Fibaro "The Button"
Mon Nov 14, 2016 12:47 pm
Fordy offline
Re: Fibaro "The Button"
I see exactly that - and that's what I had... however the trigger does nothing on a button press...
Though I do receive the zwave message received from the button..
Mon Nov 14, 2016 1:07 pm
What action have you set your trigger to do and the trigger is enabled? :)
Mon Nov 14, 2016 1:09 pm
Fordy offline
Ha yes! Good guess though! - I have it set to "toggle" a lamp, that I tested by clicking on "execute" to do it immediately.
I also used the same trigger to make it work if I choose "any received command" if I choose this option the button works great - but only for single clicks... but limiting :)
Mon Nov 14, 2016 1:10 pm
Can you enable debug logging (via Interfaces->Z-Wave->Configure... menu item), press the button several times, then copy/paste the Event Log results into a reply for me?
Mon Nov 14, 2016 1:37 pm
Fordy offline
Heya Matt,
Sure, find below - a single press, single press, and a double press:
14 Nov 2016, 19:35:58
Z-Wave Debug RCVD nonceFetch: node 040
Z-Wave Debug SENT nonceReport: 01 11 00 13 28 0A 98 80 BA 72 63 6C 31 83 88 B1 25 5E F0
Z-Wave Debug RCVD encryptedPacket: 00 5B 03 0A 80 01 (decrypted)
Z-Wave Debug RCVD sceneActivateCmd2: 01 0B 00 04 00 28 05 5B 03 0A 80 01 FF
Z-Wave Debug . . sceneActivateCmd2: node 040, type: 128, scene: 1
Z-Wave received "MasterRm-Button" scene 31769
Z-Wave Debug SENT nonceReport: 01 11 00 13 28 0A 98 80 BA 72 63 6C 31 83 88 B1 25 5F F1
Z-Wave Debug RCVD encryptedPacket: 00 5B 03 0B 80 01 (decrypted)
Z-Wave Debug RCVD sceneActivateCmd2: 01 0B 00 04 00 28 05 5B 03 0B 80 01 FF
Z-Wave Debug SENT nonceReport: 01 11 00 13 28 0A 98 80 BA 72 63 6C 31 83 88 B1 25 60 CE
Z-Wave Debug RCVD encryptedPacket: 00 5B 03 0C 83 01 (decrypted)
Z-Wave Debug RCVD sceneActivateCmd2: 01 0B 00 04 00 28 05 5B 03 0C 83 01 FF
Z-Wave Debug . . sceneActivateCmd2: node 040, type: 131, scene: 1
Z-Wave received "MasterRm-Button" scene 32537
Mon Nov 14, 2016 1:42 pm
In the settings dialog, what firmware version does it say your module is?
Mon Nov 14, 2016 1:44 pm
Fordy offline
firmware 3.02 on the button
Mon Nov 14, 2016 2:40 pm
Juju offline
Hello,
Another issue on my side (don't know if it's linked to Indigo or button malfunction) : when I press the button (once or several times), sometimes it's detected as received "Bouton noir" button double tap or received "Bouton noir" button pressed, but very often it's detected like a status request and I have in the log one or several lines (depending the number of clicks) received "022 - Bouton noir" status update battery level 100%.
Julien
Mon Nov 14, 2016 2:42 pm
Mine does that as well; it doesn't mean the click etc hasn't been received - it's just trying to be helpful giving you battery status as well.
Mon Nov 14, 2016 2:54 pm
Juju offline
But here the clicks (single, double,...) are not detected. I have only a battery report.
And few times (1/10 clicks) they are well interpreted.
I will test it with another software.
Mon Nov 14, 2016 3:02 pm
That is exactly the same problem that I had with the first Red Button I had. Matt spent ages trying to get it to work with Indigo in beta testing. It turned out to be a defective button - I returned it for a replacement which is so far working correctly. :)
With my replacement button, when you press the button down, you can hear a definite click. With the original there was no clicking I just got the button pressed message or battery updates. :?
I suspect your button is defective. :|
Mon Nov 14, 2016 3:05 pm
You should be seeing something like this in your log if it is working correctly:
Z-Wave received "Red Button" button pressed
Z-Wave received "Red Button" button double tap
Z-Wave received "Red Button" button triple tap
Z-Wave received "Red Button" button quadruple tap
Z-Wave received "Red Button" button quintuple tap
Z-Wave received "Red Button" button held down
Z-Wave received "Red Button" button released
Mon Nov 14, 2016 3:20 pm
Fordy offline
Ah! That looks like what I'd like to see! :) - I see this, no matter what I press:
The scene ID always stays the same for 1 press, and is different for each 2, 3, 4, etc!
Seems the scene ID isn't being translated into a "button press"...
Mon Nov 14, 2016 3:21 pm
Juju offline
OK thanks Jon.
I will try to have a replacement.
Mon Nov 14, 2016 5:29 pm
Actually, I think the problem is that your module is sending the scene commands with the Slow Refresh flag set. Indigo isn't properly ignoring that flag, so it doesn't find a scene match. I don't know why your module is setting that flag. According to the docs, "This flag is used to advertise if the node is sending Key Held Down notifications at a slow rate."
I will modify the next version of Indigo to ignore that flag, which should help. I'm not sure if the module is malfunctioning or not.
