- Posted on
Thu Sep 08, 2016 9:08 am
matt (support)
offline
- Site Admin
I believe the FGRM222 (maybe the 221 as well but I'm not sure) uses a manufacturer proprietary command (0x91) for controlling both the blind position and the lamella's rotation/orientation. It isn't documented well, but you can try sending a raw Z-Wave command (Z-Wave->Interfaces->Send Raw Z-Wave Command... menu item) to see if we can figure out how to control it. Try something like this for the payload bytes:
0x91 0x01 0x0F 0x26 0x01 0x01 0x00 LAMELLAS_ORIENTATION
where LAMELLAS_ORIENTATION is a value from 0 to 99 decimal, so no "0x" prefix (0 is vertical and 99 is horizontal, I think).
You can also try this command for setting a specific blind position:
0x91 0x01 0x0F 0x26 0x01 0x02 BLIND_POSITION 0x00
where BLIND_POSITION is a value from 0 to 99 decimal, so no "0x" prefix (0 is fully closed, 99 is full opened, I think).
I wish Fibaro had implemented the blind position and lamellas as separate endpoints (and not used a proprietary command), then it would be easy to map them to Indigo dimmers. Let me know if the commands above work. If they do we'll add to our request list to add UI actions for them.
