I purchased a Ecolink TILT-ZWAVE2-ECO from Amazon
https://www.amazon.com/gp/product/B00HG ... UTF8&psc=1I am unable to define and sinc the device. Here is what the event log shows.
Apr 26, 2017, 2:48:47 PM
Z-Wave Syncing - started for "034 - Notification Sensor"
Z-Wave Syncing - retrieved module neighbors list: 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 15, 17
Z-Wave Syncing - assigning return route to "034 - Notification Sensor"
Z-Wave Error Error in plugin execution:
File "/Library/Application Support/Perceptive Automation/Indigo 7/IndigoPluginHost.app/Contents/PlugIns/serialinterface.py", line 501, in startCommThread
self.processCommThread()
File "/Library/Application Support/Perceptive Automation/Indigo 7/IndigoPluginHost.app/Contents/PlugIns/serialinterface.py", line 675, in processCommThread
self.processQueueInPacket(packet) # Subclass is required to define.
File "zwaveinterface.py", line 2233, in processQueueInPacket
File "zwaveinterface.py", line 2207, in _processFuncCall
File "zwaveinterface.py", line 2268, in _processCommandReply
File "zwaveinterface.py", line 2252, in _processFuncTriggersAndBroadcast
File "zwaveinterface.py", line 2205, in _processFuncCall
File "zwavecmd_manufactureinfo.py", line 79, in _processManufactureInfo
File "zwavenode.py", line 577, in _updateModelInfoFromIDs
AttributeError: 'module' object has no attribute 'kModelDefinition'
Z-Wave Error exc type is <type 'exceptions.AttributeError'>
Z-Wave Error restarting serial connection in 5.0 seconds
Z-Wave connected to Z-Stick Plus (ZW090) interface on /dev/cu.usbmodem1431 (firmware 1.00)
Z-Wave Error Error trying to communicate with "034 - Notification Sensor".
Z-Wave found module included in controller with no matching device (missing or disabled): 026 - Static Controller
Z-Wave found module included in controller with no matching device (missing or disabled): 034 - Notification Sensor
This device is in the supported hardware list.
Below is the event log with debug turned on.
Apr 26, 2017, 3:12:08 PM
Z-Wave Debug RCVD nodeInfoFrame: 01 16 00 49 84 22 10 04 07 01 5E 86 72 73 80 71 85 59 84 30 70 EF 20 EB
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 11 00 04 00 22 0B 71 05 00 00 00 FF 07 03 00 00 00 4C
Z-Wave Debug . . requestAlarmSensorStatus: node 034, endpoint None, cmdClass 71, type 0, value 0, classSubKey 710000
Z-Wave Debug . . requestAlarmSensorStatus: typeExt 7, valueExt 3, classSubKeyExt 7100000703
Z-Wave Debug intiatingSyncUI (timeout in 1500 seconds)
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 06 0E 32 02 21 64 00 00 00 02 02 58 00 00 00 02 C8
Z-Wave Debug . . requestMeterLevel: node 006, endpoint None, meterType 01, raw value 6400...
Z-Wave Debug . . requestMeterLevel: 0.002 kWh (float: 0.002000)
Z-Wave Debug SENT getNodeNeighbors: 01 06 00 80 22 01 01 5B
Z-Wave Debug RCVD getNodeNeighbors: 01 20 01 80 FE 4F 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 EE
Z-Wave Debug . . getNodeNeighbors: nodeId 034, neighbors: 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 15, 17
Z-Wave Debug SENT assignReturnRoute: 01 05 00 46 22 01 9F
Z-Wave Debug RCVD assignReturnRoute: 01 04 01 46 01 BD
Z-Wave Debug RCVD assignReturnRoute: 01 05 00 46 01 00 BD
Z-Wave Debug . . assignReturnRoute: node 034, success 1
Z-Wave Debug SENT requestNodeInfo: 01 06 00 60 22 24 90 0F
Z-Wave Debug . . nodeInfoFrame: node 034, combined class list: 20v1 80v1 84v1 85v1 86v1 30v1 70v1 71v1 72v1 73v1 59v1 5Ev1
Z-Wave Debug SENT requestManufactureInfo: 01 09 00 13 22 02 72 04 25 91 07
Z-Wave Debug RCVD requestManufactureInfo: 01 0E 00 04 00 22 08 72 05 01 4A 00 04 00 03 E4
Z-Wave Debug . . requestManufactureInfo: node 034, manufacturerId 014A, productId 00040003
Z-Wave Debug stopping node healing thread
Z-Wave Debug stopping node status polling thread
Z-Wave Debug stopped zwave packet parser thread
Z-Wave Debug timeout waiting for reply from module (non-fatal, skipping request)
Z-Wave Debug starting serial connection loop
Z-Wave Debug starting zwave packet parser thread
Z-Wave Debug SENT getVersion: 01 03 00 15 E9
Z-Wave Debug RCVD getVersion: 18 (RETRANSMIT REQUEST)
Z-Wave Debug SENT getVersion: 01 03 00 15 E9 (re-sent because retransmit request)
Z-Wave Debug RCVD getVersion: 01 10 01 15 5A 2D 57 61 76 65 20 33 2E 39 35 00 01 99
Z-Wave Debug . . getVersion: requeuing 2 unsolicited packets
Z-Wave Debug . . getVersion: Z-Wave 3.95 static controller
