Fibaro Double Switch 2 ( FGS223 )
Sun Mar 19, 2017 7:53 pm
kwijibo007 offline
Hi Matt/Jay
This is a 921.42 Australian module. Could you please add the definitions to an upcomming i7 release?
Z-Wave
Indigo Device "Dining Room Table Light" Z-Wave Properties:
Indigo Z-Wave Version: 2.0.68
Node ID: 5
Model: Relay Power Switch
Model ID: 02033000
Manufacturer: Fibaro System
Manufacturer ID: 010F
Protocol Version: 4.05
Application Version: 3.02
Model Definition Version: 0
Library Type: 3
Class Hierarchy: 04 : 10 : 01
Command Class Base: 25
Command Versions: 20v1 60v4 22v1 25v1 86v1 27v1 72v1 8Ev1 70v1 71v1 32v3 73v1 75v1 56v1 98v1 59v1 5Av1 5Bv1 7Av1 5Ev1 85v1
Multi-Endpoint Types: 1:(10 : 01), 2:(10 : 01)
Multi-Endpoint Classes: 1:[5E 86 25 85 59 8E 32], 2:[5E 86 25 85 59 8E 32]
Features: routing, beaming, security, energyMeter
Neighbors: 3, 4
Associations: 1:[1] 2:[] 3:[] 4:[] 5:[]
Config Values: - none -
Pete
Mon Mar 20, 2017 2:56 am
Colly offline
Re: Fibaro Double Switch 2 ( FGS223 )
Hi Pete,
I added 2 of these devices over the weekend and noticed that on first sync the model wasn't recognised. Once I did a resync it was then recognised as the correct model. One issue I haven't sorted yet is the fact I don't get status update in Indigo when the wall switch is used for S2. S1 works perfectly. Can you try a resync and also see if you can get status from S2 when switched locally?
Mon Mar 20, 2017 4:32 am
kwijibo007 offline
Hi Colly,
I've got a couple of these modules with Model ID: 0203300A which I've had for a while and work fine (both switches report their correct state). The model ID I posted above is 02033000. I synced it again as you suggested but it's still not recognised. I suspect that Indigo is missing the definition. Matt or Jay can hopefully confirm one way or the other.
As a matter of interest, what are the device IDs of your modules?
I was actually installing these at my friends house over the weekend and we've only connected one light to each of the two FGS223 we were working with. Unfortunately I can't confirm the second switch issue you mentioned. As soon as we have I'll report back.
Pete
Mon Mar 20, 2017 6:00 am
Colly offline
Pete,
Not at home at the minute so will confirm later as to the device ID's.
Mon Mar 20, 2017 2:58 pm
Colly offline
Hi Pete,
See below, you may be right. Model id is slightly different. We may let Matt/Jay enlighten us as to the differences!
Also for Matt/Jay - anything that I can do to get S2 status to update when switched by the wall switch? I have an older one, FGS222, which works perfectly.
Node ID: 46
Model: Double Switch 2 (FGS223)
Model ID: 02031000
Model Definition Version: 6
Library Type: 3
Neighbors: 13, 14, 15, 19, 22, 30, 38, 43, 44, 45
Config Values: 18:5 9:1 10:0 11:0 12:50 13:5 15:0 16:0 17:50 50:20 51:10 20:2 53:100 54:20 55:10 57:100 58:3600 59:3600 28:0 29:0
Thu Mar 23, 2017 9:48 am
Colly offline
Matt/Jay,
Any suggestions re the status update for S2?
Thu Mar 23, 2017 8:12 pm
I'll get the unknown model ID added to the next bug release build of Indigo (7.0.4).
For S2 updating, try manually adding associations for group #4 back to Indigo (Z-Wave Controller). If that doesn't work try group #5. Also turn on debug logging (via the Interfaces->Z-Wave->Configure... menu item) and capture what is shown when both S1 and S2 are controlled at the switch.
Sat Mar 25, 2017 4:15 pm
Colly offline
Hi Matt,
Sorry for the delay. I think I've captured what you need below. I tried adding associations as you suggested but didn't notice any improvement. The log output below is with the controller added to group 5.
S1 switched on and then off.
