There have been a number of posts about various Kwikset 91x locks. Although the lock operates its motorized bolt from the external keypad, commands from Indigo indicate that the lock is changing states from 'locked' to 'unlocked', however, the bolt motor does not operate and the bolt doesn't move. There is no mechanical or fit problem, since the motorized bolt operates from the keypad with the proper code.
1. The state in Indigo does not properly indicate the actual state of the lock, whether it is set manually from the lock lever or the keypad, even when a status request is issued from the Indigo client
2. Requests for status will not show a status change in Indigo. I.e., if the lock shows 'locked', all subsequent status requests will show 'locked', even if the physical state of the lock is unlocked. If the lock shows 'unlocked', all subsequent status requests will show 'unlocked', even if the physical state of the lock is 'locked'.
3. Requests issued from a mouse click in Indigo will typically show that an unlock command will change the state to unlocked in Indigo, but it doesn't actually activate the motorized bolt.
4. Requests issued from a mouse click in Indigo will typically show that a lock command will change the state to locked in Indigo, but it doesn't actually activate the motorized bolt.
I've tried deleting the device and excluding it, per the Indigo and Kwikset documentation, being careful to activate it with encryption, as suggested in the Forum, however, the lock still exhibits the behavior as shown in 1-4 above. I am attaching a log for the last attempt to resolve the problem. I occasionally get a 'no ack' error, but mostly, Indigo seems happy. Since I only have the single Z-wave device in my network (other than the Aeotec Z-Stick (Gen 5), which is physically connected to a USB port on my Mac, I did order an Aeotec Z-Wave repeater that I can plug in between the lock and the Mac with the connected Z-Stick, in case it's a matter of insufficient signal strength. I've also ordered a replacement for the Kwikset 916 deadbolt, just in case there is an electronic problem with the lock control.
Any input is welcome, since I plan to expand my system in the very near future and I was considering going primarily with Z-Wave, since it appears to be more of an open standard.
My control system uses a Mac Mini i7 Quad Core with 16 GB RAM, running the latest version of Indigo 7, the Z-Stick Gen 5, as well as a SmartHome 2412 Insteon Interface and two dual band repeaters, along with 2 Insteon power control devices (Switchlinks).
