Matt,
Just to confirm it's working perfectly for me at the moment.
matt (support) wrote:davinci wrote:Ok, I have the same issue...
I can't manage to get an update on S2 if triggered manually. After a status request it is updated.
Just to follow-up, based on another thread it sounds like you did get it working after excluding it, re-including it, then removing the association and sending the raw command (0x8E 0x01 0x04 0x00 0x01 0x01). Is that correct?
We are looking at customizing the device definition for this module to automate sending that raw command during the sync process, but want to get verifications that does indeed get it working for you both.
Z-Wave Debug RCVD multiEndPointPacket: 01 0D 00 04 08 42 07 60 0D 01 01 20 01 FF 08
Z-Wave Debug . . multiEndPointPacket: node 066, endPoint 1
Z-Wave Debug RCVD relaySetLevel: 01 09 00 04 08 42 03 20 01 FF FF
Z-Wave Debug . . relaySetLevel: node 066, endpoint 1, value 255
Z-Wave Debug queueing energy request of "066 - Licht" (activity detected)
Z-Wave Debug RCVD multiEndPointPacket: 01 0D 00 04 00 42 07 60 0D 01 01 20 01 FF 00
Z-Wave Debug RCVD relaySetLevel: 01 09 00 04 00 42 03 20 01 FF FF
Z-Wave Debug polling status of node "066 - Licht" (post-activity energy request)
Z-Wave Debug SENT requestMeterLevel: 01 0E 00 13 42 07 60 0D 01 01 32 01 00 25 29 F5
Z-Wave Debug RCVD multiEndPointPacket: 01 14 00 04 00 42 0E 60 0D 01 01 32 02 21 44 00 00 00 02 00 00 99
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 42 0A 32 02 21 44 00 00 00 02 00 00 FF
Z-Wave Debug . . requestMeterLevel: node 066, endpoint 1, meterType 01, raw value 4400...
Z-Wave Debug . . requestMeterLevel: 0.02 kWh (float: 0.020000)
Z-Wave Debug SENT requestMeterLevel: 01 0E 00 13 42 07 60 0D 01 01 32 01 10 25 2A E6
Z-Wave Debug RCVD multiEndPointPacket: 01 12 00 04 00 42 0C 60 0D 01 01 32 02 21 32 01 79 00 00 91
Z-Wave Debug RCVD requestMeterLevel: 01 0E 00 04 00 42 08 32 02 21 32 01 79 00 00 FF
Z-Wave Debug . . requestMeterLevel: node 066, endpoint 1, meterType 01, raw value 3201...
Z-Wave Debug . . requestMeterLevel: 37.7 W (float: 37.700000)
Z-Wave Debug RCVD sensorSetLevel: 01 09 00 04 00 26 03 20 01 00 F6
Z-Wave Debug . . sensorSetLevel: node 038, endpoint None, cmdClass 20, value 0
Z-Wave Debug filtering duplicate command -- old: 30, 0, 0, new: 20, 0, 0 (0.0010 secs)
Z-Wave Debug RCVD multiEndPointPacket: 01 0D 00 04 08 42 07 60 0D 01 01 20 01 00 F7
Z-Wave Debug RCVD relaySetLevel: 01 09 00 04 08 42 03 20 01 00 FF
Z-Wave Debug . . relaySetLevel: node 066, endpoint 1, value 0
Z-Wave Debug RCVD multiEndPointPacket: 01 0D 00 04 00 42 07 60 0D 01 01 20 01 00 FF
Z-Wave Debug RCVD relaySetLevel: 01 09 00 04 00 42 03 20 01 00 FF
Z-Wave Debug SENT requestMeterLevel: 01 0E 00 13 42 07 60 0D 01 01 32 01 00 25 2B F7
Z-Wave Debug SENT requestMeterLevel: 01 0E 00 13 42 07 60 0D 01 01 32 01 10 25 2C E0
Z-Wave Debug RCVD multiEndPointPacket: 01 12 00 04 00 42 0C 60 0D 01 01 32 02 21 32 00 00 00 00 E9
Z-Wave Debug RCVD requestMeterLevel: 01 0E 00 04 00 42 08 32 02 21 32 00 00 00 00 FF
Z-Wave Debug . . requestMeterLevel: node 066, endpoint 1, meterType 01, raw value 3200...
