Ok, so my entire ZWave network died except for one device, fine, I overnighted a new Gen 5 stick.
The Gen5 will not honor the Indigo include/exclude at all, I have to do it manually to get it at all - meaning I cannot get encrypted mode and thus meaning I cannot get my door lock back up again
I've linked one of my plugged in ZWave devices to the Gen5 successfully, it's a power adapter, and I can see it in the node list in Indigo so I can re-assign my Indigo device to the device now on my Gen5, however it won't synchronize:
- Code: Select all
found module included in controller with no matching device (missing or disabled): 003 - Relay Power Switch
Z-Wave Syncing - started for "003 - Relay Power Switch"
Z-Wave Syncing - assigning return route to "003 - Relay Power Switch"
Z-Wave Error Syncing - failed to assign return route
EPS - Powermiser Error Exception in plug.zwaveCommandAction line 757: index 8 out of list range
CODE: cmdF = int(cmd['bytes'][8])
Z-Wave Error No response from "003 - Relay Power Switch". Module might be asleep, or is unreachable.
So I turn on debugging so I can report here before I literally throw my Indigo server, both Z-Sticks and all my ZWave stuff in the trash because I'm so unbelievably frustrated:
- Code: Select all
Dec 3, 2016, 3:29:49 PM
Z-Wave Debug stopping node healing thread
Z-Wave Debug stopping node status polling thread
Z-Wave Debug stopped zwave packet parser thread
Z-Wave connection reset requested
Z-Wave Debug starting serial connection loop
Z-Wave Debug starting zwave packet parser thread
Z-Wave Debug SENT getVersion: 01 03 00 15 E9
Z-Wave Debug RCVD getVersion: 01 10 01 15 5A 2D 57 61 76 65 20 33 2E 39 35 00 01 99
Z-Wave Debug . . getVersion: Z-Wave 3.95 static controller
Z-Wave Debug SENT getHomeID: 01 03 00 20 DC
Z-Wave Debug RCVD getHomeID: 01 08 01 20 F8 FC 5C 24 01 AB
Z-Wave Debug . . getHomeID: F8FC5C24, nodeID: 001
Z-Wave Debug SENT getInterfaceFeatures: 01 03 00 05 F9
Z-Wave Debug RCVD getInterfaceFeatures: 01 04 01 05 18 E7
Z-Wave Debug . . getInterfaceFeatures: 18
Z-Wave Debug SENT getInterfaceApiCapabilities: 01 03 00 07 FB
Z-Wave Debug RCVD getInterfaceApiCapabilities: 01 2B 01 07 01 00 00 86 01 01 00 5A FE 81 FF 88 4F 1F 00 00 FB 9F 7D A0 67 00 00 80 00 80 86 00 00 00 E8 73 00 00 0E 00 00 60 00 00 FA
Z-Wave Debug . . getInterfaceApiCapabilities: supportedFuncIDs: 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18 1C 20 21 22 23 24 27 29 2A 2B 2C 2D 41 42 44 45 46 47 48 49 4A 4B 4C 4D 50 51 53 54 55 56 57 5E 60 61 62 63 66 67 80 90 92 93 98 B4 B6 B7 B8 B9 BA BD BE BF D2 D3 D4 EE EF
Z-Wave Debug . . getInterfaceApiCapabilities: serialApi 1.00, manufactureId 0086, productType 0101, productId 005A
Z-Wave connected to Z-Stick Plus (ZW090) interface on /dev/cu.usbmodemFD121 (firmware 1.00)
Z-Wave Debug SENT forceSUC: 01 05 00 54 01 01 AE
Z-Wave Debug RCVD forceSUC: 01 04 01 54 01 AF
Z-Wave Debug SENT getInitialNodeData: 01 03 00 02 FE
Z-Wave Debug RCVD getInitialNodeData: 01 25 01 02 05 08 1D 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 C9
Z-Wave Debug . . getInitialNodeData: is static update controller
Z-Wave Debug . . getInitialNodeData: [1, 3]
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 01 BB
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 93 16 01 02 02 01 33
Z-Wave Debug . . getNodeProtocolInfo: node 001, class name: Static Computer Controller
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Static Controller : Static Controller : Static Computer Controller (02 : 02 : 01)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 00
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20
Z-Wave Debug . . getNodeProtocolInfo: encrypt class commands:
Z-Wave Debug . . getNodeProtocolInfo: features: beaming
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 03 B9
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D2 9C 00 04 10 01 ED
Z-Wave Debug . . getNodeProtocolInfo: node 003, class name: Relay Power Switch
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Relay Switch : Relay Power Switch (04 : 10 : 01)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 25
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 25 27
Z-Wave Debug . . getNodeProtocolInfo: features: routing, beaming
Z-Wave found module included in controller with no matching device (missing or disabled): 003 - Relay Power Switch
Z-Wave Debug starting node healing thread
Z-Wave Debug starting node status polling thread
Z-Wave Debug intiatingSyncUI (timeout in 1500 seconds)
Z-Wave Debug SENT getNodeNeighbors: 01 06 00 80 03 01 01 7A
Z-Wave Debug RCVD getNodeNeighbors: 01 20 01 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5E
Z-Wave Debug . . getNodeNeighbors: nodeId 003, neighbors: - none -
Z-Wave Debug SENT assignReturnRoute: 01 05 00 46 03 01 BE
Z-Wave Debug RCVD assignReturnRoute: 01 04 01 46 01 BD
Z-Wave Debug RCVD assignReturnRoute: 01 05 00 46 01 01 BC
Z-Wave Debug . . assignReturnRoute: node 003, success 0
Z-Wave Debug SENT requestNodeInfo: 01 06 00 60 03 24 F2 4C
Z-Wave Debug RCVD requestNodeInfo: 01 06 00 49 81 00 00 31
Z-Wave Debug RCVD requestNodeInfo: failed (module asleep or doesn't support command)
Dec 3, 2016, 3:30:23 PM
Z-Wave Debug terminatingSyncUI
So, what can I do here to get this working? I don't want to run around and start syncing everything to the Gen5 only to reset it and do it again. I have factory reset the Gen5 to no avail and this device that is failing worked fine on my Gen2 under I6 but for some reason since upgrading to release I7 my ZWave network went from near perfect to total disarray.
It doesn't help my attitude that I'm tired and injured so that's probably making me cranky .
