Fibaro Door / Window ZW+ sensor FGK-10x
Fri Oct 07, 2016 5:45 am
shapa offline
Mostly works, but detected as an old one ( FGK101 ), therefore wrong parameters applied and no temperature readings available.
http://manuals.fibaro.com/content/manua ... T-v2.0.pdf
Much more reliable in terms of inclusion process. Working distance is much better as well.
Z-Wave Syncing - started for "Front Entrance Door Sensor"
Z-Wave Syncing - retrieved module neighbors list: 2, 3, 4, 5, 6, 10, 16, 17, 25, 27, 28, 29, 30, 36, 37, 38, 39, 47, 52, 54, 55, 56, 60, 61, 62, 63, 64, 65, 68, 70, 72, 80, 88, 91, 92, 94, 95, 98, 99, 108, 116, 119, 130, 141, 143, 144, 157, 163, 165, 166, 179, 182, 201, 218, 220, 221, 222, 223, 230
Z-Wave Syncing - assigning return route to "104 - Front Entrance Door Sensor"
Z-Wave Syncing - retrieved manufacture and model names: Fibaro System - 010F, Door/Window Sensor (FGK101) - 07011001
Z-Wave Syncing - retrieved protocol version 4.05, app version 3.02
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : -- : -- (04 : 07 : 01, base 00)
Z-Wave Syncing - retrieved command classes: 20v1 80v1 22v1 84v2 85v1 86v1 71v1 70v1 2Bv1 8Ev1 30v1 31v5 72v1 73v1 56v1 98v1 59v1 5Av1 9Cv1 7Av1 5Ev1
Z-Wave Syncing - retrieved wake interval of 60 minutes
Z-Wave Syncing - device "104 - Front Entrance Door Sensor" wake interval changed to 60 minutes
Z-Wave Syncing - retrieved group 2 associations: [1]
Z-Wave Syncing - retrieved group 3 associations: [1]
Z-Wave Syncing - retrieved group 4 associations: []
Z-Wave Syncing - retrieved group 5 associations: []
Z-Wave Syncing - group 2 association to interface already exists (skipping)
Z-Wave Syncing - group 3 association to interface already exists (skipping)
Z-Wave Syncing - retrieved battery level of 100%
Z-Wave Syncing - complete
Z-Wave device "104 - Front Entrance Door Sensor" parameter 1 "Delay duration until door/window sensor turns off" changed to 0 seconds
Z-Wave device "104 - Front Entrance Door Sensor" parameter 2 "Enable LED flash on change" changed to false
Z-Wave device "104 - Front Entrance Door Sensor" parameter 3 "Main sensor switch type (0: normally closed, 1: normally open, 2: push button, 3: toggle)" changed to 0
Z-Wave device "104 - Front Entrance Door Sensor" parameter 12 "Temperature change sensitivity trigger (0: every 4 mins, 8: 0.5 °C, 16: 1.0 °C, 24: 1.5 °C, 32: 2.0 °C, 48: 3.0 °C, 64: 4.0 °C, 80: 5.0 °C)" changed to 255
Z-Wave received "Front Entrance Door Sensor Tamper Switch" status update is on
Z-Wave received "Front Entrance Door Sensor" status upd
Fri Oct 07, 2016 10:34 pm
Re: Fibaro Door / Window ZW+ sensor FGK-10x
Thanks for the details – I've added it to the list!
Sat Oct 08, 2016 4:56 pm
Do you have a temperature sensor connected to it?
And have you excluded it/re-included it in the Z-Wave interface after you connected the temperature sensor?
If so, re-define/sync it in Indigo. The sync above isn't showing any multi-endpoints defined. That would be okay, but that means it works very differently than the old FGK-100. The manuals for both the old and new aren't clear at all, so I'm not sure if they operate differently in that (temperature sensor) regard or not.
Sun Oct 09, 2016 3:42 am
shapa offline
Matt,
Tried quite a few times - connected sensor, re-inclusion, full reset and inclusion, etc.
Still no temperature sensor and readings.
The device is changed significantly (settings).
Sun Oct 09, 2016 10:26 am
I understand Indigo isn't showing the sensor, but I'm still curious about seeing a define/sync Event Log after the temperature sensor is connected (and has been excluded/re-included with the Z-Wave interface). What I'm looking for is if the module then shows it supports the multi-endpoint command class (your Event Log above does not show that). Depending on if it does or not will impact how we create the device definition so the temperature value can be read.
Wed Oct 26, 2016 2:54 am
marketability offline
Just added an FGK-10x sensor - all good
Just added a 2nd FGK-10x and the open/close and tamper dives are "swapped"
ie. if the door opens, the tamper device turns on
any suggestions please? I've added/removed several times but no joy
Wed Oct 26, 2016 6:13 am
shapa offline
It's because of wrong parameters applied to the sensor (by Indigo) as it's recognised like a previous model.
Change parameters manually, it will work.
Wed Oct 26, 2016 7:01 am
thanks for the reply - not sure why you mean/how to do that sorry?
Sun Nov 13, 2016 5:32 pm
shapa offline
Matt,
It works on v7, however temp device is still not shown.
Looks like they changed the way... Tried two different FGK10x, as well as different DS18B20.