Z-Wave Debug . . requestMeterLevel: 0.0 W (float: 0.000000)
Indigo Z-Wave Version: 2.0.68
Node ID: 66
Model: Double Switch 2 (FGS223)
Model ID: 02031000
Manufacturer: Fibaro System
Manufacturer ID: 010F
Protocol Version: 4.05
Application Version: 3.02
Model Definition Version: 6
Library Type: 3
Class Name: Relay Power Switch
Class Hierarchy: 04 : 10 : 01
Command Class Base: 25
Command Versions: 20v1 60v4 22v1 25v1 86v1 27v1 72v1 8Ev1 70v1 71v1 32v3 73v1 75v1 56v1 98v1 59v1 5Av1 5Bv1 7Av1 5Ev1 85v1
Multi-Endpoint Types: 1:(10 : 01), 2:(10 : 01)
Multi-Endpoint Classes: 1:[5E 86 25 85 59 8E 32], 2:[5E 86 25 85 59 8E 32]
Features: routing, beaming, security, energyMeter
Neighbors: 4, 5, 6, 11, 12, 14, 31, 32, 40, 57, 58, 59, 60, 67
Associations: 1:[] 2:[] 3:[] 4:[] 5:[]
Config Values: 18:5 9:1 10:0 11:0 12:50 13:5 15:0 16:0 17:50 50:0 51:0 20:2 53:100 54:0 55:0 57:0 58:0 59:0 28:0 29:0
Syncing - retrieved manufacture and model names: Fibaro System - 010F, Double Switch 2 (FGS223) - 02031000
Z-Wave Syncing - retrieved protocol version 4.05, app version 3.02
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Relay Switch : Relay Power Switch (04 : 10 : 01, base 25)
Z-Wave Syncing - retrieved command classes: 20v1 60v4 22v1 25v1 86v1 27v1 72v1 8Ev1 70v1 71v1 32v3 73v1 75v1 56v1 98v1 59v1 5Av1 5Bv1 7Av1 5Ev1 85v1
Z-Wave Syncing - retrieved encrypt commands: - none -
Z-Wave Syncing - retrieved capabilities: routing, beaming, security
Z-Wave Syncing - retrieved multi-endpoint types: 1:(10 : 01), 2:(10 : 01)
Z-Wave Syncing - retrieved multi-endpoint classes: 1:[5E 86 25 85 59 8E 32], 2:[5E 86 25 85 59 8E 32]
Z-Wave Syncing - retrieved group 1 associations: [1]
Z-Wave Syncing - retrieved group 2 associations: []
Z-Wave Syncing - retrieved group 3 associations: []
Z-Wave Syncing - retrieved group 4 associations: []
Z-Wave Syncing - retrieved group 5 associations: []
Z-Wave Syncing - group 1 association to interface already exists (skipping)
Z-Wave Syncing - retrieved parameter 20 "Switch type" is 2 "Toggle Momentary"
Z-Wave Syncing - retrieved parameter 10 "Switch 1 mode" is 0 "Normal"
Z-Wave Syncing - retrieved parameter 11 "Switch 1 behavior" is 0 "Cancel Delay or Auto Mode"
Z-Wave Syncing - retrieved parameter 28 "Switch 1 scenes" is 0 "Disabled"
Z-Wave Syncing - retrieved parameter 12 "Switch 1 duration" is 50 seconds
Z-Wave Syncing - retrieved parameter 13 "Switch 1 flash" is 5 * 100 milliseconds
Z-Wave Syncing - retrieved parameter 50 "Switch 1 power threshold" is 0 %
Z-Wave Syncing - retrieved parameter 51 "Switch 1 power delay" is 0 seconds
Z-Wave Syncing - retrieved parameter 53 "Switch 1 energy threshold" is 100 * 0.01 kWh
Z-Wave Syncing - retrieved parameter 15 "Switch 2 mode" is 0 "Normal"
Z-Wave Syncing - retrieved parameter 16 "Switch 2 behavior" is 0 "Cancel Delay or Auto Mode"
Z-Wave Syncing - retrieved parameter 29 "Switch 2 scenes" is 0 "Disabled"
Z-Wave Syncing - retrieved parameter 17 "Switch 2 duration" is 50 seconds
Z-Wave Syncing - retrieved parameter 18 "Switch 2 flash" is 5 * 100 milliseconds
Z-Wave Syncing - retrieved parameter 54 "Switch 2 power threshold" is 0 %
Z-Wave Syncing - retrieved parameter 55 "Switch 2 power delay" is 0 seconds
Z-Wave Syncing - retrieved parameter 57 "Switch 2 energy threshold" is 0 * 0.01 kWh
Z-Wave Syncing - retrieved parameter 58 "Periodic power reports" is 0 seconds
Z-Wave Syncing - retrieved parameter 59 "Periodic energy reports" is 0 seconds
Z-Wave Syncing - retrieved parameter 9 "Power up to last known state" is true
Z-Wave Syncing - complete
Z-Wave sent "Licht S1" status request
Z-Wave sent "Licht S1" energy status request
Z-Wave sent "Licht S2" status request
Z-Wave sent "Licht S2" energy status request
noel1983 wrote:However, I can't see the scene commands now which I like to have as they show me when the lights have been manually switched on using the switch vs motion or other triggers.
noel1983 wrote:Just had the same issue, is mostly resolved by the steps above, I can now see the devices coming on and off in the logs when the switches are used.
