Aeotec Nano Dimmer ZW111
Wed Apr 19, 2017 2:28 pm
elov offline
I just got the new Aeotec Nano Dimmer, ZW111-C (EU).
It syncs with Indigodomo and is usable for me as 024 - Dimmable Power Switch showing load.
But Im missing the binary input and setting options for the device advanced settings.
Manual: http://products.z-wavealliance.org/Prod ... manual.pdf
In order to get a notification from the Dimmer when the S1 or S2 input is trigged param 80 needs to be configured. It supports different methods. Hail CC, Basic CC and Multilevel Switch. I don't know what is the best but I've attached a log from using Hail CC. Note that i did not connect a light bulb to the dimmer yet so it does not change state to On. The manual shows all parameters available.
This seems like a incredible dimmer, I have Fibaro Dimmer 2 and Qubino Flush Dimmer today but this seems more capable with all the customizations..
Please get this thing supported fully in Indigo and I'll be a happy customer.
Let me know if you want any more debug and testing done.
Also the "Submit to Indigo Domotics" page does not work, got a server side error once I posted the form.
Cheers
Z-Wave                          Indigo Device "024 - Dimmable Power Switch" Z-Wave Properties:
Indigo Z-Wave Version: 2.0.68
Node ID: 24
Model: Dimmable Power Switch
Model ID: 0003006F
Manufacturer: Aeon Labs
Manufacturer ID: 0086
Protocol Version: 4.38
Application Version: 1.02
Model Definition Version: 0
Library Type: 3
Class Name: Dimmable Power Switch
Class Hierarchy: 04 : 11 : 01
Command Class Base: 26
Command Versions: 81v1 85v1 86v1 59v1 5Av1 5Ev1 20v1 25v1 26v2 27v1 2Bv1 2Cv1 72v1 70v1 71v1 32v3 73v1 7Av1
Features: routing, beaming, energyMeter
Neighbors: 3, 5, 6, 10, 15, 17
Associations: 1:[1] 2:[] 3:[] 4:[]
Config Values: - none -
And a sync debug log
   Z-Wave Debug                    intiatingSyncUI (timeout in 1500 seconds)
   Z-Wave                          Syncing - started for "024 - Dimmable Power Switch"
   Z-Wave Debug                    SENT getNodeNeighbors: 01 06 00 80 18 01 01 61
   Z-Wave Debug                    RCVD getNodeNeighbors: 01 20 01 80 34 42 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29
   Z-Wave Debug                    . .  getNodeNeighbors: nodeId 024, neighbors: 3, 5, 6, 10, 15, 17
   Z-Wave                          Syncing - retrieved module neighbors list: 3, 5, 6, 10, 15, 17
   Z-Wave                          Syncing - assigning return route to "024 - Dimmable Power Switch"
   Z-Wave Debug                    SENT assignReturnRoute: 01 05 00 46 18 01 A5
   Z-Wave Debug                    RCVD assignReturnRoute: 01 04 01 46 01 BD
   Z-Wave Debug                    RCVD assignReturnRoute: 01 05 00 46 01 00 BD
   Z-Wave Debug                    . .  assignReturnRoute: node 024, success 1
   Z-Wave Debug                    SENT requestNodeInfo: 01 06 00 60 18 24 8F 2A
   Z-Wave Debug                    RCVD nodeInfoFrame: 01 1C 00 49 84 18 16 04 11 01 5E 86 72 5A 73 85 59 25 26 27 32 70 81 71 2C 2B 7A EF 82 ED
   Z-Wave Debug                    . .  nodeInfoFrame: node 024, combined class list: 81v1 85v1 86v1 59v1 5Av1 5Ev1 20v1 25v1 26v1 27v1 2Bv1 2Cv1 72v1 70v1 71v1 32v1 73v1 7Av1
   Z-Wave Debug                    SENT requestManufactureInfo: 01 09 00 13 18 02 72 04 25 90 3C
   Z-Wave Debug                    RCVD requestManufactureInfo: 01 0E 00 04 00 18 08 72 05 00 86 00 03 00 6F 78
   Z-Wave Debug                    . .  requestManufactureInfo: node 024, manufacturerId 0086, productId 0003006F
   Z-Wave Debug                    . .  requestManufactureInfo: Aeon Labs, Dimmable Power Switch
   Z-Wave                          Syncing - retrieved manufacture and model names: Aeon Labs - 0086, Dimmable Power Switch - 0003006F
   Z-Wave Debug                    SENT requestVersInfoGen: 01 09 00 13 18 02 86 11 25 91 DC
