- Posted on
Tue Jun 27, 2017 6:55 pm
Different Computers
offline
Ok, I'm coming clean here, which means Matt & Jay are off the hook for this: I'm trying to run Indigo on a Hackintosh.
Indigo ran perfectly for months and months and months, but yesterday I upgraded to 10.12.5 and now my USB Aeotech Z-Stick Gen5 does not show up. Which of course means almost nothing in the house talks to Indigo!
- Code: Select all
Started interface "Z-Wave 2.0.68"
Z-Wave Error "Z-Wave Controller" serial port open error: [Errno 2] could not open port /dev/cu.usbmodem14E1: [Errno 2] No such file or directory: '/dev/cu.usbmodem14E1'
Z-Wave Error make sure the USB virtual serial port driver (ex: FTDI driver) is installed and correct port is selected
Z-Wave Error Z-Wave Controller might be disconnected
Z-Wave Error silently retrying serial connection every 5.0 seconds
Now, I had this problem (or something very similar) when I first tried to run Indigo on this machine, and some combo of installing FTDI USB Serial Driver and maybe something else got it recognized and functioning. It gave me some sort of serial connection entry in the Network system pref, not that I ever used it. I have the same SiLabsUSBDriver.kext and FTDIUSBSerialDriver.kext installed in the new OS, (or at least newer versions with the same name) but the options in the Z-wave interface dropdowns are different and there's never an option to select the Gen5.
Anyway, I'm turning here because I'm certain that I found some reference to drivers for Z Sticks in this forum, but I don't have any idea where besides this thread. Any help appreciated! I'm 99.99% certain it's not the Z Stick having gone bad.
