iammac wrote:best I can come up with has been a FirstAlert from US based supplier for twice the price . Any ideas? Many thanks, Ian.
matt (support) wrote:Indigo 7 added support for these two:
- Fibaro Smoke Sensor (FGSD002)
- POPP Smoke Detector and Siren (004001)
17 Dec 2016, 17:35:24
Z-Wave stopped controller inclusion mode
Z-Wave Error the node included has the same ID as a node already in use by Indigo
Z-Wave Error to change the encryption state of the device you must exclude it before re-including it
Z-Wave Syncing - started for "015 - Notification Sensor"
Z-Wave Syncing - retrieved module neighbors list: 8, 13
Z-Wave Syncing - assigning return route to "015 - Notification Sensor"
Z-Wave Syncing - retrieved manufacture and model names: Fibaro System - 010F, Smoke Sensor (FGSD002) - 0C021002
Z-Wave Syncing - retrieved protocol version 4.05, app version 3.03
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Notification Sensor : Notification Sensor (04 : 07 : 01, base 00)
Z-Wave Syncing - retrieved command classes: 20v1 80v1 22v1 84v2 85v1 86v1 71v1 8Ev1 70v1 31v8 72v1 73v1 56v1 98v1 59v1 5Av1 9Cv1 7Av1 5Ev1
Z-Wave Syncing - retrieved capabilities: routing, battery, beaming, security, waking
Z-Wave Syncing - retrieved wake interval of 360 minutes
Z-Wave Syncing - device "015 - Notification Sensor" wake interval changed to 60 minutes
Z-Wave Syncing - retrieved group 2 associations: [1]
Z-Wave Syncing - retrieved group 3 associations: []
Z-Wave Syncing - retrieved group 4 associations: []
Z-Wave Syncing - retrieved group 5 associations: [1]
Z-Wave Syncing - group 2 association to interface already exists (skipping)
Z-Wave Syncing - group 5 association to interface already exists (skipping)
Z-Wave Syncing - retrieved parameter 2 "Notification flags" is 3
Z-Wave Syncing - retrieved parameter 10 "Group 2 command type" is 0
Z-Wave Syncing - retrieved parameter 11 "Group 2 command value" is 255
Z-Wave Syncing - retrieved parameter 1 "Smoke sensitivity" is 2 "Medium"
Z-Wave Syncing - retrieved parameter 3 "Visual alerts" is 0 "Disabled"
Z-Wave Syncing - retrieved parameter 4 "Audible alerts" is 0 "Disabled"
Z-Wave Syncing - retrieved parameter 20 "Temperature interval" is 1 * 10 seconds
Z-Wave Syncing - retrieved parameter 21 "Temperature sensitivity" is 10 * 0.1°C
Z-Wave Syncing - retrieved parameter 30 "Temperature threshold" is 55 °C
Z-Wave Syncing - retrieved parameter 31 "Temperature alarm" is 1 "10 Seconds"
Z-Wave Syncing - retrieved battery level of 100%
Z-Wave Syncing - created device "015 - Smoke"
Z-Wave Syncing - created device "015 - Tamper"
Z-Wave Syncing - created device "015 - Temperature"
Z-Wave Syncing - complete
Z-Wave Error device "015 - Smoke" does not support status request command