Z-Wave Debug SENT getHomeID: 01 03 00 20 DC
Z-Wave Debug RCVD getHomeID: 01 08 01 20 D1 3C 1D 9A 01 BD
Z-Wave Debug . . getHomeID: requeuing 2 unsolicited packets
Z-Wave Debug . . getHomeID: D13C1D9A, nodeID: 001
Z-Wave Debug SENT getInterfaceFeatures: 01 03 00 05 F9
Z-Wave Debug RCVD getInterfaceFeatures: 01 04 01 05 18 E7
Z-Wave Debug . . getInterfaceFeatures: requeuing 2 unsolicited packets
Z-Wave Debug . . getInterfaceFeatures: 18
Z-Wave Debug SENT getInterfaceApiCapabilities: 01 03 00 07 FB
Z-Wave Debug RCVD getInterfaceApiCapabilities: 01 2B 01 07 01 00 00 86 01 01 00 5A FE 81 FF 88 4F 1F 00 00 FB 9F 7D A0 67 00 00 80 00 80 86 00 00 00 E8 73 00 00 0E 00 00 60 00 00 FA
Z-Wave Debug . . getInterfaceApiCapabilities: requeuing 2 unsolicited packets
Z-Wave Debug . . getInterfaceApiCapabilities: supportedFuncIDs: 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18 1C 20 21 22 23 24 27 29 2A 2B 2C 2D 41 42 44 45 46 47 48 49 4A 4B 4C 4D 50 51 53 54 55 56 57 5E 60 61 62 63 66 67 80 90 92 93 98 B4 B6 B7 B8 B9 BA BD BE BF D2 D3 D4 EE EF
Z-Wave Debug . . getInterfaceApiCapabilities: serialApi 1.00, manufactureId 0086, productType 0101, productId 005A
Z-Wave Debug SENT forceSUC: 01 05 00 54 01 01 AE
Z-Wave Debug RCVD forceSUC: 01 04 01 54 01 AF
Z-Wave Debug . . forceSUC: requeuing 2 unsolicited packets
Z-Wave Debug SENT getInitialNodeData: 01 03 00 02 FE
Z-Wave Debug RCVD getInitialNodeData: 01 25 01 02 05 08 1D FF FF 07 FE 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 36
Z-Wave Debug . . getInitialNodeData: requeuing 2 unsolicited packets
Z-Wave Debug . . getInitialNodeData: is static update controller
Z-Wave Debug . . getInitialNodeData: [1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 26, 27, 28, 29, 30, 31, 32, 33, 34]
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 01 BB
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 93 16 01 02 02 01 33
Z-Wave Debug . . getNodeProtocolInfo: requeuing 2 unsolicited packets
Z-Wave Debug . . getNodeProtocolInfo: node 001, class name: Static Computer Controller
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Static Controller : Static Controller : Static Computer Controller (02 : 02 : 01)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 00
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20
Z-Wave Debug . . getNodeProtocolInfo: encrypt class commands:
Z-Wave Debug . . getNodeProtocolInfo: features: beaming
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 02 B8
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 01 04 10 01 ED
Z-Wave Debug . . getNodeProtocolInfo: node 002, class name: Relay Power Switch
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Relay Switch : Relay Power Switch (04 : 10 : 01)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 25
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 25 27
Z-Wave Debug . . getNodeProtocolInfo: features: routing, beaming
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 03 B9
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D2 9C 00 04 10 01 ED
Z-Wave Debug . . getNodeProtocolInfo: node 003, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 04 BE
Z-Wave Debug . . getNodeProtocolInfo: node 004, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 05 BF
Z-Wave Debug . . getNodeProtocolInfo: node 005, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 06 BC
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 00 04 10 01 EC
Z-Wave Debug . . getNodeProtocolInfo: node 006, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 07 BD
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 00 04 11 04 E8
Z-Wave Debug . . getNodeProtocolInfo: node 007, class name: Dimmable Scene Switch
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Mulitlevel Switch : Dimmable Scene Switch (04 : 11 : 04)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 26
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 26 27 2B 2C 72
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 08 B2
Z-Wave Debug . . getNodeProtocolInfo: node 008, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 09 B3
Z-Wave Debug . . getNodeProtocolInfo: node 009, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 0A B0
Z-Wave Debug . . getNodeProtocolInfo: node 010, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 0B B1
Z-Wave Debug . . getNodeProtocolInfo: node 011, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 0C B6
