Fibaro "The Button"
Fri Aug 19, 2016 5:21 am
Frakke offline
Fibaro "The Button"
Fri Aug 19, 2016 5:45 am
Re: Fibaro "The Button"
Vesternet (UK) are selling them for £40 (UKP) with availability at end of August.
Seems quite expensive for a single button switch!
Mind you if I had the money to afford an apartment like in this video, I probably wouldn't be worried about the cost :D
Fri Aug 19, 2016 6:48 am
Colorado4Wheeler offline
Just what I needed, a big "Staples button" in my house :). Or is the the "direct button to the president" button? Oh, I know, it's the "fire the nukes" button! I like Fibraro's stuff and this looks like exactly the type of thing they would come up with but I'm not really sure where I would want that.
Fri Aug 19, 2016 6:55 pm
Indigo 6.1 might be able to detect a simple button press from it out-of-the-box, but we won't know for sure until we (or someone) tries it. More complete support for it, like detecting single vs. double-taps, will require a device definition so I've add it to our request list.
Mon Sep 05, 2016 9:35 am
Juju offline
Hello Matt,
I sent the device definition last week.
Out of the box, nothing happen with this device.
For information, it's not a single button. You can do 1, 2, 3, 4 clicks and also push and maintain + release.
Ask me if you need additional information.
Julien
Mon Sep 05, 2016 10:35 am
Hi Julien,
Thanks, no promises but based on the report it looks promising that we'll be able to get this one fully supported in Indigo 7.
Fri Sep 09, 2016 10:50 am
mat offline
NICE - Always wanted a big red button to press - I have a feeling mine is just going to play a fart mp3, but hey.
Late 2018 mini 10.14
Fri Sep 09, 2016 12:30 pm
You want that to be in pristine aac quality!
Fri Sep 09, 2016 5:28 pm
mat offline
O' the things I could do with a big red button! Especially if its labelled "Do not press" :twisted: :roll:
Sat Sep 10, 2016 1:29 am
I think I'd label mine "Self Destruct" :D
Sun Nov 13, 2016 1:24 pm
Fordy offline
Happy v7.0!! :)
Ok, so I have upgraded successfully, I paired my "button" remotely without needing to move the z-stick closer! - awesome!
However, the only way I seem to be able to use it is by setting up a trigger for a "zwave command received" and setting it to "any command".
This then works to use it as a single button, but it can't see each individual button press, or hold and release, etc.
I do see on the inbound zwave command there is a "button pressed", "button double tap", "button triple tap", etc.. however these seem to do nothing.
I see in the event log indigo does receive a unique scene command / Id with each button press but I'm stuck...
Is this a bug, or am I missing a trick?
Sun Nov 13, 2016 2:02 pm
I think your particular The Button has a different model ID then what we have defined. Can you copy/paste the result of the Event Log window showing the define/sync with it? We can then get it added and you'll see the additional scenes in the Trigger dialog.
Sun Nov 13, 2016 2:04 pm
In the meantime, if you have a look at my Zwave Scene Controller plugin - it should work just fine until such time as the new device profile is updated.
viewtopic.php?f=189&t=17102
(Shameless plug there...)
Sun Nov 13, 2016 2:17 pm
Fordy offline
Will checkout the plugged plugin plug! :) - ta sir!
Matt, here's the log:
Z-Wave Syncing - started for "MasterRm-Button"
Z-Wave Syncing - retrieved module neighbors list: 2, 9, 12, 13, 14, 15, 17, 39
Z-Wave Syncing - assigning return route to "040 - MasterRm-Button"
Z-Wave Syncing - retrieved manufacture and model names: Fibaro System - 010F, Button (FGPB101) - 0F011000
Z-Wave Syncing - retrieved protocol version 4.38, app version 3.02
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Wall Controller : Basic Wall Controller (04 : 18 : 01, base 00)
Z-Wave Syncing - retrieved command classes: 80v1 84v2 85v1 86v1 8Ev1 56v1 98v1 59v1 5Av1 5Bv1 9Cv1 5Ev1 20v1 70v1 71v1 72v1 73v1 7Av1
Z-Wave Syncing - retrieved encrypt commands: 84 85 86 8E 70 71 72 5A 5B 9C
Z-Wave Syncing - retrieved capabilities: routing, battery, beaming, security, waking
Z-Wave Syncing - retrieved wake interval of 60 minutes
Z-Wave Syncing - device "040 - MasterRm-Button" wake interval changed to 60 minutes
Z-Wave Syncing - retrieved group 3 associations: []
Z-Wave Syncing - retrieved group 4 associations: []
Z-Wave Syncing - retrieved battery level of 100%
Z-Wave Syncing - complete
Mon Nov 14, 2016 12:40 pm
Your sync looks good, and that is the model ID we have matching Indigo's device definition for the FGPB101. So, I'm not sure why it isn't working. When you create a new Trigger in Indigo, select the Z-Wave Command Received Type and Incoming Command Received Event, the configure dialog should show. From there when you select your FGPB101 device, what shows in the Received popup menu? In addition to Any Command, there should be items for:
Button Pressed
Button Double Tap
Button Triple Tap
Button Quadruple Tap
Button Quintuple Tap
Button Held Down
Button Released