Z-Wave                          received "Kitchen Light" status update is on
   Z-Wave Debug                    queueing energy request of "046 - Kitchen Light" (activity detected)
   Z-Wave Debug                    RCVD requestMeterLevel: 01 0E 00 04 00 2E 08 32 02 21 32 01 D2 00 00 23
   Z-Wave Debug                    . .  requestMeterLevel: node 046, endpoint None, meterType 01, raw value 3201...
   Z-Wave Debug                    . .  requestMeterLevel: 46.6 W (float: 46.600000)
   Z-Wave                          received "Kitchen Light" power load to 46.6 W
   Z-Wave Debug                    polling status of node "046 - Kitchen Light" (post-activity energy request)
   Z-Wave Debug                    SENT requestMeterLevel: 01 0A 00 13 2E 03 32 01 00 25 71 AC
   Z-Wave Debug                    RCVD requestMeterLevel: 01 10 00 04 00 2E 0A 32 02 21 44 00 00 00 C0 00 00 5A
   Z-Wave Debug                    . .  requestMeterLevel: node 046, endpoint None, meterType 01, raw value 4400...
   Z-Wave Debug                    . .  requestMeterLevel: 1.92 kWh (float: 1.920000)
   Z-Wave Debug                    SENT requestMeterLevel: 01 0A 00 13 2E 03 32 01 10 25 72 BF
   Z-Wave Debug                    RCVD requestMeterLevel: 01 0E 00 04 00 2E 08 32 02 21 32 01 D0 00 00 21
   Z-Wave Debug                    . .  requestMeterLevel: 46.4 W (float: 46.400000)
   Z-Wave                          received "Kitchen Light" power load to 46.4 W
   Z-Wave Debug                    RCVD requestRelayStatus: 01 09 00 04 00 2E 03 25 03 00 F9
   Z-Wave Debug                    . .  requestRelayStatus: node 046, endpoint None, value 0
   Z-Wave                          received "Kitchen Light" status update is off
   Z-Wave Debug                    RCVD requestMeterLevel: 01 0E 00 04 00 2E 08 32 02 21 32 00 00 00 00 F0
   Z-Wave Debug                    . .  requestMeterLevel: node 046, endpoint None, meterType 01, raw value 3200...
   Z-Wave Debug                    . .  requestMeterLevel: 0.0 W (float: 0.000000)
   Z-Wave                          received "Kitchen Light" power load to 0.0 W
   Z-Wave Debug                    SENT requestMeterLevel: 01 0A 00 13 2E 03 32 01 00 25 73 AE
   Z-Wave Debug                    SENT requestMeterLevel: 01 0A 00 13 2E 03 32 01 10 25 74 B9
S2 switched on and then off
Z-Wave Debug                    RCVD dimmerSetLevel: 01 0A 00 04 08 2E 04 26 01 FF 00 0B
   Z-Wave Debug                    . .  dimmerSetLevel: node 046, endpoint None, value 255
   Z-Wave Debug                    RCVD dimmerSetLevel: 01 0A 00 04 00 2E 04 26 01 FF 00 03
   Z-Wave Debug                    RCVD dimmerSetLevel: 01 0A 00 04 08 2E 04 26 01 00 00 F4
   Z-Wave Debug                    . .  dimmerSetLevel: node 046, endpoint None, value 0
   Z-Wave Debug                    RCVD dimmerSetLevel: 01 0A 00 04 00 2E 04 26 01 00 00 FC
Mon Mar 27, 2017 8:37 pm
The event log for S2 isn't what I was expecting. Can you try the following:
1) Remove all association groups from the module that point back to the Z-Wave Controller.
2) Add back the association for group #1.
3) Toggle both S1 and S2 a 3 times, and copy/paste the Event Log results of each (independently so we know what log goes with what button toggle).
4) Remove association group #1, add association group #2.
5) Toggle both S1 and S2 a 3 times, and copy/paste the Event Log result of each (independently so we know what log goes with what button toggle).
...continue the same process for each association group up to #5
I'm hoping that the Event Log for one of those for S2 doesn't show an "endpoint None" as that is the best way for Indigo to differentiate between the different buttons.
