- Posted on
Mon Sep 25, 2017 2:28 pm
siclark
offline
I have a similar problem on recently installed Qubino dimmers. Amazingly I got both wired in first time (only took an hour to get the wiring neat enough to get them both to fit inside a double gang socket. I have them controlled with a 3-position momentary switch, using the parameter 20 from the GUI and have a push switch connnected to I3 on both.
I updated the receive notifications for I3 and excluded and included again, and Indigo recognises the switches being pressed, albeit on I2 but that is fine.
However, it takes up to 5 seconds holding the switch down for Indigo to receive the notification, which as I want to use it to toggle other lights on or off is not going to be acceptable to my users (aka my wife) .
Should it be that slow?
This is the sync details from when I included it.
Z-Wave Syncing - started for "020 - Dimmable Power Switch"
Z-Wave Syncing - retrieved module neighbors list: 2, 3, 4, 6, 8, 13, 18
Z-Wave Syncing - assigning return route to "020 - Dimmable Power Switch"
Z-Wave Syncing - retrieved manufacture and model names: Qubino - 0159, Flush Micro Dimmer (ZMNHDD) - 00010051
Z-Wave Syncing - retrieved protocol version 4.05, app version 3.05
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Mulitlevel Switch : Dimmable Power Switch (04 : 11 : 01, base 26)
Z-Wave Syncing - retrieved command classes: 20v1 85v1 86v1 8Ev1 59v1 5Av1 5Ev1 60v4 30v1 25v1 26v3 27v1 72v1 70v1 71v1 32v4 73v1
Z-Wave Syncing - retrieved capabilities: routing, beaming
Z-Wave Syncing - retrieved multi-endpoint types: 1:(11 : 01), 2:(20 : 00)
Z-Wave Syncing - retrieved multi-endpoint classes: 1:[5E 85 8E 59 27 25 26 32 71], 2:[5E 85 8E 59 30 71]
Z-Wave Syncing - retrieved group 1 associations: []
Z-Wave Syncing - retrieved group 3 associations: []
Z-Wave Syncing - retrieved group 4 associations: []
Z-Wave Syncing - retrieved group 5 associations: []
Z-Wave Syncing - retrieved group 6 associations: []
Z-Wave Syncing - retrieved group 7 associations: []
Z-Wave Syncing - retrieved group 8 associations: []
Z-Wave Syncing - retrieved group 9 associations: []
Z-Wave Syncing - retrieved group 10 associations: []
Z-Wave Syncing - retrieved group 11 associations: []
Z-Wave Syncing - added group 1 multi association to interface
Z-Wave Syncing - added group 4 multi association to interface
Z-Wave Syncing - added group 11 multi association to interface
Z-Wave Syncing - retrieved parameter 30 "Power up state" is 0 "Last State"
Z-Wave Syncing - retrieved parameter 100 "Input 2 notifications" is 0 "Disabled"
Z-Wave Syncing - retrieved parameter 101 "Input 3 notifications" is 9 "Enabled"
Z-Wave Syncing - retrieved parameter 1 "Input 1 mode" is 0 "Momentary"
Z-Wave Syncing - retrieved parameter 2 "Input 2 mode" is 0 "Momentary"
Z-Wave Syncing - retrieved parameter 3 "Input 2 type" is 0 "Normally Open"
Z-Wave Syncing - retrieved parameter 4 "Input 3 type" is 0 "Normally Open"
Z-Wave Syncing - retrieved parameter 20 "Enable 3-way switch mode" is true
Z-Wave Syncing - retrieved parameter 21 "Enable double-click to maximum brightness" is true
Z-Wave Syncing - retrieved parameter 60 "Minimum value" is 1
Z-Wave Syncing - retrieved parameter 61 "Maximum value" is 99
Z-Wave Syncing - retrieved parameter 65 "Button tap duration" is 100 * 10 milliseconds
Z-Wave Syncing - retrieved parameter 66 "Button down duration" is 3 seconds
Z-Wave Syncing - retrieved parameter 110 "Temperature offset" is 32536 * 0.1 degrees
Z-Wave Syncing - retrieved parameter 120 "Temperature sensitivity" is 5 * 0.1 degrees
Z-Wave Syncing - changed device "Kitchen spots 1" address from undefined to 020
Z-Wave Syncing - changed device "014 - Input 2" address from undefined to 020
Z-Wave Syncing - changed device "014 - Input 3" address from undefined to 020
Z-Wave Syncing - changed device "014 - Temperature" address from undefined to 020
Z-Wave Syncing - complete
This is the zwave debug log showing the switch connected to I3 (end point 2) being pressed. I had to hold if for 5 seconds to see anything. Second is the results from turning off the light using the other switch connected to I1&I2. That responds immediately.
