Zipato Multisensor 4 In 1
Sat Sep 24, 2016 12:17 pm
Howdy dudes,
Here's the log for a Zipato Multisensor 4 in 1 that i won earlier this year and had kinda forgotten about. It syncs but only shows as a routing slave.
  Z-Wave                          Indigo Device "075 - Routing Slave" Z-Wave Properties:
Indigo Z-Wave Version: 1.0.368
Node ID: 75
Model: Routing Slave
Model ID: 201F1F10
Manufacturer: Vision / Yale
Manufacturer ID: 0109
Protocol Version: 4.05
Application Version: 6.01
Model Definition Version: 0
Library Type: 3
Class Name: Routing Slave
Class Hierarchy: 04 : 07 : 01
Command Class Base: 00
Command Versions: 80v1 84v2 85v1 86v1 71v1 70v1 31v7 72v1 73v1 98v1 59v1 5Av1 7Av1 5Ev1
Features: routing, battery, beaming, waking
Neighbors: 1, 4, 5, 22, 23, 24, 25, 26, 27, 29, 30, 31, 32, 35, 36, 59, 67, 74
Associations: 1:[1] 2:[]
Config Values: - none -
And when i sync it:
  Z-Wave                          Syncing - started for "075 - Routing Slave"
  Z-Wave                          Syncing - retrieved module neighbors list: 1, 4, 5, 22, 23, 24, 25, 26, 27, 29, 30, 31, 32, 35, 36, 59, 67, 74
  Z-Wave                          Syncing - assigning return route to "075 - Routing Slave"
  Z-Wave                          Syncing - retrieved manufacture and model names: Vision / Yale - 0109, Routing Slave - 201F1F10
  Z-Wave                          Syncing - retrieved protocol version 4.05, app version 6.01
  Z-Wave                          Syncing - retrieved class hierarchy: Routing Slave : -- : -- (04 : 07 : 01, base 00)
  Z-Wave                          Syncing - retrieved command classes: 80v1 84v2 85v1 86v1 71v1 70v1 31v7 72v1 73v1 98v1 59v1 5Av1 7Av1 5Ev1
  Z-Wave                          Syncing - retrieved wake interval of 60 minutes
  Z-Wave                          Syncing - device "075 - Routing Slave" wake interval changed to 60 minutes
  Z-Wave                          Syncing - retrieved group 1 associations: [1]
  Z-Wave                          Syncing - retrieved group 2 associations: []
  Z-Wave                          Syncing - group 1 association to interface already exists (skipping)
  Z-Wave                          Syncing - retrieved battery level of 100%
  Z-Wave                          received "075 - Routing Slave" status update battery level 100%
Hope this helps :)
Sat Sep 24, 2016 9:37 pm
Re: Zipato Multisensor 4 In 1
Thanks – added to our list to look into.
Wed Mar 08, 2017 5:59 pm
Here is a beta of Indigo's Z-Wave library that adds preliminary support for the Zipato Multisensor. Re-sync it after you install it (extract it then double-click to install), and Indigo should create the devices for all the sensors. Let me know how it works for you.
Thu Mar 16, 2017 12:46 pm
Seems to work fine. Didn’t sync properly the first time but second time worked fine. Do you need a dump of any logs or anything?
Thu Mar 16, 2017 1:19 pm
Nah, not if it seems to be working correctly. Thanks for the follow-up.
Thu Nov 09, 2017 7:35 pm
Indigo 7.1.1 is now available for download and includes support for the Zipato Multi Sensor 4 in 1 (ZD2201).
Users browsing this forum: No registered users and 18 guests
