I was really looking forward to the zwave encryption support in Indigo 7. That is one of the two reasons that I paid for the Indigo 7 update (note, the other hopeful fix was also not delivered, see http://forums.indigodomo.com/viewtopic.php?f=104&t=17218).
My immediate problem is that I'm unable to control my Kwikset Smartcode 916 lock. I am able to add it just fine following the instructions for inclusion, but controlling the lock status from Indigo does not take effect. When I do either "Lock", "Unlock", or "Send Status Request" from Indigo, I see a red light indicator light up on the device, but nothing actually happens. Sometimes, Indigo reports no ACK. Sometimes, Indigo reports that the status was actually updated (it was not).
Here are some logs showing the problem, but they don't seem terribly helpful.
Dec 31, 2016, 21:13:23
Z-Wave started controller inclusion mode with encryption
Dec 31, 2016, 21:15:22
Z-Wave controller included module: 004 - Keypad Door Lock
Z-Wave querying module for encryption support
Z-Wave module does not support encryption (sync will continue without encryption)
Z-Wave stopped controller inclusion mode
Z-Wave Syncing - started for "004 - Keypad Door Lock"
Z-Wave Syncing - retrieved module neighbors list: 1
Z-Wave Syncing - assigning return route to "004 - Keypad Door Lock"
Z-Wave Syncing - retrieved manufacture and model names: Kwikset - 0090, SmartCode Lock - 00010001
Z-Wave Syncing - retrieved protocol version 3.67, app version 3.37
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Entry Control : Keypad Door Lock (04 : 40 : 03, base 62)
Z-Wave Syncing - retrieved command classes: 20v1 62v1 63v1 86v1 98v1 72v1
Z-Wave Syncing - retrieved encrypt commands: - none -
Z-Wave Syncing - retrieved capabilities: routing, beaming, security, frequentWaking
Z-Wave Syncing - created device "004 - SmartCode Lock"
Z-Wave Syncing - complete
Z-Wave sent "004 - SmartCode Lock" status request
Dec 31, 2016, 21:16:17
Z-Wave sent "Front Door Lock" lock
Z-Wave sent "Front Door Lock" unlock
Dec 31, 2016, 21:16:56
Z-Wave sent "Front Door Lock" status request
Z-Wave Error send "Front Door Lock" status request failed
Dec 31, 2016, 21:17:37
Disabling interface "Z-Wave 2.0.34"
Stopping interface "Z-Wave 2.0.34" (pid 900)
Z-Wave closed connection to Z-Stick S2
Stopped interface "Z-Wave 2.0.34"
Enabling interface "Z-Wave 2.0.34"
Starting interface "Z-Wave 2.0.34" (pid 46679)
Started interface "Z-Wave 2.0.34"
Z-Wave connected to Z-Stick S2 interface on /dev/cu.SLAB_USBtoUART (firmware 3.07)
Dec 31, 2016, 21:18:44
Z-Wave Syncing - started for "Front Door Lock"
Z-Wave Syncing - assigning return route to "004 - Front Door Lock"
Z-Wave Error send "Front Door Lock" unlock failed
