No commands at all are generated when I twist the interior deadbolt handle.
Indigo Z-Wave Version: 2.0.68
Node ID: 30
Model: Keypad Door Lock
Model ID: 634B5044
Manufacturer: Schlage
Manufacturer ID: 003B
Protocol Version: 2.64
Application Version: 43.37
Model Definition Version: 0
Library Type: 6
Class Name: Keypad Door Lock
Class Hierarchy: 04 : 40 : 03
Command Class Base: 62
Command Versions: 80v1 85v1 86v1 98v1 20v1 62v1 63v1 70v1 71v1 72v1 73v1
Encryption Status: Enabled for Commands 80 20 62 63 86 70 71
Features: routing, battery, beaming, security, frequentWaking
Neighbors: 4, 7, 8, 9, 10, 11, 12, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 27, 28, 33
Associations: 1:[1] 2:[]
Config Values: - none -
