I just put about a dozen of these HomeSeer dimmers in my house because I thought the double/triple tap scene control would be a nice feature if\when indigo supports it in the future. I also have some GE's that I swapped out for the HomeSeer dimmers to keep them all looking the same on the main floor of my house (requirement for wife acceptance). I have noticed that I get more LED flickering on some circuits that I didn't have with the GE's which surprised me because except for the nice dim level indicator on the front on the HomeSeer, they look like the same hardware.
I haven't started to swap LED bulbs yet to see if I can find ones that don't flicker as much with these switches. I had been using all Philips Warm Glow dimmable LEDs (also to keep the wife happy) so I don't really want to move back to bulbs that don't have the incandescent look when you dim them. I think Sylvania makes a "Sunset Effect" LED that does the same thing but they aren't as easy to find here in Canada.
I found this bulb compatibility chart after I bought the switches and some (but not all) of my problem bulbs were the clear Philips bulbs in the chart (
http://www.homeseer.com/compare-led-bul ... wd100.html) that apparently don't work well with these switches but worked fine with my GE's.
So, I do like the way the HomeSeer dimmers look and operate and the screw terminals are nice for installation (same as GE), but I'm a bit concerned that I seem to have more LED flicker issues now. They seemed like a great idea at first but I'm holding off on selling my GEs just in case I have to switch back. Maybe I should have gone insteon
I'd love to try Lutron RadioRA2 but the price scares me away every time I start adding it up.
I had been hoping the topic of these switches would come up here. I bought them as soon as they were available in Canada but I didn't bother starting the conversation since there was an #indigo7sneak that hinted they might be fully supported in the new version so I was just going to wait. I'm curious to hear if anyone else is having more LED flicker issues with these.
I also tried the Leviton... If they are the ones I tried, I hated the dimmer push buttons on the switches. You had to push those micro buttons so hard they hurt your fingers. I also had people hit the top of the switch a couple of times hard enough to pop the switch out into it's air-gap position which was pretty annoying.