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 00 04 0F 01 F3
Z-Wave Debug . . getNodeProtocolInfo: node 012, class name: Basic Repeater Slave
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Repeater Slave : Basic Repeater Slave (04 : 0F : 01)
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 0D B7
Z-Wave Debug . . getNodeProtocolInfo: node 013, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 0E B4
Z-Wave Debug . . getNodeProtocolInfo: node 014, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 0F B5
Z-Wave Debug . . getNodeProtocolInfo: node 015, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 10 AA
Z-Wave Debug . . getNodeProtocolInfo: node 016, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 11 AB
Z-Wave Debug . . getNodeProtocolInfo: node 017, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 12 A8
Z-Wave Debug . . getNodeProtocolInfo: node 018, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 13 A9
Z-Wave Debug . . getNodeProtocolInfo: node 019, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 1A A0
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 93 86 00 02 02 00 A3
Z-Wave Debug . . getNodeProtocolInfo: node 026, class name: Static Controller
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Static Controller : Static Controller : -- (02 : 02 : 00)
Z-Wave Debug . . getNodeProtocolInfo: features: - none -
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 1B A1
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 93 04 00 03 11 05 36
Z-Wave Debug . . getNodeProtocolInfo: node 027, class name: Motor Control Class A
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Slave : Mulitlevel Switch : Motor Control Class A (03 : 11 : 05)
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 72 25 26 86
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 1C A6
Z-Wave Debug . . getNodeProtocolInfo: node 028, class name: Motor Control Class A
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 1D A7
Z-Wave Debug . . getNodeProtocolInfo: node 029, class name: Motor Control Class A
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 1E A4
Z-Wave Debug . . getNodeProtocolInfo: node 030, class name: Motor Control Class A
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 1F A5
Z-Wave Debug . . getNodeProtocolInfo: node 031, class name: Motor Control Class A
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 20 9A
Z-Wave Debug . . getNodeProtocolInfo: node 032, class name: Motor Control Class A
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 21 9B
Z-Wave Debug . . getNodeProtocolInfo: node 033, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 22 98
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 53 9C 01 04 07 01 7A
Z-Wave Debug . . getNodeProtocolInfo: node 034, class name: Notification Sensor
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Notification Sensor : Notification Sensor (04 : 07 : 01)
Z-Wave Debug starting node healing thread
Z-Wave Debug starting node status polling thread
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 07 0E 32 02 21 64 00 00 00 00 02 58 00 00 00 00 C9
Z-Wave Debug . . requestMeterLevel: node 007, endpoint None, meterType 01, raw value 6400...
Z-Wave Debug . . requestMeterLevel: 0.000 kWh (float: 0.000000)
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 07 0E 32 02 21 74 00 00 00 00 00 00 00 00 00 00 83
Z-Wave Debug . . requestMeterLevel: node 007, endpoint None, meterType 01, raw value 7400...
Z-Wave Debug . . requestMeterLevel: 0.000 W (float: 0.000000)
Apr 26, 2017, 3:12:47 PM
Z-Wave Debug terminatingSyncUI
Apr 26, 2017, 3:13:14 PM
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 0A 0E 32 02 21 64 00 00 00 22 02 58 00 00 00 1E F8
Z-Wave Debug . . requestMeterLevel: node 010, endpoint None, meterType 01, raw value 6400...
Z-Wave Debug . . requestMeterLevel: 0.034 kWh (float: 0.034000)
Z-Wave received "Outside Fountain Side" energy total to 0.034 kWh
Z-Wave Debug RCVD requestMeterLevel: 01 18 00 04 00 02 12 32 02 21 64 00 00 00 11 02 58 00 00 00 11 00 00 00 00 DC
Z-Wave Debug . . requestMeterLevel: node 002, endpoint None, meterType 01, raw value 6400...
Z-Wave Debug . . requestMeterLevel: 0.017 kWh (float: 0.017000)
Z-Wave Debug RCVD requestMeterLevel: 01 18 00 04 00 02 12 32 02 21 74 00 00 00 00 00 00 00 00 00 00 00 00 00 00 96
Z-Wave Debug . . requestMeterLevel: node 002, endpoint None, meterType 01, raw value 7400...
