TKB TZ69E Wall Plug Switch/Meter - GEN5 Module Definition
Sat Jan 28, 2017 10:20 am
CliveS offline
UpDate 8 Nov 2017 - As of Indigo v7.1.1 the TKB TZ69E is now supported and working without the logging errors reported below
This seems to be identical to the TZ88E except it now has a blue LED instead of a red LED on the front.
I did add it to the Device Report when V7 came out but it still has not been updated so not sure if the report from the GUI is working.
Z-Wave Properties:
Indigo Z-Wave Version: 2.0.68
Node ID: 8
Model: Relay Power Switch
Model ID: 00040002
Manufacturer: TKBHome
Manufacturer ID: 0118
Protocol Version: 4.05
Application Version: 2.51
Model Definition Version: 0
Library Type: 3
Class Hierarchy: 04 : 10 : 01
Command Class Base: 25
Command Versions: 20v1 85v1 86v1 27v1 32v3 70v1 72v1 73v1 59v1 5Av1 7Av1 5Ev1 25v1
Features: routing, beaming, energyMeter
Neighbors: 37, 38
Associations: 1:[1]
Config Values: - none -
CliveS
CliveS
Mon Jan 30, 2017 8:20 pm
Re: TKB TZ69E Wall Plug Switch/Meter - GEN5 Module Definitio
I'll check and make sure it gets add to the request list. Thanks!
Thu Apr 13, 2017 6:08 am
Mayhem offline
Hi Clive
I'm having some odd effect with my TKB TZ69E's. It's not an Indigo problem I'm fairly sure about that but did wonder if you could check with your devices to see if they are performing the same as mine or if mine are acting up.
Vesternet are at a loss at the moment.
On static loads no problem but when I use them on any load that fluctuates the devices keep sending out unsolicited power reports. This is despite setting the config parameters for the report period to the max. This can be for as little as 0.5 watt. I have some with FW 2.10 similar to yours and some with 1,10 FW but both behave the same.
So with them all on the network is getting bombarded with unwanted traffic.
Your views would be most appreciated.
neil
Fri Apr 14, 2017 1:42 am
marketability offline
I'm having the same problem - doesn't affect all of the TZ69Es - just some
Hi Clive
neil
Fri Apr 14, 2017 7:38 pm
CliveS offline
Neil,
My TZ69E is turning on a 240-12v transformer to power 2 x 12v LED's in the garden at night.
I have the polling set to one hour (not much else to change until it is adopted (hopefully) in 7.0.4)
The log from last night is below.
14 Apr 2017, 20:28:33
   Z-Wave                          received "En Suite Floor Heating Thermostat" mode is off
   Schedule                        Garden Lights On
   Schedule                        Sunset Plus 20 True
   Z-Wave                          sent "Garden LED 12v Lights" on
   Z-Wave                          received "Garden LED 12v Lights" power load to 3.3 W
   Z-Wave                          received "Garden LED 12v Lights" power load to 9.2 W
14 Apr 2017, 20:31:50
   Z-Wave                          received "En Suite Floor Heating Thermostat" heat setpoint is 20.0 °C
   Z-Wave                          received "Garden LED 12v Lights" power load to 8.7 W
14 Apr 2017, 21:14:22
   Z-Wave                          received "Garden LED 12v Lights" energy total to 2.019 kWh
   Z-Wave                          received "Garden LED 12v Lights" power load to 9.0 W
14 Apr 2017, 21:14:48
   Z-Wave                          received "Garden LED 12v Lights" power load to 8.9 W
14 Apr 2017, 22:14:28
   Z-Wave                          received "Garden LED 12v Lights" power load to 8.6 W
   Z-Wave                          received "Garden LED 12v Lights" energy total to 2.028 kWh
14 Apr 2017, 22:37:29
14 Apr 2017, 22:49:47
14 Apr 2017, 22:59:59
   Schedule                        Garden Lights Off
   Z-Wave                          sent "Garden LED 12v Lights" off
   Z-Wave                          received "Garden LED 12v Lights" power load to 0.0 W
   Z-Wave                          received "Garden LED 12v Lights" energy total to 2.035 kWh
I can put up with the odd occasional extra logging but if you want annoying then how about getting the following 24 hours a day, every day!! from a Heatit thermostat. Can we have a filter for the log files please.
