Polling wall switch as often as possible?
Thu Nov 10, 2016 9:55 am
Different Computers offline
I've got one of these
  Z-Wave                          Indigo Device "Dining Room" Z-Wave Properties:
Indigo Z-Wave Version: 1.0.371
Node ID: 14
Model: Dimmer Switch (LRM-AS)
Model ID: 44573034
Manufacturer: Evolve
Manufacturer ID: 0113
Protocol Version: 3.42
Application Version: 5.41
Model Definition Version: 0
Library Type: 6
Class Name: Dimmable Scene Switch
Class Hierarchy: 04 : 11 : 04
Command Class Base: 26
Command Versions: 20v1 70v1 72v1 73v1 86v1 26v1 27v1 2Bv1 2Cv1
Features: routing, beaming
Neighbors: 2, 3, 4, 5, 11, 15, 22
Associations: - none -
that has been working fine for as long as I've had Indigo. But having set up a new trigger based on when the switch's state changes, I noticed that it didn't trigger. I realized it was set to poll once an hour. When I change that to "as often as possible" the trigger fires off in an acceptable amount of time.
Am I really looking at problems by doing this? The switch is mains powered of course, so no problem with battery drain. But am I compromising my z-wave network?
Thu Nov 10, 2016 1:14 pm
Re: Polling wall switch as often as possible?
I wouldn't say compromising. Congesting, yes. For a device configured like that, Indigo waits until there is no other Z-Wave traffic scheduled, then sends out the command. It keeps the network busy, and if you have a lot of devices broadcasting (sensors, etc), then there will likely be more collisions. But Z-Wave (unlike Insteon) handles collisions pretty/very well. I wouldn't have a lot of devices doing it, but one or two is probably ok.
Thu Nov 09, 2017 9:44 am
jltnol offline
So I just uncovered this problem as well. I have several GE Z-Wave switches, all set to poll only on activity, but they don't send Indigo any information when they are operated locally at the switch. While I thought this may have been a firmware issue, oddly enough one of the 3.9 versions work, while others don't. The lone Z-Wave Dimmer also seems to communicate well.
My next thought was that some of these switches just have bad Z-Wave network connections, but all of the Z-Wave switches can be triggered by Insteon Keypad Links, which all work 99% of the time, so the Indigo TO Z-wave connection is fine. Z-Wave locks all send info to Indigo as needed and expected, but different devices, I know.
Right now, polling is set to "Only when activity is detected" on the problem devices, but I'm going to change them all to 5 minutes. This will only be a short term fix for me, as timing is everything..
]Nov 9, 2017 at 9:07:04 AM
Z-Wave Indigo Device "Pool Garage Lights" Z-Wave Properties:
Indigo Z-Wave Version: 2.0.103
Node ID: 6
Model: Relay Power Switch
Model ID: 49523033
Manufacturer: General Electric
Manufacturer ID: 0063
Protocol Version: 3.67
Application Version: 3.28
Library Type: 6
Class Hierarchy: 04 : 10 : 01
Command Class Base: 25
Command Versions: 20v1 25v1 86v1 27v1 70v1 72v1 73v1 77v1
Neighbors: 8, 10, 13
Config Values: - none -
Z-Wave Indigo Device "Kithcen-Pantry" Z-Wave Properties:
Node ID: 7
Model ID: 49523032
Application Version: 3.29
Library Type: 6
Neighbors: 8, 9, 11, 12, 13
Z-Wave Indigo Device "Kitchen-Porch Lights" Z-Wave Properties:
Node ID: 8
Model: Dimmable Power Switch
Model ID: 49443031
Application Version: 3.37
Library Type: 6
Class Name: Dimmable Power Switch
Class Hierarchy: 04 : 11 : 01
Command Versions: 20v1 26v1 86v1 27v1 70v1 72v1 73v1 77v1
Neighbors: 6, 7, 9, 10, 13
Z-Wave Indigo Device "Office-Fan" Z-Wave Properties:
Node ID: 9
Model ID: 49523032
Library Type: 6
Neighbors: 7, 8, 10, 11, 13
Z-Wave Indigo Device "MBR-Shower" Z-Wave Properties:
Node ID: 10
Model ID: 49523032
Library Type: 6
Neighbors: 6, 8, 9, 11, 12, 13
Z-Wave Indigo Device "MBR-Closet" Z-Wave Properties:
Node ID: 11
Model ID: 49523032
Library Type: 6
Neighbors: 7, 9, 10, 12
Z-Wave Indigo Device "MBR-Water Closet" Z-Wave Properties:
Node ID: 12
Model ID: 49523032
Library Type: 6
Neighbors: 6, 9, 10, 11, 13
Users browsing this forum: Google [Bot] and 10 guests
