It's an IR transmitter for controlling TVs. It has a built in library for common TVs or can learn IR signals. Product info and manuals are here: https://www.remotec.com.hk/bw8371-product-page/. It has 6 IR outputs and can be programmed for up to 6 different IR devices.
The manual states that it is a "multi-channel" device with 6 virtual devices. I"ve added the device and synced it. I've been setting attribute 27 which is the IR code (list can be found here: https://www.remotec.com.hk/wp-content/uploads/2016/06/8371EU_CODELIST_V1.2G_F829-8371-0000_20150526.pdf.) and sending the raw Z-Wave command 39 (0x0027) which should send a power on signal. 3 diffeernet TVs, No luck.
I've also set attribute 31 which is "IR transmission mode". This toggles between "Continuous IR transmission mode" and "Single shot IR transmission mode". The manual doesn't explain what this actually means. But I tried it anyway.
As there are meant to be 6 virtual devices and Indigo sees only 1, I'm wondering if I'm sending the raw Z-Wave command into no-man's-land. Similarly, when setting attributes, I don't know which virtual device I'm working with... you would assume number 1.
Full define and sync:
- Code: Select all
Z-Wave Syncing - started for "AV Control Point"
Z-Wave Syncing - retrieved module neighbors list: 1, 2, 5, 6, 15, 16, 17, 18, 22, 26, 30, 33, 41, 42
Z-Wave Syncing - assigning return route to "046 - AV Control Point"
Z-Wave Syncing - retrieved manufacture and model names: Remotec - 5254, AV Control Point - 01028371
Z-Wave Syncing - retrieved protocol version 3.67, app version 1.10
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : AV Control Point : -- (04 : 03 : 00, base 00)
Z-Wave Syncing - retrieved command classes: 20v1 60v3 86v1 70v1 72v1 94v1
Z-Wave Syncing - retrieved capabilities: routing, beaming
Z-Wave Syncing - retrieved multi-endpoint types: 1:(03 : 00), 2:(03 : 00), 3:(03 : 00), 4:(03 : 00), 5:(03 : 00), 6:(03 : 00)
Z-Wave Syncing - retrieved multi-endpoint classes: 1:[94 70 20], 2:[94 70 20], 3:[94 70 20], 4:[94 70 20], 5:[94 70 20], 6:[94 70 20]
Z-Wave Syncing - complete