14 Apr 2017, 17:37:31
14 Apr 2017, 17:38:36
14 Apr 2017, 17:41:52
14 Apr 2017, 17:42:58
14 Apr 2017, 17:46:14
14 Apr 2017, 17:47:19
14 Apr 2017, 17:50:35
14 Apr 2017, 17:51:41
14 Apr 2017, 17:54:57
14 Apr 2017, 17:56:02
14 Apr 2017, 17:59:18
14 Apr 2017, 18:00:24
14 Apr 2017, 18:03:40
14 Apr 2017, 18:04:45
14 Apr 2017, 18:08:01
14 Apr 2017, 18:09:07
14 Apr 2017, 18:12:23
14 Apr 2017, 18:13:28
14 Apr 2017, 18:16:44
14 Apr 2017, 18:17:50
14 Apr 2017, 18:21:06
14 Apr 2017, 18:22:11
14 Apr 2017, 18:25:27
14 Apr 2017, 18:26:33
14 Apr 2017, 18:29:49
14 Apr 2017, 18:30:54
14 Apr 2017, 18:34:10
14 Apr 2017, 18:35:16
14 Apr 2017, 18:38:32
14 Apr 2017, 18:39:37
14 Apr 2017, 18:42:53
14 Apr 2017, 18:43:59
14 Apr 2017, 18:47:15
14 Apr 2017, 18:48:20
14 Apr 2017, 18:51:36
14 Apr 2017, 18:52:42
14 Apr 2017, 18:55:58
14 Apr 2017, 18:57:03
14 Apr 2017, 19:00:19
14 Apr 2017, 19:01:25
14 Apr 2017, 19:04:41
14 Apr 2017, 19:05:46
14 Apr 2017, 19:09:02
14 Apr 2017, 19:10:08
14 Apr 2017, 19:13:24
14 Apr 2017, 19:14:29
14 Apr 2017, 19:17:45
14 Apr 2017, 19:18:50
14 Apr 2017, 19:22:07
14 Apr 2017, 19:23:12
14 Apr 2017, 19:26:28
14 Apr 2017, 19:27:33
14 Apr 2017, 19:30:49
14 Apr 2017, 19:31:55
14 Apr 2017, 19:35:11
14 Apr 2017, 19:36:16
14 Apr 2017, 19:39:32
14 Apr 2017, 19:40:38
14 Apr 2017, 19:43:54
14 Apr 2017, 19:44:59
CliveS
CliveS
Sun Apr 16, 2017 3:03 pm
Yes, providing much better control and/or filtering of log messages is definitely on the feature request list.
Tue Apr 18, 2017 4:02 pm
Mayhem offline
I assume Filtering will only remove from the log not remove it as unwanted traffic from the network? which is more the concern for me.
This is the output log from mine, as you can see its every few seconds, so unless its a static load the TKB socket just keeps generating traffic.
Wow is me :-)
2017-04-05 16:53:27.801 Virtual Devices sent "Eye Mac" on
2017-04-05 16:53:27.882 Z-Wave sent "iMac-Drives" on
2017-04-05 16:53:27.982 Z-Wave sent "iMac-Main" on
2017-04-05 16:53:29.109 Z-Wave received "iMac-Main" power load to 22.8 W
2017-04-05 16:53:29.189 Z-Wave received "Den Motion " status update is off
2017-04-05 16:53:31.116 Z-Wave received "iMac-Main" power load to 5.6 W
2017-04-05 16:53:33.083 Z-Wave received "iMac-Main" power load to 83.9 W
2017-04-05 16:53:35.102 Z-Wave received "iMac-Main" power load to 65.8 W
2017-04-05 16:53:37.063 Z-Wave received "iMac-Main" power load to 125.6 W
2017-04-05 16:53:37.872 Z-Wave received "Kitchen Tilt/Tamper" status update is off
2017-04-05 16:53:38.013 Z-Wave received "Kitchen Motion Sensor" status update is off
2017-04-05 16:53:39.102 Z-Wave received "iMac-Main" power load to 116.8 W
2017-04-05 16:53:42.682 Z-Wave received "iMac-Main" power load to 121.9 W
2017-04-05 16:53:43.078 Z-Wave received "iMac-Main" power load to 125.4 W
2017-04-05 16:53:47.096 Z-Wave received "iMac-Main" power load to 141.8 W
2017-04-05 16:53:49.096 Z-Wave received "iMac-Main" power load to 113.4 W
2017-04-05 16:53:53.106 Z-Wave received "iMac-Main" power load to 141.8 W
2017-04-05 16:53:55.073 Z-Wave received "iMac-Main" power load to 121.9 W
2017-04-05 16:53:57.082 Z-Wave received "iMac-Main" power load to 95.3 W
2017-04-05 16:54:01.089 Z-Wave received "iMac-Main" power load to 104.7 W
2017-04-05 16:54:03.101 Z-Wave received "iMac-Main" power load to 138.0 W
2017-04-05 16:54:13.081 Z-Wave received "iMac-Main" power load to 125.2 W
