Can't get Z-Wave to work on new Mac Mini
Posted: Thu Apr 13, 2017 6:52 pm
For several years, now, I have successfully run Z-Wave devices using Indigo 6.x. However my old Mac Mini won't run an OS that Indigo 7.x will run on, so I was forced to upgrade. Now I have a "new" Mac Mini (Late 2014). I ported everything over from the old Mini using setup assistant and a clone of the old startup disk. After further configuration Indigo 6 came up running. Connection to the Insteon controller worked fine, but there were multiple errors trying to connect to the Z-stick. I have a Z-Stick S2, Model DSA002203-ZWUS. I installed the Driver, Silicon Labs VCP Driver Installer.mpkg dated Tuesday, January 27, 2015 at 3:35 PM and restarted. No luck. The log filled with stuff like this:
I seem to recall having the same trouble the last time I tried to migrate to a new Mini a couple of years ago. Any suggestions about how to debug this? I mean besides https://xkcd.com/1822/
- Code: Select all
Z-Wave Debug stopped zwave packet parser thread
Z-Wave Debug serial port communication error: device reports readiness to read but returned no data (device disconnected)
Z-Wave Debug Z-Wave might be disconnected
Z-Wave Debug silently retrying serial connection every 5.0 seconds
Z-Wave Debug starting serial connection loop
Z-Wave Debug starting zwave packet parser thread
Z-Wave Debug SENT getVersion: 01 03 00 15 E9
Error unknown command bytes received E0 E0 (ignoring)
Z-Wave Error rcvd unexpected bytes (sent ACK): E0
Z-Wave Debug SENT getVersion: 01 03 00 15 E9 (re-sent because no response)
- Code: Select all
P210x Macintosh OSX VCP Driver v4 Release Notes
Copyright (C) 2015 Silicon Laboratories, Inc.
This release contains the following components:
* SiLabsUSBDriverDisk.dmg - Image containing the VCP Driver Installer
* ReleaseNotes.txt (this file)
Known Issues and Limitations
This release includes the Macintosh OSX driver for the Intel and
PowerPC Platforms versions 10.4, 10.5, 10.6, 10.7, 10.8, 10.9, and 10.10.