Z-Wave Debug RCVD multiEndPointPacket: 01 0D 00 04 00 15 07 60 0D 02 01 30 03 FF 46
Z-Wave Debug . . multiEndPointPacket: node 021, endPoint 2
Z-Wave Debug RCVD requestBinarySensorStatus: 01 09 00 04 00 15 03 30 03 FF FF
Z-Wave Debug . . requestBinarySensorStatus: node 021, endpoint 2, value 255
Z-Wave Debug RCVD requestMeterLevel: 01 18 00 04 00 02 12 32 02 21 64 00 00 14 FD 02 58 00 00 14 FD 00 00 00 00 DC
Z-Wave Debug . . requestMeterLevel: node 002, endpoint None, meterType 01, raw value 6400...
Z-Wave Debug . . requestMeterLevel: 5.373 kWh (float: 5.373000)
Z-Wave Debug RCVD requestMeterLevel: 01 18 00 04 00 02 12 32 02 21 74 00 00 00 00 00 00 00 00 00 00 00 00 00 00 96
Z-Wave Debug . . requestMeterLevel: node 002, endpoint None, meterType 01, raw value 7400...
Z-Wave Debug . . requestMeterLevel: 0.000 W (float: 0.000000)
Z-Wave Debug RCVD multiEndPointPacket: 01 13 00 04 00 15 0D 60 0D 02 01 71 05 00 00 00 FF 07 08 00 1A
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 0F 00 04 00 15 09 71 05 00 00 00 FF 07 08 00 FF
Z-Wave Debug . . requestAlarmSensorStatus: node 021, endpoint 2, cmdClass 71, type 0, value 0, classSubKey 710000
Z-Wave Debug . . requestAlarmSensorStatus: typeExt 7, valueExt 8, classSubKeyExt 7100000708
Z-Wave Debug RCVD multiEndPointPacket: 01 0D 00 04 00 15 07 60 0D 02 01 30 03 00 B9
Z-Wave Debug RCVD requestBinarySensorStatus: 01 09 00 04 00 15 03 30 03 00 FF
Z-Wave Debug . . requestBinarySensorStatus: node 021, endpoint 2, value 0
Z-Wave Debug RCVD multiEndPointPacket: 01 13 00 04 00 15 0D 60 0D 02 01 71 05 00 00 00 FF 07 00 00 12
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 0F 00 04 00 15 09 71 05 00 00 00 FF 07 00 00 FF
Z-Wave Debug . . requestAlarmSensorStatus: typeExt 7, valueExt 0, classSubKeyExt 7100000700
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 08 0A 32 02 21 44 00 00 58 A4 00 00 40
Z-Wave Debug . . requestMeterLevel: node 008, endpoint None, meterType 01, raw value 4400...
Z-Wave Debug . . requestMeterLevel: 226.92 kWh (float: 226.920000)
Turning off light
Z-Wave Debug RCVD multiEndPointPacket: 01 0E 00 04 00 14 08 60 0D 01 01 26 01 00 00 A3
Z-Wave Debug . . multiEndPointPacket: node 020, endPoint 1
Z-Wave Debug RCVD dimmerSetLevel: 01 0A 00 04 00 14 04 26 01 00 00 FF
Z-Wave Debug . . dimmerSetLevel: node 020, endpoint 1, value 0
Z-Wave Debug RCVD multiEndPointPacket: 01 0D 00 04 00 14 07 60 0D 01 01 26 03 00 AD
Z-Wave Debug RCVD requestDimmerStatus: 01 09 00 04 00 14 03 26 03 00 FF
Z-Wave Debug . . requestDimmerStatus: node 020, endpoint 1, value 0
Z-Wave Debug RCVD multiEndPointPacket: 01 18 00 04 00 14 12 60 0D 01 01 32 02 21 34 00 00 00 00 00 00 00 00 00 00 AD
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 14 0E 32 02 21 34 00 00 00 00 00 00 00 00 00 00 FF
Z-Wave Debug . . requestMeterLevel: node 020, endpoint 1, meterType 01, raw value 3400...
Z-Wave Debug . . requestMeterLevel: 0.0 W (float: 0.000000)