Those DS18B20 works fine on the previous Fibaro door sensor version.
Z-Wave Syncing - retrieved module neighbors list: 2, 3, 4, 5, 6, 10, 12, 16, 17, 18, 25, 27, 28, 29, 30, 36, 37, 38, 39, 47, 52, 54, 55, 56, 59, 60, 61, 62, 63, 64, 65, 66, 68, 70, 72, 80, 82, 88, 91, 92, 94, 95, 98, 106, 108, 116, 119, 137, 141, 143, 157, 163, 165, 166, 179, 182, 201, 218, 220, 221, 222, 223, 230
Z-Wave Syncing - assigning return route to "142 - Door/Window"
Z-Wave Syncing - retrieved manufacture and model names: Fibaro System - 010F, Door/Window Sensor (FGK10x) - 07011001
Z-Wave received "Living Bathroom Danfoss Radiator Thermostat" heat setpoint is 19.00 °C
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Notification Sensor : Notification Sensor (04 : 07 : 01, base 00)
Z-Wave Syncing - retrieved capabilities: routing, battery, beaming, security, waking
Z-Wave Syncing - device "142 - Door/Window" wake interval changed to 60 minutes
Z-Wave Syncing - retrieved group 3 associations: []
Z-Wave Syncing - retrieved parameter 20 "Group 1 command type" is 0
Z-Wave Syncing - retrieved parameter 1 "Operation mode" is 0 "Door Sensor or External Alarm"
Z-Wave Syncing - retrieved parameter 3 "LED mode" is 6 "Tamper and Wakeup"
Z-Wave Syncing - retrieved parameter 2 "Reverse ON / OFF commands for magnet switch" is false
Z-Wave Syncing - retrieved parameter 14 "Delayed on" is 0 seconds
Z-Wave Syncing - retrieved parameter 15 "Delayed off" is 0 seconds
Z-Wave Syncing - retrieved parameter 31 "Enable tamper auto off" is true
Z-Wave Syncing - retrieved parameter 30 "Tamper off delay" is 5 seconds
Z-Wave Syncing - retrieved parameter 51 "Temperature sensitivity" is 10 * 0.1°C
Z-Wave Syncing - retrieved parameter 50 "Temperature measuring interval" is 300 seconds
Z-Wave Syncing - retrieved parameter 52 "Temperature reporting interval" is 0 seconds
Z-Wave Syncing - retrieved parameter 53 "Temperature offset" is 0 * 0.1°C
Mon Nov 14, 2016 11:25 pm
Indigo 7.0.1 is now available and will hopefully create the temperature sensor device on next sync.
Tue Nov 15, 2016 10:26 am
shapa offline
Works now!
Cool :)
Tue Nov 15, 2016 3:00 pm
shapa offline
Update
Temperature readings / device available, but FGK-10x is not working as a door sensor.
There are notifications regarding tamper switch (which is wrong) - testing with a magnet but not touching the sensor.
" Z-Wave received "Entrance Door Sensor Tamper Switch" status update is off"
Tue Nov 15, 2016 3:56 pm
Wait, you want both the temperature sensor and the door sensor to work? :mrgreen:
Can you turn on debug logging (Interfaces->Z-Wave->Configure) and open/close the door a few times, then copy/paste the log results for me?
Wed Nov 16, 2016 6:37 am
shapa offline
Yep, indeed - nice to have both working :D
So Indigo detects "tamper" instead of open / close
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 0F 00 04 00 8E 09 71 05 00 00 00 FF 06 17 00 E9
Z-Wave Debug . . requestAlarmSensorStatus: node 142, endpoint None, cmdClass 71, type 0, value 0, classSubKey 710000
Z-Wave Debug . . requestAlarmSensorStatus: typeExt 6, valueExt 23, classSubKeyExt 7100000617
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 0F 00 04 00 8E 09 71 05 00 00 00 FF 06 16 00 E8
Z-Wave Debug . . requestAlarmSensorStatus: typeExt 6, valueExt 22, classSubKeyExt 7100000616
Z-Wave Debug filtering duplicate command -- old: 710000, 7100000617, 0, new: 710000, 7100000616, 0 (0.5321 secs)
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 0D 06 31 05 04 22 00 6B 85
Z-Wave Debug . . requestVarSensorStatus: node 013, endpoint None, type 4, raw value 2200...
Z-Wave Debug . . requestVarSensorStatus: 10.7 W (float: 10.700000)
Z-Wave Debug received "Rack LED Composite" power load to 10.7 W
Z-Wave Debug filtering duplicate command -- old: 710000, 7100000617, 0, new: 710000, 7100000616, 0 (0.4764 secs)
Z-Wave Debug filtering duplicate command -- old: 710000, 7100000617, 0, new: 710000, 7100000616, 0 (0.5275 secs)
Z-Wave Debug filtering duplicate command -- old: 710000, 7100000617, 0, new: 710000, 7100000616, 0 (0.5776 secs)
Wed Nov 16, 2016 12:59 pm
Just to make sure I'm clear, are you saying: 1) tripping the reed (magnetic) sensor but Indigo detects that as tamper, or 2) reed does nothing but tamper works as it should?
Users browsing this forum: cuhouse and 24 guests