2017-04-05 16:54:17.110 Z-Wave received "iMac-Main" power load to 134.8 W
2017-04-05 16:54:19.077 Z-Wave received "iMac-Main" power load to 125.8 W
2017-04-05 16:54:27.116 Z-Wave received "iMac-Main" power load to 112.9 W
2017-04-05 16:54:31.098 Z-Wave received "iMac-Main" power load to 104.3 W
2017-04-05 16:54:33.084 Z-Wave received "iMac-Main" power load to 112.9 W
2017-04-05 16:54:45.080 Z-Wave received "iMac-Main" power load to 96.6 W
2017-04-05 16:54:47.092 Z-Wave received "iMac-Main" power load to 109.6 W
2017-04-05 16:54:49.100 Z-Wave received "iMac-Main" power load to 130.4 W
2017-04-05 16:54:51.120 Z-Wave received "iMac-Main" power load to 112.9 W
2017-04-05 16:54:59.112 Z-Wave received "iMac-Main" power load to 104.7 W
2017-04-05 16:55:01.079 Z-Wave received "iMac-Main" power load to 116.6 W
2017-04-05 16:55:07.061 Z-Wave received "iMac-Main" power load to 137.5 W
2017-04-05 16:55:11.089 Z-Wave received "iMac-Main" power load to 118.5 W
2017-04-05 16:55:13.061 Z-Wave received "iMac-Main" power load to 105.0 W
2017-04-05 16:55:15.118 Z-Wave received "iMac-Main" power load to 96.9 W
2017-04-05 16:55:17.079 Z-Wave received "iMac-Main" power load to 91.8 W
2017-04-05 16:55:21.102 Z-Wave received "iMac-Main" power load to 100.1 W
2017-04-05 16:55:23.085 Z-Wave received "iMac-Main" power load to 92.1 W
2017-04-05 16:55:29.098 Z-Wave received "iMac-Main" power load to 84.4 W
2017-04-05 16:55:35.109 Z-Wave received "iMac-Main" power load to 88.7 W
2017-04-05 16:55:37.108 Z-Wave received "iMac-Main" power load to 84.2 W
2017-04-05 16:55:53.074 Z-Wave received "iMac-Main" power load to 104.8 W
2017-04-05 16:55:55.703 Z-Wave received "Hall Luminance" sensor update to 9 lux
2017-04-05 16:55:55.748 Z-Wave received "Hall Humidity" sensor update to 50%
2017-04-05 16:55:55.768 Z-Wave received "Hall Temperature" sensor update to 13.6 °C
2017-04-05 16:55:57.111 Z-Wave received "iMac-Main" power load to 85.2 W
2017-04-05 16:55:59.093 Z-Wave received "iMac-Main" power load to 97.0 W
2017-04-05 16:56:01.073 Z-Wave received "iMac-Main" power load to 88.5 W
2017-04-05 16:56:03.790 Z-Wave received "Lounge Luminance" sensor update to 250 lux
2017-04-05 16:56:03.791 Z-Wave received "Lounge Humidity" sensor update to 49%
2017-04-05 16:56:03.800 Z-Wave received "Lounge Temperature" sensor update to 16.7 °C
2017-04-05 16:56:05.111 Z-Wave received "iMac-Main" power load to 93.2 W
2017-04-05 16:56:07.082 Z-Wave received "iMac-Main" power load to 88.5 W
2017-04-05 16:56:09.086 Z-Wave received "iMac-Main" power load to 93.2 W
2017-04-05 16:56:11.102 Z-Wave received "iMac-Main" power load to 85.1 W
2017-04-05 16:56:15.077 Z-Wave received "iMac-Main" power load to 89.5 W
2017-04-05 16:56:15.539 Application Indigo Cocoa client authenticated (192.168.100.12)
2017-04-05 16:56:17.110 Z-Wave received "iMac-Main" power load to 110.1 W
2017-04-05 16:56:19.081 Z-Wave received "iMac-Main" power load to 88.8 W
2017-04-05 16:56:59.087 Z-Wave received "iMac-Main" power load to 84.0 W
2017-04-05 16:57:03.071 Z-Wave received "iMac-Main" power load to 88.7 W
2017-04-05 16:57:03.469 Z-Wave received "Lounge Motion Sensor" status update is off
Tue Apr 18, 2017 7:15 pm
CliveS offline
I thought my Heatit thermostat was bad but that is just plain annoying. When I get back to the UK on 30th I will swap the TZ69E with a TZ88E that controls the Plasma TV as that fluctuates power and i will let you know the results.
