Does indigo control how the led ring provides feedback on energy usage? I am controlling a towel warmer that uses about 250 watts. I would suspect that should be red on the led ring but instead the ring is green.
matt (support) wrote:In the device settings dialog is the configuration item LED mode popup menu set to Mirrors Load?
matt (support) wrote:Mirrors Load I would expect to just change colors if the load is OFF versus ON. Are you seeing somewhere in the Aeotec documentation that the LED ring can change colors based on a threshold? The report threshold settings's, I believe, just refer to when the module reports energy/power settings back to Indigo.
Save on what you spend.
Smart Switch 6 has world-class energy monitoring technology built right in. In real-time it can understand how much electricity your devices are using and let you know.
It does that via the Aeotec LED Ring. 16 million colours of light are used to visually communicate how much electricity is being used.
