I tried the New Device -> Add to network: "New with Encryption Disabled" method of including this device. It found it and sync'd successfully, but it came up as "Notification Sensor" rather than the multisensor it is. I've got a handful of these already on the network, so I immediately knew something was up.
Dump from the logs:
- Code: Select all
Dec 28, 2016, 5:49:47 PM
Z-Wave Indigo Device "(Motion) Living Room Desk" Z-Wave Properties:
Indigo Z-Wave Version: 2.0.34
Node ID: 39
Model: Notification Sensor
Model ID: 00000000
Manufacturer: Unknown
Manufacturer ID: 0000
Protocol Version: 4.05
Application Version: 3.02
Model Definition Version: 0
Library Type: 3
Class Name: Notification Sensor
Class Hierarchy: 04 : 07 : 01
Command Class Base: 00
Command Versions: 80v1 84v2 85v1 86v1 8Ev1 56v1 98v1 59v1 5Av1 9Cv1 5Ev1 20v1 70v1 22v1 71v1 30v1 31v8 72v1 73v1 7Av1
Features: routing, battery, beaming, security, waking
Neighbors: 1, 12, 17, 19, 25, 32, 37
Associations: 1:[1] 2:[] 3:[] 4:[] 5:[]
Config Values: - none -
I tried to exclude using the "Start Controller Exclusion Mode" menu item, but it didn't seem to work. So I hiked downstairs, unplugged my Z-stick and did it the old fashioned way successfully. I then re-included the multisensor again using the button on the Z-stick and it showed up successfully. Here are some logs in case they're useful
Including view button in Indigo:
- Code: Select all
Dec 28, 2016, 5:47:53 PM
Z-Wave received "(Motion) Living Room" status update is off
Z-Wave received "(Lux) Kitchen" sensor update to 91 lux
Z-Wave started controller inclusion mode
Z-Wave sent "(Switch) Bedroom Hot" energy status request
Z-Wave controller included module: 039 - Notification Sensor
Z-Wave stopped controller inclusion mode
Z-Wave Syncing - started for "039 - Notification Sensor"
Z-Wave Syncing - retrieved module neighbors list: 1, 12, 17, 19, 25, 32, 37
Z-Wave Syncing - assigning return route to "039 - Notification Sensor"
Z-Wave received "(Lux) Downstairs" sensor update to 29 lux
Z-Wave received "(Humidity) Downstairs" sensor update to 37%
Z-Wave received "(Temp) Downstairs" sensor update to 67.1 °F
Z-Wave Syncing - retrieved protocol version 4.05, app version 3.02
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Notification Sensor : Notification Sensor (04 : 07 : 01, base 00)
Z-Wave Syncing - retrieved command classes: 80v1 84v2 85v1 86v1 8Ev1 56v1 98v1 59v1 5Av1 9Cv1 5Ev1 20v1 70v1 22v1 71v1 30v1 31v8 72v1 73v1 7Av1
Z-Wave Syncing - retrieved encrypt commands: - none -
Z-Wave Syncing - retrieved capabilities: routing, battery, beaming, security, waking
Z-Wave Syncing - retrieved wake interval of 120 minutes
Z-Wave Syncing - device "039 - Notification Sensor" wake interval changed to 60 minutes
Z-Wave Syncing - retrieved group 1 associations: []
Z-Wave Syncing - retrieved group 2 associations: []
Z-Wave Syncing - retrieved group 3 associations: []
Z-Wave Syncing - retrieved group 4 associations: []
Z-Wave Syncing - retrieved group 5 associations: []
Z-Wave Syncing - added group 1 association to interface
Z-Wave Syncing - retrieved battery level of 100%
Z-Wave Syncing - created device "039 - Notification Sensor"
Z-Wave Syncing - complete
Z-Wave sent "039 - Notification Sensor" status request
Z-Wave received "039 - Notification Sensor" status update battery level 100%
Including via button on Z-Stick:
- Code: Select all