   Z-Wave Debug                    RCVD requestVersInfoGen: 01 11 00 04 00 18 0B 86 12 03 04 26 01 02 6F 01 01 02 22
   Z-Wave Debug                    . .  requestVersInfoGen: node 024, protoVers 4.38, appVers 1.02
   Z-Wave                          Syncing - retrieved protocol version 4.38, app version 1.02
   Z-Wave Debug                    SENT requestVersInfoCmdClass: 01 0A 00 13 18 03 86 13 26 25 92 F9
   Z-Wave Debug                    RCVD requestVersInfoCmdClass: 01 0A 00 04 00 18 04 86 14 26 02 5B
   Z-Wave Debug                    . .  requestVersInfoCmdClass: node 024, class command 26 using version 2
   Z-Wave Debug                    . .  requestVersInfoCmdClass: node 024, combined class list: 81v1 85v1 86v1 59v1 5Av1 5Ev1 20v1 25v1 26v2 27v1 2Bv1 2Cv1 72v1 70v1 71v1 32v1 73v1 7Av1
   Z-Wave Debug                    SENT requestVersInfoCmdClass: 01 0A 00 13 18 03 86 13 32 25 93 EC
   Z-Wave Debug                    RCVD requestVersInfoCmdClass: 01 0A 00 04 00 18 04 86 14 32 03 4E
   Z-Wave Debug                    . .  requestVersInfoCmdClass: node 024, class command 32 using version 3
   Z-Wave Debug                    . .  requestVersInfoCmdClass: node 024, combined class list: 81v1 85v1 86v1 59v1 5Av1 5Ev1 20v1 25v1 26v2 27v1 2Bv1 2Cv1 72v1 70v1 71v1 32v3 73v1 7Av1
   Z-Wave                          Syncing - retrieved class hierarchy: Routing Slave : Mulitlevel Switch : Dimmable Power Switch (04 : 11 : 01, base 26)
   Z-Wave                          Syncing - retrieved command classes: 81v1 85v1 86v1 59v1 5Av1 5Ev1 20v1 25v1 26v2 27v1 2Bv1 2Cv1 72v1 70v1 71v1 32v3 73v1 7Av1
   Z-Wave                          Syncing - retrieved encrypt commands: - none -
   Z-Wave                          Syncing - retrieved capabilities: routing, beaming
   Z-Wave Debug                    SENT requestAssociationGroupCount: 01 09 00 13 18 02 85 05 25 94 CE
   Z-Wave Debug                    RCVD requestAssociationGroupCount: 01 09 00 04 00 18 03 85 06 04 6E
   Z-Wave Debug                    . .  requestAssociationGroupCount: node 024, group count: 4
   Z-Wave Debug                    SENT requestAssociations: 01 0A 00 13 18 03 85 02 01 25 95 CB
   Z-Wave Debug                    RCVD requestAssociations: 01 0C 00 04 00 18 06 85 03 01 05 00 01 6A
   Z-Wave Debug                    . .  requestAssociations: node 024, group: 1, num associations: 1, max associations: 5, replies left: 0
   Z-Wave Debug                    . .  requestAssociations: node 024, group: 1, associations: [1]
   Z-Wave                          Syncing - retrieved group 1 associations: [1]
   Z-Wave Debug                    SENT requestAssociations: 01 0A 00 13 18 03 85 02 02 25 96 CB
   Z-Wave Debug                    RCVD requestAssociations: 01 0B 00 04 00 18 05 85 03 02 05 00 6C
   Z-Wave Debug                    . .  requestAssociations: node 024, group: 2, num associations: 0, max associations: 5, replies left: 0
   Z-Wave Debug                    . .  requestAssociations: node 024, group: 2, associations: []
   Z-Wave                          Syncing - retrieved group 2 associations: []
   Z-Wave Debug                    SENT requestAssociations: 01 0A 00 13 18 03 85 02 03 25 97 CB
   Z-Wave Debug                    RCVD requestAssociations: 01 0B 00 04 00 18 05 85 03 03 05 00 6D
   Z-Wave Debug                    . .  requestAssociations: node 024, group: 3, num associations: 0, max associations: 5, replies left: 0
   Z-Wave Debug                    . .  requestAssociations: node 024, group: 3, associations: []
   Z-Wave                          Syncing - retrieved group 3 associations: []
   Z-Wave Debug                    SENT requestAssociations: 01 0A 00 13 18 03 85 02 04 25 98 C3
   Z-Wave Debug                    RCVD requestAssociations: 01 0B 00 04 00 18 05 85 03 04 05 00 6A
   Z-Wave Debug                    . .  requestAssociations: node 024, group: 4, num associations: 0, max associations: 5, replies left: 0
