I periodically (maybe every 30 minutes - 1 hour) gets this error in the log...
- Code: Select all
14 Nov 2016, 03:44:50
Z-Wave Error Error in plugin execution:
File "/Library/Application Support/Perceptive Automation/Indigo 7/IndigoPluginHost.app/Contents/PlugIns/serialinterface.py", line 501, in startCommThread
self.processCommThread()
File "/Library/Application Support/Perceptive Automation/Indigo 7/IndigoPluginHost.app/Contents/PlugIns/serialinterface.py", line 675, in processCommThread
self.processQueueInPacket(packet) # Subclass is required to define.
File "zwaveinterface.py", line 2224, in processQueueInPacket
File "zwaveinterface.py", line 2198, in _processFuncCall
File "zwaveinterface.py", line 2259, in _processCommandReply
File "zwaveinterface.py", line 2243, in _processFuncTriggersAndBroadcast
File "zwaveinterface.py", line 2196, in _processFuncCall
File "zwavecmd_wakeinterval.py", line 182, in _processNodeAwake
AttributeError: 'NoneType' object has no attribute 'wakeDelayProcessingTimer'
Z-Wave Error exc type is <type 'exceptions.AttributeError'>
Z-Wave Error restarting serial connection in 5.0 seconds
Z-Wave connected to Z-Wave 3.95 static controller interface on /dev/cu.usbmodemFA131 (firmware 1.00)
Z-Wave found module included in controller with no matching device (missing or disabled): 002 - Entry Control
any suggestions?
Thanks for your help