Z-Wave Error serial port communication error: read failed: [Errno 6] Device not configured
Z-Wave Error Z-Stick S2 might be disconnected
Z-Wave Error silently retrying serial connection every 5.0 seconds
Interface Failure lost connection with interface
Z-Wave connected to Z-Stick S2 interface on /dev/cu.SLAB_USBtoUART (firmware 3.07)
Z-Wave found module included in controller with no matching device (missing or disabled): 033 - Notification Sensor
Z-Wave found module included in controller with no matching device (missing or disabled): 040 - Notification Sensor
Z-Wave Syncing - started for "040 - Notification Sensor"
Z-Wave Syncing - retrieved module neighbors list: 1, 6, 7, 12, 17, 18, 19, 24, 32, 35
Z-Wave Syncing - assigning return route to "040 - Notification Sensor"
Z-Wave Syncing - retrieved manufacture and model names: Fibaro System - 010F, Motion Sensor (FGMS001) - 08012001
Z-Wave Syncing - retrieved command classes: 20v1 80v1 22v1 84v2 85v1 86v1 71v1 8Ev1 70v1 31v8 72v1 73v1 30v1 56v1 98v1 59v1 5Av1 9Cv1 7Av1 5Ev1
Z-Wave Syncing - device "040 - Notification Sensor" wake interval changed to 60 minutes
Z-Wave Syncing - added group 2 association to interface
Z-Wave Syncing - added group 3 association to interface
Z-Wave Syncing - retrieved parameter 8 "Motion sensor mode" is 0 "Always Active"
Z-Wave Syncing - retrieved parameter 1 "Motion sensor sensitivity" is 15
Z-Wave Syncing - retrieved parameter 6 "Off delay" is 30 seconds
Z-Wave Syncing - retrieved parameter 9 "Night luminance threshold" is 200
Z-Wave Syncing - retrieved parameter 12 "Group 1 command type" is 0
Z-Wave Syncing - retrieved parameter 20 "Tamper sensitivity" is 20
Z-Wave Syncing - retrieved parameter 24 "Tamper operating mode" is 0
Z-Wave Syncing - retrieved parameter 40 "Luminance sensitivity" is 200 LUX
Z-Wave Syncing - retrieved parameter 42 "Luminance reporting interval" is 3600 seconds
Z-Wave Syncing - retrieved parameter 60 "Temperature sensitivity" is 10 * 0.1°C
Z-Wave Syncing - retrieved parameter 62 "Temperature measuring interval" is 900 seconds
Z-Wave Syncing - retrieved parameter 64 "Temperature reporting interval" is 0 seconds
Z-Wave Syncing - retrieved parameter 66 "Temperature offset" is 0 * 0.1°C
Z-Wave Syncing - retrieved parameter 80 "LED signaling mode" is 10
Z-Wave Syncing - retrieved parameter 81 "LED brightness" is 50
Z-Wave Syncing - retrieved parameter 82 "LED ambient lower" is 100 LUX
Z-Wave Syncing - retrieved parameter 83 "LED ambient upper" is 1000 LUX
Z-Wave Syncing - retrieved parameter 86 "LED temperature lower" is 18 degrees
Z-Wave Syncing - retrieved parameter 87 "LED temperature upper" is 28 degrees
Z-Wave Syncing - retrieved parameter 89 "LED flashes red, white, blue on tamper" is true
Z-Wave Syncing - created device "040 - Motion Sensor"
Z-Wave Syncing - created device "040 - Tilt/Tamper"
Z-Wave Syncing - created device "040 - Temperature"
Z-Wave Syncing - created device "040 - Luminance"
Z-Wave sent "040 - Motion Sensor" status request
Z-Wave received "040 - Motion Sensor" status update is off
Z-Wave received "040 - Motion Sensor" status update battery level 100%
Z-Wave sent "040 - Tilt/Tamper" status request
Z-Wave received "040 - Tilt/Tamper" status update is on
Z-Wave sent "040 - Temperature" status request
Z-Wave received "040 - Luminance" sensor update to 108 lux
Z-Wave received "040 - Luminance" units changed to lux
Z-Wave sent "040 - Luminance" status request