   Z-Wave Debug                    . .  requestAssociations: node 024, group: 4, associations: []
   Z-Wave                          Syncing - retrieved group 4 associations: []
   Z-Wave                          Syncing - group 1 association to interface already exists (skipping)
   Z-Wave Debug                    SENT requestMeterInfo: 01 09 00 13 18 02 32 03 25 99 72
   Z-Wave Debug                    RCVD requestMeterInfo: 01 0A 00 04 00 18 04 32 04 81 35 6F
   Z-Wave Debug                    . .  requestMeterInfo: node 024, meterType 01, subTypeFlags 35, supportsReset True
   Z-Wave Debug                    SENT requestClockInfo: 01 09 00 13 18 02 81 05 25 9A C4
   Z-Wave Debug                    RCVD requestClockInfo: 01 0A 00 04 00 18 04 81 06 75 37 28
   Z-Wave Debug                    . .  requestClockInfo: node 024, 21:55 day-of-week 3
   Z-Wave Debug                    SENT setClock: 01 0B 00 13 18 04 81 04 75 37 25 9B 82
   Z-Wave                          Syncing - synced server clock to module (21:55, Wednesday)
   Z-Wave Debug                    SENT requestDimmerStatus: 01 09 00 13 18 02 26 02 25 9C 62
   Z-Wave                          sent "024 - Dimmable Power Switch" status request
   Z-Wave                          sent "024 - Dimmable Power Switch" energy status request
   Z-Wave                          device "024 - Dimmable Power Switch" parameter 80 changed to 1
   Z-Wave Debug                    RCVD hailBroadcast: 01 08 00 04 00 18 02 82 01 6A
   Z-Wave Debug                    . .  hailBroadcast: node 024
   Z-Wave Debug                    queueing full request of "024 - Dimmable Power Switch" (activity detected)
   Z-Wave Debug                    ignoring duplicate full request of "024 - Dimmable Power Switch" (activity detected)
   Z-Wave Debug                    polling status of node "024 - Dimmable Power Switch" (post-activity full request)
   Z-Wave Debug                    SENT requestDimmerStatus: 01 09 00 13 18 02 26 02 25 C2 3C
   Z-Wave Debug                    RCVD requestDimmerStatus: 01 09 00 04 00 18 03 26 03 42 8E
   Z-Wave Debug                    . .  requestDimmerStatus: node 024, endpoint None, value 66
   Z-Wave                          received "024 - Dimmable Power Switch" status update brightness 67
   Z-Wave Debug                    queueing energy request of "024 - Dimmable Power Switch" (activity detected)
   Z-Wave Debug                    SENT requestMeterLevel: 01 0A 00 13 18 03 32 01 00 25 C3 28
   Z-Wave Debug                    RCVD requestMeterLevel: 01 14 00 04 00 18 0E 32 02 21 64 00 00 00 00 00 00 00 00 00 00 8C
   Z-Wave Debug                    . .  requestMeterLevel: node 024, endpoint None, meterType 01, raw value 6400...
   Z-Wave Debug                    . .  requestMeterLevel: 0.000 kWh (float: 0.000000)
   Z-Wave Debug                    SENT requestMeterLevel: 01 0A 00 13 18 03 32 01 10 25 C4 3F
   Z-Wave Debug                    RCVD requestMeterLevel: 01 14 00 04 00 18 0E 32 02 21 74 00 00 00 00 00 00 00 00 00 00 9C
   Z-Wave Debug                    . .  requestMeterLevel: node 024, endpoint None, meterType 01, raw value 7400...
   Z-Wave Debug                    . .  requestMeterLevel: 0.000 W (float: 0.000000)
   Z-Wave Debug                    polling status of node "024 - Dimmable Power Switch" (post-activity energy request)
   Z-Wave Debug                    SENT requestMeterLevel: 01 0A 00 13 18 03 32 01 00 25 C5 2E
   Z-Wave Debug                    RCVD requestMeterLevel: 01 14 00 04 00 18 0E 32 02 21 64 00 00 00 00 00 05 00 00 00 00 89
   Z-Wave Debug                    SENT requestMeterLevel: 01 0A 00 13 18 03 32 01 10 25 C6 3D
   Z-Wave Debug                    RCVD requestMeterLevel: 01 14 00 04 00 0F 0E 32 02 21 54 00 00 00 00 00 3C 00 00 00 00 97
   Z-Wave Debug                    . .  requestMeterLevel: node 015, endpoint None, meterType 01, raw value 5400...