Tue Mar 28, 2017 3:02 pm
Colly offline
Matt,
See attached file. I removed all associations and then added the controller back to group 1.
As requested I then copied 3 * S1 On and 3*S1 Off - I got as far as completing this for group 1 & 2, these are in the file. For S2 operations I am not getting anything in the log for group 1 & 2. I will continue with this and post results unless you think there is no point..
Fibaro_FGS223.txt
(21.6 KiB) Downloaded 172 times
Tue Mar 28, 2017 3:30 pm
Colly offline
Matt,
I should really just do as I'm told! :oops: :oops:
New file attached for groups 3 - 5. S2 is getting logged for group 4. Hope this is of some help to you.
Fibaro_FGS223_a.txt
(15.82 KiB) Downloaded 194 times
Fri Mar 31, 2017 4:53 pm
I did some more research on this. There are dozens and dozens of pages of forum/support posts about problems with the newer firmware versions of the FGS223 on other home automation platforms / hubs. Misery loves company I guess?
It looks like they changed the behavior of when the module sends out the endpoint encapsulated commands which are required for differentiating between S1 and S2. We might be able to work around this:
1) First, remove all associations (1 to 5) the module has back to the Z-Wave controller (if any) via the Z-Wave->Manage Associations dialog.
2) Next, use the Z-Wave->Send Raw Z-Wave Command menu command to send the following raw command to your FGS223:
0x8E 0x01 0x01 0x00 0x01 0x01
3) Capture Event Log snippets of both S1 and S2 toggles.
4) If S1 and/or S2 aren't updating correctly in Indigo, then again use the Z-Wave->Send Raw Z-Wave Command menu command to send both of these commands:
0x8E 0x01 0x02 0x00 0x01 0x01
0x8E 0x01 0x04 0x00 0x01 0x01
and again capture Event Log snippets of both S1 and S2 toggles.
Sat Apr 01, 2017 8:50 am
Colly offline
First command didn't work when sent to S1 device.
Sent 0x8E 0x01 0x02 0x00 0x01 0x01 to S1 device.
result with above command for Switching on S1:
   Z-Wave Debug                    SENT sendRawZwaveCommand: 01 11 00 13 2E 0A 60 0D 01 01 8E 01 02 00 01 01 25 F6 EA
   Z-Wave                          sent "Kitchen Light" raw command [8E 01 02 00 01 01]
   Z-Wave Debug                    RCVD multiEndPointPacket: 01 0D 00 04 00 2E 07 60 0D 01 01 20 01 FF 6C
   Z-Wave Debug                    . .  multiEndPointPacket: node 046, endPoint 1
   Z-Wave Debug                    RCVD relaySetLevel: 01 09 00 04 00 2E 03 20 01 FF FF
   Z-Wave Debug                    . .  relaySetLevel: node 046, endpoint 1, value 255
   Z-Wave Debug                    SENT requestMeterLevel: 01 0E 00 13 2E 07 60 0D 01 01 32 01 00 25 F7 47
   Z-Wave Debug                    RCVD multiEndPointPacket: 01 14 00 04 00 2E 0E 60 0D 01 01 32 02 21 44 00 00 01 61 00 00 97
   Z-Wave Debug                    RCVD requestMeterLevel: 01 10 00 04 00 2E 0A 32 02 21 44 00 00 01 61 00 00 FF
   Z-Wave Debug                    . .  requestMeterLevel: node 046, endpoint 1, meterType 01, raw value 4400...
   Z-Wave Debug                    . .  requestMeterLevel: 3.53 kWh (float: 3.530000)
   Z-Wave Debug                    SENT requestMeterLevel: 01 0E 00 13 2E 07 60 0D 01 01 32 01 10 25 F8 58
   Z-Wave Debug                    RCVD multiEndPointPacket: 01 12 00 04 00 2E 0C 60 0D 01 01 32 02 21 32 01 CF 00 00 4B
   Z-Wave Debug                    RCVD requestMeterLevel: 01 0E 00 04 00 2E 08 32 02 21 32 01 CF 00 00 FF
   Z-Wave Debug                    . .  requestMeterLevel: node 046, endpoint 1, meterType 01, raw value 3201...
