- Posted on
Mon Mar 13, 2017 3:15 am
MarkZ
offline
Hi Matt,
I tried a complete delete and started from scratch.
Unfortunately - exactly the same result.
It quite happily updates when requested but refuses to without a request.
Z-Wave Indigo Device "Garage Electricity - Meter Total" Z-Wave Properties:
Indigo Z-Wave Version: 2.0.76
Node ID: 111
Model: Home Energy Monitor (ZW095)
Model ID: 0002005F
Manufacturer: Aeon Labs
Manufacturer ID: 0086
Protocol Version: 3.92
Application Version: 1.33
Model Definition Version: 1
Library Type: 3
Class Name: Simple Meter
Class Hierarchy: 04 : 31 : 01
Command Class Base: 32
Command Versions: 20v1 85v1 86v1 72v1 70v1 32v4 73v1 56v1 98v1 59v1 7Av1 5Ev1
Features: routing, beaming, security, energyMeter
Neighbors: 13, 14, 20, 21, 22, 25, 26, 35, 38, 42, 82, 86, 88, 89, 90, 92, 93, 94, 96
Associations: 1:[1]
Config Values: 3:0 4:50 5:50 6:50 8:10 9:10 10:10 101:3 102:3 103:3 111:120 112:120 113:120 252:0
and when asked to update returns:
Z-Wave sent "Garage Electricity - Meter Total" energy status request
Z-Wave Debug SENT requestMeterLevel: 01 0A 00 13 6F 03 32 01 00 25 80 1C
Z-Wave Debug RCVD requestMeterLevel: 01 15 00 04 00 6F 0F 32 02 21 64 00 00 11 E4 00 04 00 00 11 E4 00 FF
Z-Wave Debug . . requestMeterLevel: node 111, endpoint None, meterType 01, raw value 6400...
Z-Wave Debug . . requestMeterLevel: 4.580 kWh (float: 4.580000)
Z-Wave received "Garage Electricity - Meter Total" energy total to 4.580 kWh
Z-Wave Debug SENT requestMeterLevel: 01 0A 00 13 6F 03 32 01 10 25 81 0D
Z-Wave Debug Optimizing - waiting for neighbor find to complete
Z-Wave Debug RCVD requestMeterLevel: 01 11 00 04 00 6F 0B 32 02 21 74 00 06 BE 69 00 00 00 3A
Z-Wave Debug . . requestMeterLevel: node 111, endpoint None, meterType 01, raw value 7400...
Z-Wave Debug . . requestMeterLevel: 441.961 W (float: 441.961000)
Z-Wave received "Garage Electricity - Meter Total" power load to 441.961 W
Any ideas?
Cheers
MarkZ