   Z-Wave Debug                    . .  requestMeterLevel: 0.00 W (float: 0.000000)
   Z-Wave Debug                    SENT requestDimmerStatus: 01 09 00 13 18 02 26 02 25 C7 39
   Z-Wave Debug                    SENT requestMeterLevel: 01 0A 00 13 18 03 32 01 00 25 C8 23
   Z-Wave Debug                    RCVD requestMeterLevel: 01 14 00 04 00 18 0E 32 02 21 64 00 00 00 00 00 15 00 00 00 00 99
   Z-Wave Debug                    SENT requestMeterLevel: 01 0A 00 13 18 03 32 01 10 25 C9 32
Thu Apr 20, 2017 4:34 am
CrazyFin offline
Re: Aeotec Nano Dimmer ZW111
Oooh I really love these brand new Aeon Labs Nano Dimmers ZW111!! :shock:
http://www.vesternet.com/z-wave-aeon-labs-nano-dimmer-gen5
These Nano Dimmers look really cool and have very small footprint (just 4 mm higher than the Qubino dimmer).
They seem to be able to handle all kind of wiring setups and other issues I have had with Qubino and Fibaro dimmers.
Hopefully they will be fully working with Indigo soon. I´ll buy a bunch of them from my local supplier here in Sweden (www.m.nu)
Wed Apr 26, 2017 9:40 am
marketability offline
in stock in UK (vesternet)
looks good as I have 2-wire throughout the house
+1 for indigo integration :-)
Wed Apr 26, 2017 1:38 pm
elov offline
Just hooked up a light fixture (5 Osram Parathom Advanced GU5,3 35W Dim LED 12V with an Eglo LED 0-70W transformer) to this Aeotec Nano Dimmer.
It flashed around at "boot", calibrating the type fixture just like the Fibaro dimmer. It choose trailing edge dimming, I tried to set it manually to leading and it also worked well.
Previous I had set param 80 to 1 for Hail CC. And now it works. I can control the light from Indigo and it reports its state back.
   Z-Wave Debug                    SENT setMultiLevelValue: 01 0A 00 13 18 03 26 01 00 25 48 B7
   Z-Wave                          sent "024 - Dimmable Power Switch" off
   Z-Wave Debug                    queueing full request of "024 - Dimmable Power Switch" (activity detected, replacing previous energy request)
   Z-Wave Debug                    SENT requestDimmerStatus: 01 09 00 13 18 02 26 02 25 49 B7
   Z-Wave Debug                    RCVD requestDimmerStatus: 01 09 00 04 00 18 03 26 03 00 CC
   Z-Wave Debug                    . .  requestDimmerStatus: node 024, endpoint None, value 0
   Z-Wave Debug                    SENT requestMeterLevel: 01 0A 00 13 18 03 32 01 00 25 4A A1
   Z-Wave Debug                    RCVD requestMeterLevel: 01 14 00 04 00 18 0E 32 02 21 64 00 00 00 00 00 27 00 00 00 00 AB
   Z-Wave Debug                    SENT requestMeterLevel: 01 0A 00 13 18 03 32 01 10 25 4B B0
   Z-Wave                          received "024 - Dimmable Power Switch" power load to 0.000 W
   Z-Wave Debug                    SENT setMultiLevelValue: 01 0A 00 13 18 03 26 01 FF 25 4C 4C
   Z-Wave                          sent "024 - Dimmable Power Switch" on
   Z-Wave Debug                    SENT requestDimmerStatus: 01 09 00 13 18 02 26 02 25 4D B3
   Z-Wave Debug                    RCVD requestDimmerStatus: 01 09 00 04 00 18 03 26 03 63 AF
   Z-Wave Debug                    . .  requestDimmerStatus: node 024, endpoint None, value 99
   Z-Wave Debug                    SENT requestMeterLevel: 01 0A 00 13 18 03 32 01 00 25 4E A5
   Z-Wave Debug                    RCVD requestMeterLevel: 01 14 00 04 00 18 0E 32 02 21 64 00 00 00 00 00 0D 00 00 00 00 81
   Z-Wave Debug                    SENT requestMeterLevel: 01 0A 00 13 18 03 32 01 10 25 4F B4
   Z-Wave Debug                    RCVD requestMeterLevel: 01 14 00 04 00 18 0E 32 02 21 74 00 00 6A E0 00 00 00 00 00 00 16
   Z-Wave Debug                    . .  requestMeterLevel: 27.360 W (float: 27.360000)
   Z-Wave                          received "024 - Dimmable Power Switch" power load to 27.360 W
I tested the input S1, and it works once I set param 120 to 1 or 3. But here I found out that the Aeotec manual is incorrect.