   Z-Wave Debug                    . .  requestMeterLevel: 46.3 W (float: 46.300000)
   Z-Wave                          received "Kitchen Light" power load to 46.3 W
S1 Off:
-Wave Debug                    . .  relaySetLevel: node 046, endpoint 1, value 0
   Z-Wave Debug                    RCVD multiEndPointPacket: 01 0D 00 04 00 2E 07 60 0D 01 01 20 01 00 93
   Z-Wave Debug                    RCVD relaySetLevel: 01 09 00 04 00 2E 03 20 01 00 FF
   Z-Wave Debug                    . .  relaySetLevel: node 046, endpoint 1, value 0
   Z-Wave Debug                    SENT requestMeterLevel: 01 0E 00 13 2E 07 60 0D 01 01 32 01 00 25 FC 4C
   Z-Wave Debug                    SENT requestMeterLevel: 01 0E 00 13 2E 07 60 0D 01 01 32 01 10 25 FD 5D
   Z-Wave Debug                    RCVD multiEndPointPacket: 01 12 00 04 00 2E 0C 60 0D 01 01 32 02 21 32 00 00 00 00 85
   Z-Wave Debug                    RCVD requestMeterLevel: 01 0E 00 04 00 2E 08 32 02 21 32 00 00 00 00 FF
   Z-Wave Debug                    . .  requestMeterLevel: node 046, endpoint 1, meterType 01, raw value 3200...
S2 On/Off - no log entries
Sent 0x8E 0x01 0x04 0x00 0x01 0x01 to S1 device
S1 On:
Z-Wave Debug                    SENT sendRawZwaveCommand: 01 11 00 13 2E 0A 60 0D 01 01 8E 01 04 00 01 01 25 01 1B
   Z-Wave                          sent "Kitchen Light" raw command [8E 01 04 00 01 01]
   Z-Wave Debug                    RCVD multiEndPointPacket: 01 0D 00 04 08 2E 07 60 0D 01 01 20 01 FF 64
   Z-Wave Debug                    RCVD relaySetLevel: 01 09 00 04 08 2E 03 20 01 FF FF
   Z-Wave Debug                    SENT requestMeterLevel: 01 0E 00 13 2E 07 60 0D 01 01 32 01 00 25 02 B2
   Z-Wave Debug                    SENT requestMeterLevel: 01 0E 00 13 2E 07 60 0D 01 01 32 01 10 25 03 A3
   Z-Wave Debug                    RCVD multiEndPointPacket: 01 12 00 04 00 2E 0C 60 0D 01 01 32 02 21 32 01 D0 00 00 54
   Z-Wave Debug                    RCVD requestMeterLevel: 01 0E 00 04 00 2E 08 32 02 21 32 01 D0 00 00 FF
S1 Off:
   Z-Wave Debug                    RCVD multiEndPointPacket: 01 0D 00 04 08 2E 07 60 0D 01 01 20 01 00 9B
   Z-Wave Debug                    RCVD relaySetLevel: 01 09 00 04 08 2E 03 20 01 00 FF
   Sonos Error                     [Sat Apr  1 15:29:32 2017] ZonePlayer: Sonos Kitchen has fallen off the network.
   Sonos Error                     [Sat Apr  1 15:29:32 2017] Resubscription due to timeout for ZonePlayer: Sonos Kitchen
   Sonos Error                     [Sat Apr  1 15:29:32 2017] ZonePlayer: Sonos Master Bedroom has fallen off the network.
   Sonos Error                     [Sat Apr  1 15:29:32 2017] Resubscription due to timeout for ZonePlayer: Sonos Master Bedroom
   Z-Wave Debug                    SENT requestMeterLevel: 01 0E 00 13 2E 07 60 0D 01 01 32 01 00 25 04 B4
   Z-Wave Debug                    SENT requestMeterLevel: 01 0E 00 13 2E 07 60 0D 01 01 32 01 10 25 05 A5
S2 On/Off no log entries
Sent 0x8E 0x01 0x01 0x00 0x01 0x01 to S2 device, no log entries for S2 On/Off
S1 On
   Z-Wave Debug                    RCVD requestMeterLevel: 01 18 00 04 00 17 12 32 02 21 64 00 00 4B 5D 02 58 00 00 4B 5D 00 00 00 00 C9
   Z-Wave Debug                    . .  requestMeterLevel: node 023, endpoint None, meterType 01, raw value 6400...