Hopefully when 7.0.4 is released it will sort out the problem as the TZ88E can set the time between Watt and KwH reporting intervals and has the "hide status and energy message broadcasts in event log" option that the TZ69E (would be nice to see that added to the Heatit as well!) does not yet have.
But it might not stop the unwanted traffic and add a few of them and some Heatit's plus other badly programmed devices into the equation and it could end up with collisions and congestion slowing down the whole system.
CliveS
CliveS
Tue Apr 18, 2017 8:03 pm
While the settings checkbox option to Hide status and energy message broadcasts in the Event Log requires a device definition for this module, you can in the current version of Indigo still change its Z-Wave configuration settings. Just use the Interfaces->Z-Wave->Modify Configuration Parameter... menu item. If it has the same config settings as the TZ88E, then parameter #1 is the Watt reporting interval (in 5 second increments), and parameter #2 is the kWh reporting interval (in 10 minute increments).
Wed Apr 19, 2017 2:34 am
CliveS offline
Just tried changing parameters #1 and #2 but they always revert to a 1 byte value of 1, tried 2 byte value of 2222 and that returned default ( 1:1) when I read it again but doing the same with the TZ88 gave me a value of 2222 when it was re-read and also in the device settings page.
Z-wave seems to be getting more problematic with every firmware update.
CliveS
CliveS
Wed Apr 19, 2017 10:47 am
Mayhem offline
Chaps
I have set the reporting parameters to the maximum with no effect. First thing I tried.
Talking to one of the Tech's at Vesternet and sending him various logs etc. he came back with :
"Thanks for the diagnostics, my only guess is that it's an adaptive algorithm based on some percentage change over time as opposed to a fixed rate - it looks pretty random though."
He did say they hadn't seen this anywhere else BUT he said that he thought Indigo logging gave a greater level of reporting so it could be happening else where.
Clive, be interesting to see what you get on a fluctuating load.
Cheers Chaps.
Thu Apr 20, 2017 9:13 am
I don't know if the TZ69E uses the same config parameters as the TZ88 or not. Does the manual for it not specify the configuration parameter details? It is also possible it isn't even a setting that can be modified.
Thu Apr 20, 2017 6:29 pm
CliveS offline
Neil,
Having now read the manual :roll: parameter 1 is for turning the front led on/off, #2 is for memory function and both are set 0 as default.
Param #3 is for Watt meter report period (byte size 2), unit is 5 sec and default is 720 so it should only report once an hour.
Param #4 is for KwH report period (byte size 2), unit is 10 mins and default is 6 so also reports once an hour.
Changed param #3 to 1 (every 5 secs reporting) and then changed it to 32767 (once a day reporting) and all silent (except for that *&$%(# Heatit !!!
    21 Apr 2017, 01:01:08
    Z-Wave connection reset requested
    Z-Wave connected to Z-Wave 3.95 static controller interface on /dev/cu.usbmodem1d121 (firmware 1.00)
    Z-Wave received "Garden LED 12v Lights" power load to 8.8 W
    Z-Wave received "Garden LED 12v Lights" power load to 8.4 W
    21 Apr 2017, 01:03:31
    21 Apr 2017, 01:04:00
    21 Apr 2017, 01:04:31
    21 Apr 2017, 01:05:06
    21 Apr 2017, 01:07:16
    21 Apr 2017, 01:08:00
    Z-Wave retrieved parameter 3 value: 1 (size 2)
    21 Apr 2017, 01:08:16
    Z-Wave device "Garden LED 12v Lights" parameter 3 changed to 32767
    Z-Wave device "Garden LED 12v Lights" parameter 4 changed to 32767
    21 Apr 2017, 01:11:37
    21 Apr 2017, 01:12:43
So it seems param 3 & 4 should turn off your constant output with 32767 values, if not then back to Vesternet with it.
CliveS
CliveS
Wed Oct 18, 2017 1:53 am
benip offline
Hi Matt
Thanks for the 7.1 update, but disappointed that the TZ69E didn't get a definition added. Can I check that it is still on the feature request list? I do prefer them over my TZ88Es, but the constant logging is tiresome!
Ben
Wed Oct 18, 2017 10:03 am
Hi Ben,
Yes, it is still on the list. We did get a lot of modules added but still have a lot left. :-)
In the mean time, did you see Clive's post above about modifying the configuration parameters to help reduce the reporting of the TZ88?
Users browsing this forum: No registered users and 25 guests
