Colorado4Wheeler wrote:roussell wrote:It would seem like the hinge point is the worst location to detect a door being slightly ajar.
I don't see why if you calibrate the sensor to when the door is closed versus opened. It's not too dissimilar to how I utilize my Add-A-Motor drape controller, just dialed in so I can predictably open, close or any point in between.
It was based on the assumption that there is inherent "slop" in the mechanism, which I admit is a suspicion based on the lack of quality I often see in consumer electronics these days. Anywho... Consider the door being open 1/2 inch (or less) - enough to appear closed, but not enough to engage the latching mechanism. A traditional magnetic door/window sensor (installed on the strike plate side of the door (opposite the hinge) would have that full 1/2 inch span to register an ajar condition, but 30-36 inches away -near the hinge point- that lateral movement is extremely small. My thoughts were around the question of the sensor having enough precision to detect that small movement, consistently. It probably wouldn't be a problem on a bathroom or closet door, but could be an issue on an entry door. My doors have those hinge-pin door stops that keep the door from opening too far; over time they seem to push the pin up and out of the hinge a bit, which reduces their effectiveness, I wonder if these would act similarly.
At any rate, it's a cool device, and I'm interested to see how they turn out. I guess I'm just too old school when it comes to these types of sensor devices and just prefer hardwired if possible.
Terry