   Z-Wave Debug                    . .  requestMeterLevel: 19.293 kWh (float: 19.293000)
   Z-Wave Debug                    RCVD requestMeterLevel: 01 18 00 04 00 17 12 32 02 21 74 00 00 00 00 00 00 00 00 00 00 00 00 00 00 83
   Z-Wave Debug                    . .  requestMeterLevel: node 023, endpoint None, meterType 01, raw value 7400...
   Z-Wave Debug                    . .  requestMeterLevel: 0.000 W (float: 0.000000)
   Z-Wave Debug                    SENT requestMeterLevel: 01 0E 00 13 2E 07 60 0D 01 01 32 01 00 25 08 B8
   Z-Wave Debug                    SENT requestMeterLevel: 01 0E 00 13 2E 07 60 0D 01 01 32 01 10 25 09 A9
S1 Off
   Z-Wave Debug                    SENT requestMeterLevel: 01 0E 00 13 2E 07 60 0D 01 01 32 01 00 25 0B BB
   Z-Wave Debug                    RCVD multiEndPointPacket: 01 14 00 04 00 2E 0E 60 0D 01 01 32 02 21 44 00 00 01 62 00 00 94
   Z-Wave Debug                    RCVD requestMeterLevel: 01 10 00 04 00 2E 0A 32 02 21 44 00 00 01 62 00 00 FF
   Z-Wave Debug                    . .  requestMeterLevel: 3.54 kWh (float: 3.540000)
   Z-Wave                          received "Kitchen Light" energy total to 3.54 kWh
   Z-Wave Debug                    SENT requestMeterLevel: 01 0E 00 13 2E 07 60 0D 01 01 32 01 10 25 0C AC
Sent 0x8E 0x01 0x02 0x00 0x01 0x01 to S2 device.
S2 On
   Z-Wave Debug                    RCVD multiEndPointPacket: 01 0D 00 04 08 2E 07 60 0D 02 01 20 01 FF 67
   Z-Wave Debug                    . .  multiEndPointPacket: node 046, endPoint 2
   Z-Wave Debug                    . .  relaySetLevel: node 046, endpoint 2, value 255
   Z-Wave                          received "Kicker" status update is on
   Z-Wave Debug                    RCVD multiEndPointPacket: 01 0D 00 04 00 2E 07 60 0D 02 01 20 01 FF 6F
   Z-Wave Debug                    SENT requestMeterLevel: 01 0E 00 13 2E 07 60 0D 01 02 32 01 00 25 0E BD
   Z-Wave Debug                    RCVD multiEndPointPacket: 01 14 00 04 00 2E 0E 60 0D 02 01 32 02 21 44 00 00 00 3D 00 00 C9
   Z-Wave Debug                    RCVD requestMeterLevel: 01 10 00 04 00 2E 0A 32 02 21 44 00 00 00 3D 00 00 FF
   Z-Wave Debug                    . .  requestMeterLevel: node 046, endpoint 2, meterType 01, raw value 4400...
   Z-Wave Debug                    . .  requestMeterLevel: 0.61 kWh (float: 0.610000)
   Z-Wave Debug                    SENT requestMeterLevel: 01 0E 00 13 2E 07 60 0D 01 02 32 01 10 25 0F AC
   Z-Wave Debug                    RCVD multiEndPointPacket: 01 12 00 04 00 2E 0C 60 0D 02 01 32 02 21 32 00 8E 00 00 08
   Z-Wave Debug                    RCVD requestMeterLevel: 01 0E 00 04 00 2E 08 32 02 21 32 00 8E 00 00 FF
   Z-Wave Debug                    . .  requestMeterLevel: node 046, endpoint 2, meterType 01, raw value 3200...
