only issue with the upgrade was that I had to resync 3 of the 4 version 1 sensors i have in my network.
Indigo Z-Wave Version: 2.0.96
Node ID: 79
Model: Door/Window Sensor 2 (FGDW002)
Model ID: 07021000
Model Definition Version: 7
Library Type: 3
Neighbors: 3, 5, 6, 17, 28, 30, 31, 35, 53, 54, 59, 60, 61, 77, 78, 81
Config Values: 1:0 2:6 51:10 52:0 30:5 53:0 15:0 50:300 14:0 31:1
Thu Nov 09, 2017 11:22 am
Indigo 7.1.1 is now available for download and supports the Fibaro Door / Window Sensor 2.
