Hoping someone can help, I've got a fibaro dimmer 1 module that i'd like to use the 2nd switch to control a Fibaro relay switch. I'm used to setting associations between devices and have done it several times with fibaro dimmer modules, however the relay has 2 outputs, and only the 1st is being shown in the associations list, so i can't select the 2nd, Does anyone have a work around or know how i can get it working? Or is it a bug in Indigo?
Andrew