   Z-Wave Debug                    . .  requestMeterLevel: 14.2 W (float: 14.200000)
   Z-Wave                          received "Kicker" power load to 14.2 W
S2 Off
   Z-Wave Debug                    RCVD multiEndPointPacket: 01 0D 00 04 08 2E 07 60 0D 02 01 20 01 00 98
   Z-Wave Debug                    . .  relaySetLevel: node 046, endpoint 2, value 0
   Z-Wave                          received "Kicker" status update is off
   Z-Wave Debug                    RCVD multiEndPointPacket: 01 0D 00 04 00 2E 07 60 0D 02 01 20 01 00 90
   Z-Wave Debug                    SENT requestMeterLevel: 01 0E 00 13 2E 07 60 0D 01 02 32 01 00 25 10 A3
   Z-Wave Debug                    SENT requestMeterLevel: 01 0E 00 13 2E 07 60 0D 01 02 32 01 10 25 11 B2
   Z-Wave Debug                    RCVD multiEndPointPacket: 01 12 00 04 00 2E 0C 60 0D 02 01 32 02 21 32 00 00 00 00 86
   Z-Wave                          received "Kicker" power load to 0.0 W
S1 On
   Z-Wave Debug                    SENT requestMeterLevel: 01 0E 00 13 2E 07 60 0D 01 01 32 01 00 25 12 A2
   Z-Wave Debug                    SENT requestMeterLevel: 01 0E 00 13 2E 07 60 0D 01 01 32 01 10 25 13 B3
S1 Off
   Z-Wave Debug                    SENT requestMeterLevel: 01 0E 00 13 2E 07 60 0D 01 01 32 01 00 25 18 A8
   Z-Wave Debug                    SENT requestMeterLevel: 01 0E 00 13 2E 07 60 0D 01 01 32 01 10 25 19 B9
Sent 0x8E 0x01 0x04 0x00 0x01 0x01 to S2 device.
S2 On
   Z-Wave Debug                    SENT requestMeterLevel: 01 0E 00 13 2E 07 60 0D 01 02 32 01 00 25 1F AC
   Z-Wave Debug                    SENT requestMeterLevel: 01 0E 00 13 2E 07 60 0D 01 02 32 01 10 25 20 83
   Z-Wave Debug                    RCVD multiEndPointPacket: 01 12 00 04 00 2E 0C 60 0D 02 01 32 02 21 32 00 90 00 00 16
   Z-Wave Debug                    RCVD requestMeterLevel: 01 0E 00 04 00 2E 08 32 02 21 32 00 90 00 00 FF
   Z-Wave Debug                    . .  requestMeterLevel: 14.4 W (float: 14.400000)
   Z-Wave                          received "Kicker" power load to 14.4 W
S2 Off
   Z-Wave Debug                    SENT requestMeterLevel: 01 0E 00 13 2E 07 60 0D 01 02 32 01 00 25 21 92
   Z-Wave Debug                    SENT requestMeterLevel: 01 0E 00 13 2E 07 60 0D 01 02 32 01 10 25 22 81
S1 On
   Z-Wave Debug                    SENT requestMeterLevel: 01 0E 00 13 2E 07 60 0D 01 01 32 01 00 25 23 93
   Z-Wave Debug                    SENT requestMeterLevel: 01 0E 00 13 2E 07 60 0D 01 01 32 01 10 25 24 84
S1 Off
No log entries
Sat Apr 15, 2017 10:11 am
davinci offline
Ok, I have the same issue...
I can't manage to get an update on S2 if triggered manually. After a status request it is updated.
I removed all association from this switch, sent 0x8E 0x01 0x04 0x00 0x01 0x01 and resented. No luck...
Oh and when I remove all energy reporting by setting to 0, the log is flooded by this:
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 42 0A 32 02 21 44 00 00 00 01 00 00 F7
Z-Wave Debug . . requestMeterLevel: node 066, endpoint None, meterType 01, raw value 4400...
Z-Wave Debug . . requestMeterLevel: 0.01 kWh (float: 0.010000)
If I set only Switch 1 energy threshold to 100 it stops.
Sun Apr 16, 2017 2:28 pm
Just to follow-up, based on another thread it sounds like you did get it working after excluding it, re-including it, then removing the association and sending the raw command (0x8E 0x01 0x04 0x00 0x01 0x01). Is that correct?
We are looking at customizing the device definition for this module to automate sending that raw command during the sync process, but want to get verifications that does indeed get it working for you both.