It says: 0 = Automatic, 1 = Momentary Push Botton Mode, 2 = 3 way switch mode, 3 = 2-state switch.
But it turns out that 3 = Momentary Push Botton Mode, and 1 = 2-state switch.
So once I set it to 3 I can use a regular push button for on/off and hold for dimming.
So today I can use these dimmers and only need the Indigo integration to bring on the extra features and S2 input. And providing a GUI configuration menu.
I think that I could detect the S2 input with a Z-wave Raw package trigger but I have no time left today to test that out.
Also after the calibration param 131 was set to 20 causing the min dim level to be quite bright for these amazing Osram bulbs. I decrease that to 8 and they barely light up, producing a very Halogen like glow. (I also have two fixtures with Osram Parathom PRO GU10 Dim bulbs that just look amazing with their CRI>90 and SDCM<3, I can wait to dim those with this little device).
elov offline
Sat May 06, 2017 12:04 pm
Thanks for the feedback. I've added including more complete support for this module to the feature request list.
Wed May 24, 2017 8:43 am
Jann offline
Does the support (for ZW111-C) that you say you put on the "more complete support" list include the ZW-111-A as well?
I just got an alert email saying it was available...
https://www.amazon.com/Aeotec-lighting- ... 06XC4CH98/
Fri May 26, 2017 12:59 am
CrazyFin offline
The difference between ZW111-A and ZW111-C is just the frequency for the Z-Wave that the device uses. If Indigo supports ZW111-A then it will also support ZW111-B and ZW111-C.
Read more at
https://aeotec.freshdesk.com/support/solutions/articles/6000027557-what-are-aeon-labs-product-codes-
ZW111-A is the US version (908.42MHz)
ZW111-B is the AU version (921.42MHz)
ZW111-C is the EU version (868.42MHz)
Thu Jun 01, 2017 12:01 am
thatdamncat offline
+1 on this device.
It's great, and just what I've been needing since I have no neutral in my switch gangs!
It's working well for me actually. I set parameter 120 (to 1) and 125 (to 1 because I found the dimming too slow).
Thu Nov 09, 2017 7:26 pm
Indigo 7.1.1 is now available for download and supports the Aeotec Nano Dimmer (ZW111).
Mon Nov 20, 2017 10:25 am
elov offline
Works great!
Though maybe my early ZW111 has a firmware issue since I still need to set S1/S2 switch mode to 2 State, while its a physical push button that i use as I mentioned earlier.
Anyone else having the same issue?
Fri Dec 01, 2017 5:23 pm
CrazyFin offline
I have exactly the same issue too!
I installed 2 of the Nano Dimmers tonight and I was sooooo confused when I initially configured parameter 120 (S1 switch type) to 1 which is supposed to be Push Button (and what I have as buttons) but then the lights are on all the time and they only go off while keeping the push button pressed.
As soon as I changed parameter 120 to 3 which means S1 = 2 way switch then my push button works fine!? :shock:
I am not sure if this is a firmware issue or if the manual is incorrect?
Indigo Z-Wave Version: 2.0.111
Node ID: 104
Model: Nano Dimmer (ZW111)
Model ID: 0003006F
Model Definition Version: 1
Library Type: 3
Neighbors: 2, 3, 4, 6, 7, 8, 12, 23, 24, 26, 27, 29, 30, 31, 32, 39, 49, 59, 60, 64, 65, 68
Config Values: 131:20 132:99 80:3 3:1 20:0 4:1 90:0 91:100 92:99 101:3 102:0 103:0 124:3 111:3600 112:600 113:600 120:3 121:3 123:3 252:0
Sat Dec 02, 2017 5:20 pm
CrazyFin offline
I think I have found the latest (June 1st 2017) Engineering Document for the Nano Dimmer. Found it at Vesternet:
http://www.vesternet.com/downloads/dl/file/id/1877/product/2828/z_wave_plus_aeotec_nano_dimmer_engineering_sheet.pdf
I can see in that document that the proper value for push button on S1 and S2 is 3 which we already have guessed so the user manual is indeed wrong.
Sat Dec 09, 2017 1:15 pm
Thanks for tracking down this one. Indigo 7.1.2 will have the correct configuration options (labels) listed in the UI for the ZW111.
Fri Sep 28, 2018 12:44 pm
Indigo 7.2.0 is now available for download and should have the correct configuration options (labels) listed in the UI for the ZW111.
