Aeonlabs Home Energy Monitor not syncing?
Fri Mar 10, 2017 8:26 am
MarkZ offline
Re: Aeonlabs Home Energy Monitor not syncing?
Hi Martin,
Thanks for the idea, I've set the interval to 120S unfortunately nothing changed, I don't get any updates.
I think I'll try a complete reset and add again.
Cheers
MarkZ
Mon Mar 13, 2017 3:15 am
MarkZ offline
Aeonlabs ZW095 Home Energy Monitor not updating?
Hi Matt,
I tried a complete delete and started from scratch.
Unfortunately - exactly the same result.
It quite happily updates when requested but refuses to without a request.
Z-Wave Indigo Device "Garage Electricity - Meter Total" Z-Wave Properties:
Indigo Z-Wave Version: 2.0.76
Node ID: 111
Model: Home Energy Monitor (ZW095)
Model ID: 0002005F
Manufacturer: Aeon Labs
Manufacturer ID: 0086
Protocol Version: 3.92
Application Version: 1.33
Model Definition Version: 1
Library Type: 3
Class Name: Simple Meter
Class Hierarchy: 04 : 31 : 01
Command Class Base: 32
Command Versions: 20v1 85v1 86v1 72v1 70v1 32v4 73v1 56v1 98v1 59v1 7Av1 5Ev1
Features: routing, beaming, security, energyMeter
Neighbors: 13, 14, 20, 21, 22, 25, 26, 35, 38, 42, 82, 86, 88, 89, 90, 92, 93, 94, 96
Associations: 1:[1]
Config Values: 3:0 4:50 5:50 6:50 8:10 9:10 10:10 101:3 102:3 103:3 111:120 112:120 113:120 252:0
and when asked to update returns:
Z-Wave sent "Garage Electricity - Meter Total" energy status request
Z-Wave Debug SENT requestMeterLevel: 01 0A 00 13 6F 03 32 01 00 25 80 1C
Z-Wave Debug RCVD requestMeterLevel: 01 15 00 04 00 6F 0F 32 02 21 64 00 00 11 E4 00 04 00 00 11 E4 00 FF
Z-Wave Debug . . requestMeterLevel: node 111, endpoint None, meterType 01, raw value 6400...
Z-Wave Debug . . requestMeterLevel: 4.580 kWh (float: 4.580000)
Z-Wave received "Garage Electricity - Meter Total" energy total to 4.580 kWh
Z-Wave Debug SENT requestMeterLevel: 01 0A 00 13 6F 03 32 01 10 25 81 0D
Z-Wave Debug Optimizing - waiting for neighbor find to complete
Z-Wave Debug RCVD requestMeterLevel: 01 11 00 04 00 6F 0B 32 02 21 74 00 06 BE 69 00 00 00 3A
Z-Wave Debug . . requestMeterLevel: node 111, endpoint None, meterType 01, raw value 7400...
Z-Wave Debug . . requestMeterLevel: 441.961 W (float: 441.961000)
Z-Wave received "Garage Electricity - Meter Total" power load to 441.961 W
Any ideas?
Cheers
MarkZ
Wed Mar 15, 2017 7:45 am
I'm afraid I don't know why it won't send out the broadcasts. As part of your delete and re-add did you perform a full factory reset of the module? Most modules factory reset when you exclude them from the Z-Stick, but not all. I don't recall what the steps are for this module so you would need to check the manual to make sure it is being fully reset.
Wed Mar 15, 2017 8:21 am
CrazyFin offline
@MarkZ: Could it be a firmware issue with the firmware version you have on your ZW095?
You seem to have:
Z-Wave Indigo Device "Garage Electric - Meter Total" Z-Wave Properties:
Node ID: 104
Model ID: 0002005F
While @Gusten who has updated working at his configured interval of 120 seconds has the following firmware and app version:
Z-Wave Syncing - retrieved manufacture and model names: Aeon Labs - 0086, Home Energy Monitor (ZW095) - 0002005F
Z-Wave Syncing - retrieved protocol version 4.34, app version 1.00
With params 111, 112 and 113 set to for example 120 seconds, do you not even see any automatic updates in the debug log?
(I usually prefer to have for example 111 set to 60 seconds and the two others at longer intervals so that I do not get updates for all three groups at the same time.)
I have seen similar issues with other devices and manufacturers where broadcast messages not being sent out automatically due to firmware bug.
I would create a ticket at Aeotec help desk and mention that you do not get broadcast messages out from your device and let them know you have protocol version 3.92 and app version 1.33 and ask them if there is a firmware upgrade available.
Thu Mar 16, 2017 11:10 am
MarkZ offline
Hi
I'm pretty sure I actually did a reset its a case of holding the button pressed for ten seconds.
I've had 111 set to 120 seconds and 112 & 113 to 600 seconds - I'm single phase so only have one clamp.
I'll raise a ticket with Aeotec as you suggest.
Thanks for your help.
Cheers
MarkZ
Sun Oct 22, 2017 1:39 pm
Berts offline
Hi Mark,
I have the same problem. Did you get reaction from Aeotec?
Is your problem solved now?
Thu Nov 09, 2017 11:18 am
Indigo 7.1.1 is now available for download and now more completely supports this module (as describe above).
Fri Feb 22, 2019 2:05 pm
Dual offline
Check out my post for my success story with this meter:
AEOTEC Aeon Labs Home Energy Meter Gen5 ZW095 communicating
