siclark wrote:... However, it takes up to 5 seconds holding the switch down for Indigo to receive the notification, which as I want to use it to toggle other lights on or off is not going to be acceptable to my users (aka my wife) .
Should it be that slow?...
Unfortunately yes, that is my experience as well with these Qubino modules. See my post in this thread:
http://forums.indigodomo.com/viewtopic.php?p=143301#p143301 where I wrote
"Note that the updates for I2 and I3 can be 4-5 seconds delayed in both the GUI and log. This is NOT an Indigo issue but rather a poor firmware design by Qubino. I do see the same delays with other platforms as well (OpenZwave Controller Panel for example)"
If I understand you correctly you are using a 3-way switch connected to I1 and I3? That is actually wrong, if you want to use 3-way switch then it should be connected to I1 and I2. Input 3 is meant to be used with for example a normally open/normally closed sensor like a door sensor or a motion sensor.
See the manual at for example http://www.vesternet.com/downloads/dl/file/id/1323/product/1559/z_wave_qubino_flush_dimmer_plus_user_manual_v1_5.pdf where you can see that I3 is not used for push buttons or bi stable buttons. Only I1 and I2 is configurable for buttons. See also under parameter 20 description where it says:
Parameter no. 20 – Enable/Disable 3way switch.
Dimming is done by push button or switch connected to I1 (by default). Enabling 3way switch, dimming can be controlled by push button or switch connected to I1 and I2.
If you want to trigger turn on of another lamp controlled by another module when you trigger on the ZMNHDDx then you should instead use direct association method and set up a direct association between the ZMNHDDx (as the controlling device) and the other device(s) you want to control being the controlled devices. This is the way I have my system setup. You will have minimal delay with this method.
