Popp Z-wave Smoke Detector / Wireless Siren
Thu Oct 06, 2016 10:54 am
tintin4fun offline
Has anybody got this hardware to work in Indigo?
http://www.popp.eu/products/sensors/smoke-sensor/
Any suggestions would be highly appreciated.
Mon Oct 17, 2016 6:22 am
tintin4fun offline
Re: Popp Z-wave Smoke Detector / Wireless Siren
Bump!
Isn't there anyone who could help me out?
Thank you for any help!
Mon Oct 17, 2016 7:23 am
Re-Define/Sync it in Indigo then copy/paste the Event Log results into a reply for me.
Thu Oct 20, 2016 5:21 am
tintin4fun offline
Great! Thanks a lot for looking into this.
Indigo doesn't recognize the unit other than a Routing Slave.
Here are the log file entries after resync and redefine of the unit:
20 okt. 2016 13:06:30
Z-Wave Syncing - started for "007 - Routing Slave"
Z-Wave Syncing - retrieved module neighbors list: 2, 3, 4
Z-Wave Syncing - assigning return route to "007 - Routing Slave" Z-Wave Syncing - assigned return route
Z-Wave Syncing - retrieved manufacture and model names: Popp &
Co. - 0154, Routing Slave - 01000201
Z-Wave Syncing - retrieved protocol version 4.05, app version 2.01 Z-Wave Syncing - retrieved class hierarchy: Routing Slave : -- : --
(04 : 07 : 01, base 00)
Z-Wave Syncing - retrieved command classes: 20v1 80v1 25v1
86v1 30v1 70v1 71v1 72v1 73v1 59v1 5Av1 5Ev1 85v1
Z-Wave Syncing - retrieved group 3 associations: []
Z-Wave Syncing - group 1 association to interface already exists
(skipping)
Z-Wave Syncing - retrieved battery level of 100%
Z-Wave Syncing - complete
Z-Wave received "007 - Routing Slave" status update battery level
Regards Tintin
Thu Oct 20, 2016 7:55 am
That helps - thanks!
Thu Oct 27, 2016 9:52 am
tintin4fun offline
Hello!
Any news on the subject?
Thank you!
Thu Oct 27, 2016 10:25 am
It isn't available yet, but it was high on the priority list for Indigo 7.
Thu Jan 26, 2017 5:36 pm
This thread is old but I wanted to follow-up that Indigo 7.0 is now available (has been for a while). It adds supports for dozens of new Z-Wave devices, including the Popp Smoke Detector and Siren (004001
Fri Jan 27, 2017 3:37 am
tintin4fun offline
Yeah! The upgrade is done and everything works perfect with the new version.
:D
Sat Aug 19, 2017 4:37 am
mortenkols offline
I have tested the fire detector and when it detects fire it's just the siren that changes the status in indigo, smoke alarm does not change status, it off when its fire.
Someone else who has tested this?
Sat Aug 19, 2017 11:49 am
Can you enable the Z-Wave debug logging checkbox (via the Interfaces->Z-Wave->Configure... menu item), then trip the fire sensor again? I'd like to see exactly what is logged in the Event Log window as a result, and we can tweak our device definition to make sure the smoke alarm device changes its device state.
Mon Aug 21, 2017 10:54 am
mortenkols offline
Here it is
Smoke detector 1
21. aug. 2017, 18.50.38
Z-Wave Watcher Debug Raw command received (Node 72): 01 11 00 04 04 48 0B 71 05 00 00 00 FF 01 02 00 00 00 25
Z-Wave Watcher Debug Raw command received (Node 72): 01 11 00 04 00 48 0B 71 05 00 00 00 FF 01 02 00 00 00 21
Z-Wave received "Stue og kjøkken - Sirene" status update is on
Z-Wave Watcher Debug Raw command received (Node 72): 01 0A 00 04 00 48 04 30 03 FF 02 73
Z-Wave Watcher Debug Raw command received (Node 72): 01 09 00 04 00 48 03 20 01 63 FB
Smoke detector 2
21. aug. 2017, 18.58.28
Z-Wave Watcher Debug Raw command received (Node 74): 01 11 00 04 04 4A 0B 71 05 00 00 00 FF 01 02 00 00 00 27
Z-Wave Watcher Debug Raw command received (Node 74): 01 11 00 04 00 4A 0B 71 05 00 00 00 FF 01 02 00 00 00 23
Z-Wave received "Soverom - Sirene" status update is on
Z-Wave Watcher Debug Raw command received (Node 74): 01 0A 00 04 00 4A 04 30 03 FF 02 71
Z-Wave Watcher Debug Raw command received (Node 74): 01 09 00 04 00 4A 03 20 01 63 F9
Tue Aug 22, 2017 6:25 pm
Thanks, that helps. We'll get the device definition updated soon.
Sat Sep 23, 2017 9:17 pm
Give this version of the Z-Wave library a try. I believe it will fix the issue.
Thu Nov 09, 2017 7:20 pm
Indigo 7.1.1 is now available for download and includes support for the POPP Smoke Detector and Siren.
